13WL Brake Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Eugene406, Jan 29, 2019.
  1. Aug 7, 2023 at 10:43 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    You're a little higher than mine.
  2. Aug 7, 2023 at 10:54 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Thanks for reference. Going to try a hair lower. The emercency break re-set also did trick auto adjusting the parking brake. So any others....I think it was 7 clicks down 5 times in a row to reset manual adjuster.
    Eddie's XSP X likes this.
  3. Aug 8, 2023 at 5:34 AM
    Your e-brake cable looks a little loose there.
    Weagle likes this.
  4. Aug 8, 2023 at 6:33 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    aint no reason to be gawkin' my flacid cable. It'll work when i need it to.
    Weagle, bmf4069 and FirstGenVol like this.
  5. Aug 8, 2023 at 6:38 AM
    You were danglin’ it in our faces. I tried not to see it also, but human nature got the best of me. Next thing you know I was pinching to zoom and scrolling and oh man, back down that rabbit hole. I started googling other flaccid cables and now I just sit here with my shame.
    Weagle, bmf4069, shifty` and 2 others like this.
  6. Aug 8, 2023 at 7:11 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Jack McCarthy, bmf4069 and shifty` like this.
  7. Aug 8, 2023 at 10:33 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Jack McCarthy likes this.
  8. Aug 8, 2023 at 5:34 PM
    BluegrapeVr6
    J
    Too funny
  9. Aug 8, 2023 at 6:00 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Has a stormtrooper tried backing your truck under a trailer?
  10. Apr 20, 2024 at 8:24 PM
    andyman0369
    andyman0369 New Member
    Nashville
    2002 Limited AC, RWD
    Bone stock w/ 210k miles
    TSB for the upgrade to 13WL [TSB BR004-02] shows PNs 47710-0C022 and 47720-0C022 for the OE Calipers, which, of course are discontinued. Anybody have alternate OE PNs or suitabe aftermarket calipers?
    I'd prefer OE, the originals (13WE) made it to 210k in 22 years, so they can't be but so bad. I won't put those back on it though.
    I'm open to something else but don't want to piecemeal too much, helps me remember what replacement parts to get... think Johnny Cash's "One Piece at a Time"
  11. Apr 20, 2024 at 9:28 PM
    Powerstop kit. comes with the new calipers in red and new rotors and pads.
    https://www.carid.com/sf-pl-mpn/pid...heaatbJ77Yr26SHdQSxoCCrYQAvD_BwE&gclsrc=aw.ds
    RickM, Weagle and The Black Mamba like this.
  12. Apr 21, 2024 at 8:15 AM
    You provided zero details about your truck or situation, so it's really hard to help out here...
    I'm finding a couple of sites showing stock of the part you entered, so it may just be reaching EOL. But the current part number for the 13WL is 47730-0C022 and 47750-0C022. If you want reman units, 47730-0C022-84 and 47750-0C022-84.
    AmericanKing06 likes this.
  13. Apr 21, 2024 at 7:30 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
  14. Apr 22, 2024 at 4:34 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
  15. Apr 24, 2024 at 6:12 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Weagle and KNABORES like this.
  16. Apr 25, 2024 at 9:16 AM
    RickM
    RickM New Member
    Rick
    NE Texas
    01 Tundra TRD Limited
  17. Apr 25, 2024 at 9:22 AM
    Is the parking brake 100% functional and dialed in correctly? If not, that is 100% your likely issue. It is so well known, there’s an entire sticky thread dedicated to it.
  18. Apr 25, 2024 at 9:25 AM
    13WL will bolt right up, mild dust shield trimming needed for the larger calipers. Clears 17” and up wheels, and most 16” factory wheels. There is a TON of info on this site about the 13WL upgrade. Not sure anything will not feel weak trying to stop those 35s though. Gonna have to go with a more aggressive pad, that means a lot more brake dust.
    Weagle and RickM[QUOTED] like this.
  19. Apr 25, 2024 at 9:47 AM
    #49
    RickM
    RickM New Member
    Rick
    NE Texas
    Parking brake seems to work fine. Are you suggesting PB set too tight is wearing away disks or does it affect actual braking some other way?
  20. Apr 25, 2024 at 9:50 AM
    #50
    RickM
    RickM New Member
    Rick
    NE Texas
    Searched “13WL” and only saw one thread that led to a good purchase choice but I’ll search again. Thanks very much for info!
    The Black Mamba likes this.
  21. Apr 25, 2024 at 10:07 AM
    #51
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    BIGGER IS ALWAYS BETTER ...and before someone does a FTFY I'll just go ahead and add a TWSS :rofl:
  22. Apr 25, 2024 at 10:08 AM
    #52
    Check this: https://www.tundras.com/threads/rear-brake-adjustment-theory-and-practice.99575/
    If your brakes were same before and after the work, there's a solid possibility upgrading to 13WL isn't going to fix your issue, caliper is potentially not your problem. (but if you do upgrade, know you need bigger pads, bigger rotors, and you'll need to trim your dust shield)
    If your truck is lifted as it appears in your avatar, and you didn't also raise the height of your prop valve arm, that's problem #1. Page 2, reply #33 of that thread (link) will show you one example of moving (A) prop valve arm relocation bracket and (B) how to adjust the prop valve arm to put more brake bias to the rears. I'm not going to tag him, but one of our members in an earlier year like yours recently did this, and noted marked improvement.
    If making those adjustments doesn't fix your issue, problem #2 is - quite possibly - simply that your rears aren't adjusted properly, specifically auto-adjustment of the shoes for the parking brake arm, there's a very specific spacing that a lot of people have issues with getting correct. The FSM explains this, but it's probably also in that thread.
    But the tl;dr on this topic, many of us have learned together over the years:
    • Good braking on these trucks mandates proper adjustment of the rears, and proper functioning of the arm; when you set your p-brake, it should be locking down the rears and auto-adjusting the arm, to the point you shouldn't be able to give gas and move the truck forward when set
    • If you've lifted, and you did nothing to correct the LSPV (load sensing prop valve) armature/position, your braking will be shittier.
  23. Apr 25, 2024 at 10:15 AM
    #53
    RickM likes this.
  24. Apr 26, 2024 at 8:20 PM
    #54
    andyman0369
    Nashville
    Thanks Shifty, assuming common knowledge can backfire, this is a thread about 13WL upgrade, so...my bad. I should have given more detail.
    I'm doing the 13WL upgrade on my 02 Limited, still has 13WEs and I was having a hard time finding PNs. I spent some time on the phone with John at Olathe and he got me squared away. Those fellas are awesome BTW.
    I'm headed in the right direction now, trying to mentally prepare for front caliper upgrade & new brakes all-round, front wheel bearings, front upper/lower ball joints, L/R exhaust manifolds. My garage looks like a Toyota parts warehouse!
    The tribal knowledge here is invaluable. I genually appreciate you.
    KNABORES and Weagle like this.
  25. Jun 23, 2024 at 1:54 PM
    #55
    2001sr5 _yota
    2001sr5 _yota New Member
    Dev
    01 tundra 2r5
    3in cat back. Rest stock
    13wg take a 5.3” pad right ?? Same as 13wl?
