13WL Brake Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Eugene406, Apr 11, 2019.
  1. Oct 28, 2021 at 3:10 PM
    #121
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    All I can tell you about is what I've done and installed. Can't tell you anything about 14WAs other than I don't have an interest in them. Have you read through the dedicated thread? https://www.tundras.com/threads/2000-2006-tundra-big-brake-upgrade-kit-14wa-calipers.61231/
    Be the guinea pig and report back on it if you're interested in this stuff... kind of like I'm doing in this thread.
    The cheap 17" wheel rotors appear to be one piece. The expensive options are all two-piece rotors.
    Lil Steve and daveeasa[QUOTED] like this.
  2. Oct 28, 2021 at 3:14 PM
    #122
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    des2mtn[QUOTED] likes this.
  3. Oct 28, 2021 at 9:29 PM
    #123
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Never ask you why you would have not done the 14wa conversion?
  4. Oct 28, 2021 at 9:41 PM
    #124
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    hes been fighting a soft pedal ever since
    daveeasa likes this.
  5. Oct 28, 2021 at 9:43 PM
    #125
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I have read that is very rare, now that I'm thinking I have read that he's tried everything possible but not sure if he changed his M/C.
    Talking about M/C your doing the Sequoia conversion from SOS correct? What are you doing about the booster?
  6. Oct 28, 2021 at 9:45 PM
    #126
    empty_lord
    05 rollover special
    booster is staying stock. adapter for sequoia master.. then my old master thats barely 2 years old fits my tacoma so its going on the 2002.
    @FirstGenVol replaced his master with a new OEM unit.
  7. Oct 28, 2021 at 9:46 PM
    #127
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Do you think a T100 booster with the Sequoia M/C will be better? Is the Sequoia booster the same as ours?
  8. Oct 28, 2021 at 9:48 PM
    #128
    empty_lord
    05 rollover special
    t100 booster will not bolt up to the sequoia setup without a custom adapter no one makes. plus it will make finding parts harder if you go t100 since that trucks newest model is damn near 25 years old now.
    des2mtn likes this.
  9. Oct 28, 2021 at 9:57 PM
    #129
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Ok im sure It be good with normal booster. My plan is 14wa, EBC slotted rotors orange pads and SOS Sequoia M/C. Down the road rear disc
  10. Oct 28, 2021 at 9:58 PM
    #130
    empty_lord
    05 rollover special
    dont waste your money on the master until you do rear disc. the circuit is setup different and would likely make the brakes feel worse if the drums are still on
    des2mtn likes this.
  11. Oct 28, 2021 at 9:59 PM
    #131
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Shit ok so are you saying don't do the 14WA ethier snice I can't upgrade the M/C?
  12. Oct 28, 2021 at 10:00 PM
    #132
    empty_lord
    05 rollover special
    that one is up to you. some have soft pedals some dont. its luck of the draw
  13. Oct 28, 2021 at 10:04 PM
    #133
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Go figure that's a risky decision, most likely going to wait as my WL are hold up pretty good. Just trying to put a part list together so I can have everything ready. So I have the front covered know how to see about the rear.
  14. Oct 29, 2021 at 10:14 AM
    #134
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Personally I'd wait on the 14WA until you are having problems. If the 13WL are working ok for you then I'd stick to that. Why open up a can of worms that may lead to future problems.
    Rotors and pads are cheap enough that even if you had to replace them every two years, that's still the cost of two tanks of gas for these trucks.
    Also, don't know if mentioned this before, but make sure the rears are working well and LSPV is set. Then try that. I don't tow, but I have been happy enough with he brakes on my 01 and 06 tundras. They're not as good as a new car, but they work and stop me just fine.
    Punk1974, SouthPaw, Lil Steve and 2 others like this.
  15. Oct 29, 2021 at 10:16 AM
    #135
    des2mtn
    SW
    Tonto cover
    Probably some of the best advice on this thread so far.
    Punk1974 likes this.
  16. Oct 29, 2021 at 10:28 AM
    #136
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Thank you so yea they are ok not perfect, they feel spongy and not firm. The rear brakes should be adjusted good. I have to check the LSPV as that I'm sure is not right. Parking brake works perfectly. I also have stainless brake lines. Next I'm doing is changing fluid.
  17. Oct 29, 2021 at 10:43 AM
    #137
    daveeasa
    David
    Pads are cheap if you accept lower standards than Dan the Man with the orange compound band.
    FWIW, I should have some completely brand new (possibly installed and then removed) 13WE stoptech sport pads once the 13WL calipers arrive and get swapped out. And some calipers too for that matter, though who would bolt on 13we calipers instead of 13wl I don't know. Just in case someone wants the pads, assuming I cannot use them on the Tacoma.
  18. Oct 29, 2021 at 10:45 AM
    #138
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    That's was my plan EBC orange pads and rotors.
  19. Oct 29, 2021 at 11:01 AM
    #139
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yep. I seriously regret fucking with it. Worst thing I've done.
  20. Oct 29, 2021 at 11:02 AM
    #140
    daveeasa
    David
    Yeah, so, premium rotors and those $200 pads, we're beyond a couple of tanks of gas, right? Unless my back-o-envelope math is off?
  21. Oct 29, 2021 at 11:36 AM
    #141
    Dave8699
    Dave8699 Trackrat
    David
    NJ
  22. Oct 29, 2021 at 11:48 AM
    #142
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Ok so im back to the drawing board most likely I guess I'm going to stay with the WL and do the rear disc conversion and Sequoia M/C. How reliable will that combination be?
    des2mtn likes this.
  23. Oct 29, 2021 at 6:01 PM
    #143
    des2mtn
    SW
    Tonto cover
    There is no exact answer to that question. I have no regrets on adding discs and the MC to my truck. The truck hasn't blown up on me or gave me any issues since install so I guess it's reliable?
    @Dave8699, I mean this in the nicest way possible, but a lot of the questions you're asking about, you'll have to find out for yourself, as in no one has an exact answer. The disc conversion and 14WA is unknown territory for 90-95% of people. I wouldn't trust my own answers I'm giving you as sacrosanct as I'm not a Toyota tech.
    I did my disc conversion pretty much blind without any step-by-step instructions. Sure, I came on here and asked for help in some cases, such as diagnosing whether the MC piston rod was too long, but I knew from the beginning a lot of this work was going to rely on my own knowledge and abilities.
    Dave8699, FirstGenVol and daveeasa like this.
  24. Nov 1, 2021 at 8:22 AM
    #144
    rock climber
    Sorry if you already mentioned this, but what's the end goal? Are you having problems with your current set up?
  25. Nov 1, 2021 at 8:27 AM
    #145
    rock climber
    Yeah, but I'd hope with that set up you'd get more than a few years :)
    I was meaning more with decent $60 rotors and $50 pads. The EBC greenstuff pads are $80, the Hawk LTS are $70, Akebono premium are $60 and the powerstop are $40.
    On a side note, has anyone gone from 13WE to 13WL and had a mushy pedal? In theory it shouldn't because the piston is the same size, just the caliper is larger to accommodate larger pads
    daveeasa[QUOTED] likes this.
  26. Nov 1, 2021 at 8:36 AM
    #146
    daveeasa
    David
    I’ll let you know if I get mushy pedal with the 13WL’s.
    I didn’t realize the greenstuff was so much less than orange. Go figure. Maybe I’ll get the green ones after all. Or maybe be I should just get orange. Hah. 3 sets of new brake pads and none fit the Tacoma, at least I’ll have a backup set ready.
  27. Nov 1, 2021 at 8:45 AM
    #147
    rock climber
    The yellow aren't terrible, it's the orange that jump in price :eek2:
  28. Nov 1, 2021 at 8:48 AM
    #148
    empty_lord
    05 rollover special
    You only want orange if your towing near capacity a lot.
  29. Nov 1, 2021 at 10:38 AM
    #149
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    So I have no problems but I do have that feeling that if I have to slam on the brakes it takes a while to stop. My end goal is to have as close as possible to newer truck brakes.I have WL and decent shape rotors with I believe its green pads but not sure completely.
    I only tow in the summer around 5500 - 5800lb.
  30. Nov 1, 2021 at 10:58 AM
    #150
    daveeasa
    David
    OK, I took a stroll through buybrakes.com for 13WL pads:
    Greenstuff $90
    Yellowstuff $156
    Orangestuff $187
    Stoptech $82
    Rock Auto:
    Power Stop $33
    Summit:
    Green 6000 $95 (EBC-DP61657)
    Yellow 4000 $165
    Orange $197
    Another Green for $136 (EBC-DP71657)
    I think I may be just as unsure as before, hah. I'm sure pad material impacts performance, just not sure without trying all of these to know how to measure value compared to price...
