17" wheels won't balance
Discussion in 'Wheels & Tires' started by rodriguez2103, May 7, 2017.
  1. May 8, 2017 at 1:29 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I had an issue with 18" after market wheels which was resolved solely by using extended thread lugnuts, the OEM lugnuts were not long enough for the thicker wheel and they would vibrate at 55-60 no matter how many times balanced or using different places to balance them. Not all Discount Tires have a road force balance machine by the way.
  2. May 8, 2017 at 4:31 PM
    rodriguez2103
    rodriguez2103 [OP] New Member
    CHARLIE
    2007 Tundra Limited CM
    They have the right machine and right lugs. I'm just done! Went to a local wheel shop and a shop that does lifts/wheels/tires and they couldn't balance them either.
  3. May 8, 2017 at 9:34 PM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    If all else fails you could try this
    http://www.ride-on.com/
    I have been using it in my harley tires for years now and am very happy! They make it for other applications as well.
    I have no affiliation with ride on, just a happy user.
    chphilo likes this.
  4. May 9, 2017 at 4:25 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    ET lugs are bad. I've seen them break and the collar gets stuck on the lug and then you can't take your wheel off.
    The right answer is to only use wheels with the proper hub bore, 110mm. If you absolutely have to, use a hub bore adapter; ie 116 hub bore with an adapter to fit the tundra's 110mm hub
    equin likes this.
  5. May 9, 2017 at 4:59 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have balancing beads in my tires and my truck rides very smooth. Do you know how effective these are in balancing you wheels?
  6. May 9, 2017 at 5:50 PM
    rodriguez2103
    CHARLIE
    So tundras have a 110mm bore and my wheels have a 116.5mm bore. However the Methods are lug centric, can I still use a hub ring to take up that slack?
  7. May 9, 2017 at 7:08 PM
    PMG
    PMG New Member
    Use a hub ring that goes from 116.5 to 110..
    Wth did you order 116.5 in the first place?
    osidepunker likes this.
  8. May 10, 2017 at 4:24 AM
    rodriguez2103
    CHARLIE
    According to Tire Rack that was the proper size. That wheel has a push through center cap so that's the reason for the difference.
  9. May 10, 2017 at 7:59 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    My methods are 110. Do you still have the wheels? If you can't exchange them, try the hub rings, it'll probably fix it.
  10. May 10, 2017 at 8:26 AM
    PMG
    PMG New Member
    Then have tire rack exchange them because it's their error. Or just do the hub rings. I have the rings on my wife's Infiniti which has 22s; no issues.
  11. May 10, 2017 at 9:16 AM
    rodriguez2103
    CHARLIE
    MR30478558700 That is the part number on the wheels.
  12. May 10, 2017 at 9:21 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    You bought the wrong wheel. Exchange it for a Method with a 110mm hub bore or get a 116mm to 110mm adapter.
    equin and joonbug like this.
  13. May 10, 2017 at 9:27 AM
    rodriguez2103
    CHARLIE
    Just called TR and they said it's the right part number but couldn't confirm the bore size. Said "it's not coming up on my end". Guys also said make sure they torque the wheels when they are in the air.
    I'm so mind fucked right now
  14. May 10, 2017 at 9:29 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'm not sure why you are confused. Call Method Wheels and ask them for the hub bore size for that part number wheel. I googled that part number and Summit Racing lists the hub bore as 116mm.
    Bottom line is the hub bore is too big. Either get a different wheel or get an adapter.
    TheBeast likes this.
  15. May 10, 2017 at 9:39 AM
    rodriguez2103
    CHARLIE
    Just frustrated but I appreciate all your guys input!
    Summit site says 116.5 but 4WD and 4WheelParts say 110.
  16. May 10, 2017 at 9:44 AM
    rodriguez2103
    CHARLIE
    Called Method and you are right that is a 116.5 bore
    In 17s they don't offer a 110mm bore on in 18s and up
  17. May 10, 2017 at 9:44 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Call Method Wheels! Why are you listening to 4WD and 4WheelParts??? they don't know what they are talking about.
    Here, I'll help you out since you can't seem to pick up the phone and call Method. This link is the Master Parts List for Method.
    Jsena likes this.
  18. May 10, 2017 at 9:45 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Good. Now that thats settled, make whoever you bought the wheels from exchange them for a Method with a 110mm bore
  19. May 10, 2017 at 9:49 AM
    #49
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Looks like Double Standard is not offered in a 17" with a 110mm bore.
    According to the parts list I post, 17" with 110mm bore only models offered are Con6 and Vex
  20. May 10, 2017 at 10:01 AM
    #50
    Voyagermike
    Voyagermike New Member
    California
    Tire rack screwed up.(assuming that's who you got them from) Make them fix it. You just won't be able to get the wheel in a 17. And I guess you'd have to get different tires as well. Call them, let them know what's going on. See what they have to offer. Seems frustrating after spending all that time and money. Make that a point when talking to them and stay calm. Good luck :thumbsup:
  21. May 10, 2017 at 10:06 AM
    #51
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    It's probably your shop's problem. Either they don't have the right equipment, experienced technician, or technician that don't know how to use the equipment. My Discount Tire was able to balance 40" Mickey Thompson MTZ P3s on my 17" Method Race Wheels Double Standards just fine.
  22. May 10, 2017 at 10:42 AM
    #52
    rodriguez2103
    CHARLIE
    Yea I'm done
    TireRack says according to their system they are the correct size so they won't exchange or return especially since they have been mounted. Discount Tire says they are lug centric so they don't need hub rings but acknowledge the fact in the difference in bore size will create vibrations at highway speeds. I'll update later I just refuse to try and sell these wheels off when I know a lot of guys running the exact same set up with no issues.
  23. May 10, 2017 at 10:58 AM
    #53
    TheBeast The Beach
    check the new 17" Icons rims made for the Tundra in case you want to switch
  24. May 10, 2017 at 10:59 AM
    #54
    osidepunker
    Alex
    2013 Tundra DC 4x4
    116mm hub bore on those...
  25. May 10, 2017 at 11:00 AM
    #55
    TheBeast The Beach
  26. May 10, 2017 at 11:04 AM
    #56
    Voyagermike
    California
    Contact method asking them if the wheel will work correctly on your rig. Try to get a response through email and show tire rack IF they respond saying they won't work. Then they sold you the wrong wheel and shouldn't have it advertised to fit. May help.
  27. May 10, 2017 at 11:13 AM
    #57
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The problem is, Methods are technically lug centric. But Methods sell wheels with 110mm bore size which I believe basically makes them hub centric also and those don't seem to have any problems with vibrations. What a lot of people don't realize is even if a wheel is lug centric, they can develop a wobble very easily. Hub rings will fix it most of the time. I didn't realize this specific wheel in 17" doesn't have a 110mm bore, so I guess if you can't return it, next step is to try the hub rings. Hopefully that'll fix it.
  28. May 10, 2017 at 11:27 AM
    #58
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  29. May 10, 2017 at 11:29 AM
    #59
    osidepunker
    Alex
    2013 Tundra DC 4x4
  30. May 10, 2017 at 11:33 AM
    #60
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    LOL, I couldn't open that Master Parts List...
