14 Tundra TSS. P0303 misfire, #3 compression issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by 68Bird, Jun 25, 2019.
  1. Jun 25, 2019 at 9:09 AM
    68Bird
    68Bird [OP] New Member
    2014 Tundra TSS
    Hey Guys first time posting and I have researched but don't see anything quite like my issue completely!
    I will run thru this step by step of what happen.
    filling up with fuel (truck running) pulled away from pump and left idling (air on for dog) I returned to truck about 20 min. later and it was idling rough and check engine light flashing. I read codes and came up with P0303. not having much time to diagnose I just purchased a coil pack, sparkplug and replaced. reset computer and started, it ran smooth for about 30-45 sec. then the check engine light came back on and started running rough. I now decided to check the injectors, not having a pulse reader I pulled fuel rail and swapped #1 injector with #3. same problem when put back and started. I now thought I better check compression, here is where it gets weird. first time I pulled compression test #3 read 40..... I put it back together and checked compression in #1 and got 168. I decided to retest #3 a few times to make sure of operator error.... next time before I checked compression I reset the computer, and compression was 165! I hit the release on comp. tester to make sure it read it correct and pressure would not rebuild!!! pulled comp. tester and tried again not resetting computer and I get no reading of compression?!?!?! started truck with cylinder open and get what seems like good intake and exhaust pushing and sucking thru spark plug hole BUT that's just a guess with my hand over the hole...
    So I have had the truck towed to Toyota and after 1 day they have no answers yet?? I know im impatient but I like to understand everything completely! dealer also says they put a scope in cylinder and it looked good??
    truck has 76000 miles on it. I have a lifetime engine warranty but am worried this may be a computer issue that would not be covered!
    has anyone encountered anything like this??
  2. Jun 25, 2019 at 9:54 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Following for more info, my 2014 is almost 73k miles trouble free, not an issue but hanging around to see the fix for your problem. I hope you can get it figured out and it’s not too expensive of a fix.
  3. Jun 25, 2019 at 4:27 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Broken ring(s) in #3? Compression in a normal cylinder doesn't vary wildly like that.
    If it's the rings, everything may look normal using a borescope through the sparkplug hole. Oil squirted into the cylinder for the compression test could be revealing.
    14burrito likes this.
  4. Jun 26, 2019 at 4:29 AM
    68Bird
    2014 Tundra TSS
    So I stopped by and talked with the tech working on it and they think they have narrowed it down to the ECU not providing a pulse to the #3 injector.
    he says compression is good SO maybe I didn't get a good reading in the Auto Zone parking lot with rented gauge LOL. At least the ECU is warrantied for 8yrs or 80K
  5. Mar 24, 2021 at 3:39 PM
    Langdontd
    Langdontd New Member
    2010 tundra
    None
    I'm having the exact experience with my 2010. A few more miles @ 240000
    I'm very curious what they come up with, my next move is the shop. I was leaning towards an ecu issue. the previous owner deleted the egr. I'm assuming to bypass the air injection pump instead of paying for the costly pump replacement. I was wondering if that would have anything to do with it. Idk...?
  6. Mar 24, 2021 at 3:51 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    P0303
    Replaced coil and plug #3 = issue still in 3
    Swapped inj between 1 and 3 = issue still in 3
    Compression test value = low
    Do I understand correctly?
    As @JohnLakeman mentioned,
    Some oil in the cylinder + test = compression = rings
