13WL Brake Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Eugene406, Apr 11, 2019.
  1. Oct 7, 2019 at 10:05 PM
    Aerindel
    Aerindel New Member
    Montana
    The original idea to vent gases given off by brake pads so they couldn't keep the pads from making contact with the rotors while hot, but it modern pad materials don't off gas like that.
  2. Oct 8, 2019 at 2:10 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    The kit seems to be quite a bit cheaper at Rock Auto.
    Also, there are less expensive options for ceramic pads (vs ceramic/carbon fiber... if that's even a thing). And standard, not drilled & slotted rotors.
    Worth noting.
  3. Oct 8, 2019 at 5:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wonder why mine have not warped. I hear it happens frequently on the early years. The previous owner had a brake job done right before he sold the truck.
    How many miles are you guys getting out of your pads? I'm approaching 30K on this set.
  4. Oct 8, 2019 at 5:36 AM
    Aerindel
    Aerindel New Member
    Montana
    Well, I have a theory that its because people let the rear brakes get out of adjustment and the front brakes get over worked but its just a theory at this point.
  5. Jan 14, 2020 at 3:38 PM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    It looks like you installed this kit a while ago, any review on the product? My rotors have been warped since i bought the truck and I'm trying to figure out the best route of replacement parts
    Mid-Atlantic Slots likes this.
  6. Jan 14, 2020 at 3:55 PM
    Eugene406
    Eugene406 [OP] New Member
    Montana
    2002 Toyota Tundra SR5 TRD
    Bone Stock.
    No complaints. Rotors are still straight, even with the larger tires. I pull a drift boat frequently (hardly any weight), but no issue slowing her down.
  7. Jan 14, 2020 at 3:56 PM
    Whothefat
    Clark
    Las Vegas
    Awesome thanks for the reply!
  8. Jan 16, 2020 at 12:59 PM
    Professional Hand Model
    Hand Protectors
    2002 Tundra V8 here. Drove with original warped rotors until last year. Had front end rebuilt and they also installed new rotors and pads.
    Around that same time I discovered about the RLSP Valve adjustment to make my rear brakes take on more braking power. My adjustment was bottomed out (from factory?) until I raised it about mid-way up.
    Both of these changes made the truck stop substantially better.
    Next good adjustment was at the rear drums where my parking brake cables were mis-installed by others in the past brake service. These cables were put back into their proper slots such that the shoes now adjust themselves properly.
    Final boost to better braking was actually bleeding the lines with fresh DOT3. They hadn’t been done in about 5 years. Pictured dirty fluid was from front passenger caliper.
    bmf4069 likes this.
  9. Jan 16, 2020 at 1:42 PM
    Whothefat
    Clark
    Las Vegas
    Awesome info! Did you go with OEM rotors and pads?
    That service is definitely due on my truck. My pedal is mushy unless I pump it once then it feels as it should.
  10. Jan 16, 2020 at 2:53 PM
    Hand Protectors
    Not sure of the brand, but they weren’t OEM. Holding nicely with no warp in a years worth of driving (14k miles).
  11. Jan 16, 2020 at 3:22 PM
    Hand Protectors
    Opps. Forgot to mention I have the WE calipers, not the WL (larger).
    Still have all the OEM brake lines, as well. Nothing has been upgraded other than the above mentioned minor adjustments. Brakes real nicely.
  12. Jan 17, 2020 at 4:46 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    I did the same big brake upgrade 2 years ago, 2000 up to a 2006, just went with Beck Arnley Reman calipers and Stoptech drilled/slotted rotors, Akebono pads, steel lines. . From personal experience, the stop is much better than before, like holy shit much better. No more brake issues like the old set up. The older stock reman calipers and rotors I installed about 7 years ago went to shit. The Rotors seemed to start warping after 3 years. So while your sitting there at a stop light after a heavy stop and the heat from the pads has nowhere to go warping your rotor.............well, I'll stay with my slotted drilled rotors, which by the way are much bigger than the 2000.....well there is my surface area. Best upgrade I did so far. All new drums, shoes and hardware in back as well.
    DarkMint likes this.
  13. Jan 17, 2020 at 5:01 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I just did this kit from rockauto. Requires a little trimming of the dust shield to clear the new calipers but was pretty straight forward. If you do this and have nasty brake juice be sure and bleed BEFORE you swap so as not to contaminate your shiny new calipers. And of course bleed after as well to get rid of the air...
    Heres what I did: https://www.tundras.com/threads/front-brake-job.41227/
  14. Jan 17, 2020 at 5:19 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    No trimming shields for me....................there's a reason I didn't go with Powerstop, let me know in a couple years.
  15. Jan 17, 2020 at 5:21 AM
    Hand Protectors
    I feel a brake war heating up!
    :stirthepot:
  16. Jan 17, 2020 at 5:35 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Whatever happened to Marbles? Did you run him off?
    TX-TRD1stGEN likes this.
  17. Jan 17, 2020 at 5:37 AM
    Hand Protectors
    Not sure, but I thought we had made up and were now friends?
    Last I heard, he and his neighbor were doing his timing belt job. Hope he is ok!
  18. Jan 17, 2020 at 6:27 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did you go from WE to WL calipers?
  19. Jan 17, 2020 at 1:37 PM
    #49
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    His twin showed up :eek2:
  20. Jan 18, 2020 at 6:33 AM
    #50
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    I'm a lover, not a fighter....you get what you pay for, I would rather have the powerstop big brake up grade than the original. I just paid twice as much for a different company. Also keep in mind I've been working on Imports for 30 years and have become loyal to certain companies.
  21. Jan 30, 2020 at 2:55 PM
    #51
    Hand Protectors
    Looks like I’m slowly reaching Brake Nirvana on the 2002. I’ve ticked all the boxes so far with small improvements at each accomplishment and the last box to tick next week will be this 13WL install.
    So far, in sequential order, the boxes ticked are:
    1) Load Sensing Proportional Valve adjust up. Very easy and free improvement. Noticeable too! Do it!
    2) Parking brake cables adjustments. This one was a little frustrating, as I worked through the specs but didn’t check the inside drum area to notice prior brake service mechanic didn’t loop inner cable in its slot. Once I discovered this, the parking brake puzzle was solved. Works like a champ now. Do it. Cheap!
    3) Brake Fluid Flush with DOT3. Made the pedal feel real solid. Cheap and easy. Do it!
    4) Flexible Braided Brake Hose install. Eh. Pedal feels ‘more evenly distributed’ in pressure throughout the press. Same braking distances. Just a differing feel at pedal. Less soft to hard feel pre-install. More medium pressure press throughout post-install. Worth it if you want to blow $100 for small gains. Items 1-3 above blow my skirt more than this #4. If anything good came from me doing this it was to notice my 13WE calipers had tears in the rubbers which leads me to #5.
    5) This pending 13WL upgrade. Review pending until next week post-install. Really hoping for great results based on this thread. I’ll be keeping my one and a half year ‘non slotted/non drilled’ newer rotors. Going with the Tow Brake Pads which are a ceramic/graphite combo.
    DarkMint, theblurry1 and bmf4069 like this.
  22. Feb 16, 2020 at 6:43 AM
    #52
    Hand Protectors
    Edit to post #51 above.
    Installed the 13WL calipers and re-bleed brakes with Bosch DOT5.1 brake fluid. Truck is braking better. The stops are more powerful and better controlled than the old WE13 calipers.
    The oldies with 3 of 4 frozen pistons.
  23. Apr 28, 2020 at 6:59 AM
    #53
    ZacFromCleveland
    ZacFromCleveland New Member
    Zac
    Powerstop buyers, what issues have you run in to long term? I was going to buy the WL kit from Amazon, but there were too many negative reviews with issues on the calipers.
    Full disclosure, I have a 1997 4Runner but the 1st gen tundra brake calipers bolt directly on to the 3rd gen 4Runner. Trying to get info on the brakes from guys who’ve used them on the heavier trucks.
  24. Apr 29, 2020 at 10:11 PM
    #54
    Blueranger501
    Blueranger501 New Member
    What year did they start doing 13WL calipers? And is the gx460 upgrade even bigger calipers? I know it’s a bigger rotor...
    Mine is an 04 AC. I have performance rotors, pads and stainless all around. Looking for more with the 35s and don’t feel like shelling out for the big brake kit.
  25. Apr 30, 2020 at 2:44 AM
    #55
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Mid 03 was the upgrade so you should have the 13WL. The gx460 brakes (14WA) are larger. Below is a quick spec list in differences. Also a link from someone upgrading 13WG (same specs as WL's) and their testing. They picked up about 4 ft from 61/62 to consistently 57' braking from 40mph. I went from 13WE which are the smallest/weakest to 14wa and it was a good upgrade!
    https://www.tacomaworld.com/threads...unner-bbk-upgrade-for-2nd-gen-tacomas.504234/
    13WL
    Caliper Size - 11-5/8" Inch
    Rotor Size - 318.7mm
    Rotor Thickness - 28mm
    Rotor Weight - 20.48 lbs
    Brake Pad Size -
    Piston Size - 45mm
    Wheel Size - 16"- 17"
    14WA
    Rotor Size - 338mm
    Rotor Thickness - 31.8mm
    Rotor Weight - 21.7 lbs
    Brake Pad Size -
    Piston Size - 48mm
    Wheel Size - 17"
    FirstGenVol and bmf4069 like this.
  26. Apr 30, 2020 at 11:32 AM
    #56
    will the 14WA bolt up and fit the 1st Gen Tundra?
  27. Apr 30, 2020 at 1:45 PM
    #57
    imDementeD
    You need to mill 3.5mm off the "ears" on the inside and then the rest is bolt-on.
    speedtre likes this.
  28. Apr 30, 2020 at 9:14 PM
    #58
    Blueranger501
    Very helpful thank you!
  29. May 1, 2020 at 9:38 AM
    #59
    could I mill them with a grinder, er should I is more appropriate.
  30. May 1, 2020 at 9:57 AM
    #60
    imDementeD
    You want a flat surface. The machine shop I took them to charged me 30 bucks each and took less than an hour.
    You don't want uneven mounting on your calipers.
