13WL Brake Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Eugene406, Apr 11, 2019.
  1. Sep 23, 2021 at 9:09 PM
    #61
    Ciafre
    Ciafre New Member
    I have a 2000 4runner and one popular upgrade is the 1st gen Tundra brakes. I purchased the Z36 kit from Rock Auto linked here: https://www.rockauto.com/en/moreinfo.php?pk=3803118&cc=1357938&pt=13824&jsn=437
    My question is, if I purchased OEM spec/remaned WL calipers, will they work with these pads and rotors? The kit listing on Rock Auto says "With Front Caliper Casting # 13WL" but I wanted confirmation that any WL calipers should fit with this kit.
    Also, which year Tundras had the WL calipers? I plan to go to Napa or another store and simply buy a set by telling them what year truck.
    Thanks for the help and sorry for reviving this thread after 16 months!
  2. Sep 24, 2021 at 2:01 AM
    #62
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    I believe that mid 2003-2006 had the WL caliper.
    KNABORES likes this.
  3. Oct 20, 2021 at 11:32 AM
    #63
    daveeasa
    David
  4. Oct 20, 2021 at 11:42 AM
    #64
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
  5. Oct 20, 2021 at 11:44 AM
    #65
    daveeasa
    David
    I am definitely not in a rush. I would be stoked to do some recycling. I'm guessing I would likely need to purchase new pads? Let me know how best to compensate you for time/shipping/value?
    Cheers!
    assassin10000[QUOTED] likes this.
  6. Oct 21, 2021 at 6:53 PM
    #66
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    So what I learned from this thread is 04 tundra have the WL calipers and any year before came with WE I'm I correct?
    So the best caliper you can fit in our trucks are WL.
    What are guys doing about converting rear to disk?
  7. Oct 21, 2021 at 7:43 PM
    #67
    Sequoia?
  8. Oct 21, 2021 at 9:18 PM
    #68
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I'm referring to tundra
  9. Oct 22, 2021 at 4:07 AM
    #69
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, the sequoia has disks, and is the source. I think @des2mtn has the swap.
    des2mtn and shifty` like this.
  10. Oct 22, 2021 at 4:33 AM
    #70
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Is there a write up on the conversion or any feed back? Is the booster and master cylinder big enough?
  11. Oct 22, 2021 at 8:34 AM
    #71
    Thanks for that, @bmf4069
    In theory, booster and MC should be big enough but any time you upgrade from drum/disc to all-disc you need to change or adjust the prop valve to compensate for needing different clamping force (unsure if LSPV can be adjusted to compensate). Then again, you may be able to source the prop valve from the donor vehicle, since the chassis is virtually identical.
  12. Oct 22, 2021 at 9:49 AM
    #72
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Darkness likes this.
  13. Oct 22, 2021 at 10:02 AM
    #73
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If I had known what I know now, I would have never gone with 14WA calipers and would have upgraded to 13WL....
    SouthPaw, bmf4069 and shifty` like this.
  14. Oct 22, 2021 at 10:10 AM
    #74
    Dave8699
    Dave8699 Trackrat
    David
    NJ
  15. Oct 22, 2021 at 10:04 PM
    #75
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    uh... i TOTALLY wouldnt be opposed to uh.. buying the WA calipers off you... since im going to be doing rear disc and swaping master anyway....
  16. Oct 23, 2021 at 3:24 AM
    #76
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    What rear disc setup are you planning on doing and also what master ?
  17. Oct 23, 2021 at 8:42 AM
    #77
    empty_lord
    05 rollover special
    Same as @des2mtn sequoia master with SOS rear brake brackets and cables + their master adapter
    bmf4069 likes this.
  18. Oct 23, 2021 at 9:07 AM
    #78
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Did @des2mtn do a write up ? I searched his profile but didn't see anything.
  19. Oct 23, 2021 at 9:44 AM
    #79
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    No write up. If I get some time, I'll try to share some of my experience. If you're on your original axle seals and bearings, this will be the time to do those too.
    bmf4069 likes this.
  20. Oct 23, 2021 at 9:58 AM
    #80
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    That would be great if you had some part numbers also. I definitely would change the axle seals and bearing snice they are original.
    Also what caliper do you have in the front, did you use 13WL or 14WA?
    Did you do anything with the LSPV when you converted? I was thinking in using a Wildwood proportioning valve what's your thoughts?
  21. Oct 23, 2021 at 4:04 PM
    #81
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did both of yall use the sos kit? It seems pretty straight forward. But that price tag, ouch.
  22. Oct 23, 2021 at 5:12 PM
    #82
    empty_lord
    05 rollover special
    I bought a used set. (We’ll never installed)
    bmf4069[QUOTED] likes this.
  23. Oct 23, 2021 at 5:16 PM
    #83
    des2mtn
    SW
    Tonto cover
    I didn't buy all the parts from him. I did purchase it when it specifically was on sale, on top of a black friday sale though.
  24. Oct 23, 2021 at 5:18 PM
    #84
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    This definitely feels like we need a 1st gen drum to disc conversion sticky with some part numbers of oem and aftermarket parts.
    Tundra2 likes this.
  25. Oct 23, 2021 at 5:19 PM
    #85
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Just curious why you want with the Sequoia M/C instead of the T100 mc and booster?
  26. Oct 23, 2021 at 11:24 PM
    #86
    empty_lord
    05 rollover special
    t100 was never offered with rear disk. the sequoia m/c was. it just plays nicer with large pistons in the rear.
  27. Oct 24, 2021 at 4:19 AM
    #87
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Got it so I'm assuming 13WL and rear conversion is enough braking power no need for 14WA? Also how about the LSPV delete and add wildwood PV.
  28. Oct 24, 2021 at 6:30 AM
    #88
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So the other option for rear disks is buy a sequoia axle, take it and your axle to a competent welder, tell them "I want these leaf spring perches in place of the coil spring perches", then replace the axle?
    des2mtn likes this.
  29. Oct 24, 2021 at 7:02 AM
    #89
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I would figure that would be alot more work or no?
  30. Oct 24, 2021 at 7:17 AM
    #90
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    I have installed several of these kits on my vehicles . 1995 T100 4x4 - 2002 Sequoia 4x4 and at the moment waiting for the rotors for my newest toy 2009 Infinity FX50 S
