17 CM SR5 TRD levelling kit
Discussion in 'Suspension' started by matambo, Nov 2, 2017.
  1. Nov 2, 2017 at 7:10 PM
    matambo
    matambo [OP] New Member
    2017 Tundra 4x4
    so im in the process of upgrading my tundra and now considering a leveling kit. i am seeing a lot on eBay but i wanted to get your opinion on which ones you are currently using. what brand and how much it cost. thanks. here is a photo of my truckIMG_4478-3.jpg
    Troy2017TRD, Prostar 190 and CJ21 like this.
  2. Nov 2, 2017 at 7:20 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Price range?
  3. Nov 2, 2017 at 7:27 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I installed Bilstein 6112 coilovers set at 1.9". Perfectly level. About $800. Kind of wish I had just gone 2.5" to see what it looked like. With hood slope it still looks like it has some rake. I could always add a small block or shackle if needed. Just required a little toe adjustment to align. Not sure what the alignment would have been at 2.5".
    matambo[OP] likes this.
  4. Nov 2, 2017 at 7:39 PM
    geno0506
    geno0506 New Member
    Michael
    6112 set at 2.5 without adding my CB Shackles, put 5160's in rear! Had 2 alignments to get it right and is spot on now!
    Troy2017TRD and matambo[OP] like this.
  5. Nov 3, 2017 at 5:07 AM
    matambo
    2017 Tundra 4x4
    thank you for the reply. nice looking truck. so if i buy this set on eBay "https://www.ebay.com/itm/331670386670" its almost the same as your set up- upon install would it level itself automatically or it has to be adjusted by the one installing it to make it level?
    geno0506[QUOTED] likes this.
  6. Nov 3, 2017 at 5:07 AM
    matambo
    2017 Tundra 4x4
  7. Nov 3, 2017 at 5:17 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    So is your truck all stock in this picture, other than wheels? I think is has a great look.
    matambo[QUOTED][OP] likes this.
  8. Nov 3, 2017 at 5:22 AM
    matambo
    2017 Tundra 4x4
    yes sir all stock. thanks. the grill and side mirrors i wrapped with carbon fiber and front tints.
  9. Nov 3, 2017 at 5:32 AM
    butters1975
    butters1975 New Member
    Clarksville TN
    '20 MGM Pro
    What wheels are those and how's the ride with that setup?
  10. Nov 3, 2017 at 6:40 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    If you just want level - which is about 2in the front, I'd buy from Toytec and pay a bit extra to have them shipped assembled. Then you don't need a spring compressor and the install is pretty straight forward.
    http://toyteclifts.3dcartstores.com...es-Front-Shock-Kit-for-2007Tundra_p_1455.html
    The other decent option is 5100s in the front, which folks say firm up the ride a bit. The install is harder though, since you need to dis-assemble the stock parts, change out the strut, while reusing the stock spring. Requires a spring compressor and guts.
    http://toyteclifts.3dcartstores.com...ies-Height-Adjustable-Front-Shocks_p_150.html
    This is a pretty sweet kit, which would be 3in front, 1in rear. But then you run the risk of needing to replace the upper control arms to get the alignment in spec... so they say.
    http://toyteclifts.3dcartstores.com/TTHA-TUN--ToyTecEibach-3-Lift-Kit--07Tundra_p_1828.html
  11. Nov 3, 2017 at 8:14 AM
    matambo
    2017 Tundra 4x4
    this are MB wheels TKO 20 x 9 with Nitto Grapplers 285/55/20. stock ride, wheels are quite as stock.
  12. Nov 3, 2017 at 8:21 AM
    matambo
    2017 Tundra 4x4
    so "just to level the front and the back" i need 2" lift in front and the Bilstein 6112 Series Front Shock Kit lift will do this without a need to replace the control arms to have aa proper alignment?
    what is the matching shock for the rear to reduce bed bounce if you cont mind? want a matching shocks for the looks.
    geno0506 likes this.
  13. Nov 3, 2017 at 8:30 AM
    matambo
    2017 Tundra 4x4
    another question - https://www.ebay.com/itm/-/331670390119? would this set up work without changing the upper control arms would still give me the proper alignment? thanks
  14. Nov 3, 2017 at 8:37 AM
    MistrRoboto
    Virginia Beach, VA
    Your an interesting creature @matambo. Somehow you are asking every question you have twice, but not actually double posting on accident :)
    The item you are referring to is adjustable when disassembled. I don't see in the listing which clip position they are using... whereas Toytec is giving that detail as an option. If your clip is adjusted one from the top, that would be 1.9 inches of lift in the front, which levels you off nicely. At that lift height, the general consensus is you do not need to upgrade the UCAs. If the clip is adjusted to the top setting - you would get 2.5 inches of lift in the front, which would likely be just a bit higher than the rear. At 2.5 inches of front lift, you are nearing the upper control arm grey area, where you may, or may not be able to get in alignment spec.
  15. Nov 3, 2017 at 4:28 PM
    matambo
    2017 Tundra 4x4
    hahahaha this is my first truck and i don't want to get into something that might start something expensive. anyways thank you very much for the very informative reply and hope to ask more questions soon lol. thanks mucho
  16. Dec 10, 2017 at 5:39 PM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    How did you mount the Shackles? What size are they?
  17. Dec 10, 2017 at 5:41 PM
    NFab steps?!?
    geno0506[QUOTED] and matambo[OP] like this.
  18. Dec 10, 2017 at 5:52 PM
    matambo
    2017 Tundra 4x4
    i believe the are 3/4 and the shackles are mounted on "Elevated Suspension Brackets" check them out on Facebook - Elevated Suspension.
    DaBoro54[QUOTED] likes this.
  19. Dec 10, 2017 at 6:17 PM
    geno0506
    geno0506 New Member
    Michael
    yes, I'm changing for AMP power steps soon! If your not careful you can slip on the N-fabs and bust your shins and that hurts like a mofo!
