$1500 for new stereo upgrade
Discussion in 'Audio & Video' started by zlaneb, Mar 9, 2018.
  1. Mar 9, 2018 at 8:37 AM
    zlaneb
    zlaneb [OP] New Member
    Austin, TX
    Gents and Gals - I have $1500 I want to invest in an upgraded sound system for my 17 CM. I don't need navigation (never used it after day 1) and I don't need a CD player. I want to replace the HU, Amp, speakers and add a sub. Additionally I want:
    1. Bluetooth (obviously)
    2. Decent bass (I' want some thump)
    3. Maintain steering wheel controls
    4. Behind the backseat sub
    5. Speakers to support and a new amp
    6. Fit in the dash, no cutting
    Nice to have:
    Input from tundra 'brain' to the head unit (gauges, MPH, Temp ect)
    Apple Play
    Tell me what you have and if you like it!
  2. Mar 9, 2018 at 8:39 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Check out *********.com complete plug and play systems minus the head unit.
    zlaneb[OP] and aperezsh like this.
  3. Mar 9, 2018 at 8:48 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Kenwood head unit. Several of us have the 994S which does have navigation, but they make some without the nav. You can then utilize the Maestro module to retain 95% of the functions of the factory head unit and steering wheel controls.
  4. Mar 9, 2018 at 8:50 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You doing the install yourself or having a shop do it?
    zlaneb[OP] likes this.
  5. Mar 9, 2018 at 12:09 PM
    zlaneb
    Austin, TX
    Totally do it at a shop.
  6. Mar 9, 2018 at 12:30 PM
    Danimal86
    Daniel
    Sacramento, CA
    that's probably going to be a tight to get an entire overhaul for $1500.
    zlaneb[QUOTED][OP] and Y0TA PR0 like this.
  7. Mar 9, 2018 at 2:23 PM
    zlaneb
    Austin, TX
    I haven't
    I haven't upgraded a stereo in years so I don't really know cost. I guess I will start at 1500 and shoot for an affordable solution.
  8. Mar 9, 2018 at 2:24 PM
    zlaneb
    Austin, TX
    You guys adding a sub with the unit? if so, any recommendations?
  9. Mar 9, 2018 at 2:28 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    oemaudioplus.com run it in my truck and couldnt be happier. complete plug and play and everything looks like stock. keep your original head unit and everything else is new.
  10. Mar 9, 2018 at 2:32 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    $1,500 is pretty tight, but doable if you keep the facotry HU. A decent HU is going to eat a big chunk of your budget. Here’s the breakdown of my system (I kept the facotry HU):
    OEM Entune non-JBL w/ Nav
    Audio Control LC7i ($130)
    JL XD1000/5v2 amp ($830)
    Alpine Type-R SPR-60C 6.5" Components (front) ($330)
    Alpine Type-R SPR-60 6.5" Coaxials (rear) ($230)
    JL 10" TW3 subs x2 ($300/ea)
    Audio Enhancers dual 10 box (sealed)
    Hushmat for doors ($50)
    **waiting for audio control bass knob to arrive ($25)
    Total for parts: $2,195 + speaker box (I don't remember this cost)
    Tundy Chuck and aperezsh like this.
  11. Mar 9, 2018 at 3:15 PM
    Danimal86
    Daniel
    Sacramento, CA
    Op could do the same but go with something less expensive for the amp like the pioneer d9605 (around $250) and find some front and rear speakers for around $125/pair, and go with a single 10tw3 (or something cheaper like a Rockford Fosgate).
    That would leave $400 for a head unit. assuming you are going to install everything yourself.
    i believe it was @smooosh that did a great write up on the maestro integration kit showing what you gain/loose with going aftermarket
  12. Mar 9, 2018 at 6:01 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Do you have the factory JBL system. It's more expensive to upgrade that as far as I know, but maybe thats only if you keep the factory HU
  13. Mar 9, 2018 at 6:13 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    If you look at my build page you will see i did a pair of Rockford Fosgste P3 10’s in a port enclosure behind the back seats. Box is just over 1.6 cubic feet. Think the subs were around 180 a piece. I would image a single 10 would be fine unless you are a bass head like me! :headbang:
    Black Wolf and Pudge like this.
  14. Mar 9, 2018 at 6:16 PM
    Black Wolf, Kwikfish and aperezsh like this.
  15. Mar 9, 2018 at 6:21 PM
    Pudge
    CT
    Send @BOOMHAUER@TECH12VOLTS a PM or tech12volts an email. They will steer you in the right direction. And they are very realistic as to what can and can not be done within your budget.
    Black Wolf and Cfincke like this.
  16. Mar 9, 2018 at 6:22 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    If you do the kenwood dnx994s with maestro and the connects to retain ur factory xm and gps antenna then u lost a huge chunk of ur spending cash. I spent about 1200 on mine.
    Y0TA PR0, aperezsh and Pudge like this.
  17. Mar 9, 2018 at 6:24 PM
    Cfincke
    San Antonio
    This!
  18. Mar 9, 2018 at 6:26 PM
    Pudge
    CT
    You could always buy a Harmon cadence amp for $100. I hear that's really all you need
    JoeJob, AKJ78, Newm and 5 others like this.
  19. Mar 9, 2018 at 6:26 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Yep good people there thats where i purchased mine. Prewired so basically plug and play.
    Pudge and Cfincke[QUOTED] like this.
  20. Mar 9, 2018 at 9:58 PM
    ZPMAN
    Minnesota
    On your cell phone do you have unlimited data and tethering? Then I would get a Phoenix Tesla head unit, the sound improvement over stock unit is way bettor with only stock speakers and my boys love watching you tube music videos.
    Google maps
    https://youtu.be/RgGiBogrA9c
    https://youtu.be/TmLjFFufMQk
    darkknight2014 and iHacker like this.
  21. Mar 9, 2018 at 11:40 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Ha! I see what you did there.
    Pudge[QUOTED] and Black Wolf like this.
  22. Mar 10, 2018 at 12:40 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    What part did you purchase to use your oem gps antenna on your Kenwood?
  23. Mar 10, 2018 at 5:18 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
  24. Mar 10, 2018 at 5:25 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Also i love that when i plug my note8 into my unit andriod car play pops up and i get the option for google or waze navigation plus different music source options and also just say ok google and the truck will talk to u lol.
    BlueBottle likes this.
  25. Mar 10, 2018 at 5:31 AM
    Adam New Member
  26. Mar 10, 2018 at 5:32 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
  27. Mar 10, 2018 at 5:40 AM
    Rica25
    Ricardo
    Tulare
    You have pics
  28. Mar 10, 2018 at 5:41 AM
    War Machine
    War Machine SSEM # 5 3MW
  29. Mar 10, 2018 at 6:03 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    You can get a Pioneer 4200 or 4201 nex in the 300s after rebate, I've seen the 8200 for $550 recently too
  30. Mar 10, 2018 at 6:28 AM
    Vendeta2k
    Jay
    Bozeman, Montana
