16-18 Tacoma wheels on 1st Gen Sequoia/Tundra
Discussion in 'Wheels & Tires' started by cashsmoney, Aug 25, 2018.
  1. Aug 25, 2018 at 3:50 PM
    cashsmoney
    cashsmoney [OP] New Member
    Cash
    2018 Tundra Platinum CrewMax
    TRD Duel Exhaust TRD Rear Sway Bar TRD Cold Air Intake To be continued .....
    Has anyone put the 18 Tacoma wheels and tires on a 1st Gen Sequoia or Tundra. I found like new 16 inch wheels and tires from a 2018 Tacoma and want to put them on a 2002 Sequoia 2wd. The bolt pattern is the same but it’s showing the offset is different.
  2. Aug 25, 2018 at 5:55 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    If the sequoia wheels are 16 inches also, you will be ok. If they are 17s, you will need to make sure the calipers clear the new rims.
  3. Aug 25, 2018 at 6:01 PM
    Casper421
    Casper421 Adventure in a 1st gen
    N. Cal
    06 DC
    I’ve seen the 2018 18” Tacoma limited wheels on a 06 Tundra, not sure about the 16’s though.
  4. Aug 25, 2018 at 6:17 PM
    cashsmoney
    Cash
    Yes the the Sequoia has 16” rims now.
  5. Aug 29, 2018 at 7:04 AM
    because_v8
    because_v8 TTC #036
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    3rd gen taco TRD OR wheels, flowmaster 44, LEDs and stickers
    Pretty sure the new tundras and sequoias only have 5 lugs and ours have 6
  6. Aug 29, 2018 at 9:07 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    The rims will fit no problem. I personally would get 17s because there is a gx460/4runner bolt on brake caliper upgrade you can do for larger front and rear rotors. Dust shield replacing or removing may be required.
    You should be able to find cheap new take offs from people off cl.
  7. Nov 28, 2018 at 7:20 PM
    RRobertson
    RRobertson New Member
    I found an excellent deal on 17inch 2019 Tacoma TRD Sport take offs. Can anyone verify that they will fit my 2005 Tundra Quad Cab 4x4 Limited. I currently have the stock 17 inch rims.
