12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Aug 13, 2019 at 8:21 PM
    #211
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Yup exact same wire I cut, driver door doesn’t lock. All others do.
  2. Aug 13, 2019 at 8:21 PM
    #212
    Muddog
    Muddog New Member
    Bay Area California
    Kings front and Rear BMC Sliders 17s on toyo 35s
    Only the driver door should unlock all other doors should remain locked. unless you use your remote to lock or unlock. Yours doesn't do that?
  3. Aug 13, 2019 at 8:27 PM
    #213
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    According to 12volt solutions youtube installation tutorial all doors including driver should lock few seconds after remotely starting the truck
  4. Aug 13, 2019 at 8:34 PM
    #214
    Muddog
    Muddog New Member
    Bay Area California
    my driver door remains unlocked unless I hit the lock button. Anyone else have the same thing?
    MakMurph likes this.
  5. Aug 13, 2019 at 8:40 PM
    #215
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Mine came in and it's all installed. Works great! Thanks for the group buy
    TomC843, TheBeast and YsoSeRiouS! like this.
  6. Aug 13, 2019 at 8:53 PM
    #216
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    2022 limited Trd crew max
    Did any of u guys install the hood pin
  7. Aug 13, 2019 at 9:01 PM
    #217
    Muddog
    Muddog New Member
    Bay Area California
    No hood pin for me. Or push the lock 4 times and truck starts and doors lock. Im hoping James get us some clarification
  8. Aug 13, 2019 at 9:02 PM
    #218
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    I was wondering if James recommends the hood pin be installed if so was wandering where is the best place to put it
  9. Aug 13, 2019 at 9:36 PM
    #219
    TheBeast The Beach
    quick install !
    AZTundra likes this.
  10. Aug 13, 2019 at 10:08 PM
    #220
    viha22
    viha22 MAGA
    WA
    I didnt get hood pin.whats it supposed to do
  11. Aug 13, 2019 at 10:10 PM
    #221
    AZTundra
    Paul
    Phoenix, AZ
    Switch that prevents the remote start from being activated if the hood is open. Or at least that's what I recall.
    viha22[QUOTED] likes this.
  12. Aug 13, 2019 at 10:17 PM
    #222
    viha22
    viha22 MAGA
    WA
    I also didnt get a sticker for inside the hood to warn mechanics of truck being equipped with a remote start
  13. Aug 14, 2019 at 12:58 AM
    #223
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I think you may be referring to the kit/ box from 12Volt Solutions that comes with a custom sticker... 12Volt Solutions is a different group.
    James at Tech12Volts, is who this GB is with.
    FWIW, I wanted to add for the group here:
    As others have commented, James' customer service is top notch, and he cares about his customers! If you have questions, email him.
    T-Rex266[OP] and voz like this.
  14. Aug 14, 2019 at 1:38 AM
    #224
    voz
    voz New Member
    2016 Tundra
    Thank you so much for this product, it went together well.
    Awesome Job Gentlemen..
    jewsNbrews and T-Rex266[OP] like this.
  15. Aug 14, 2019 at 5:59 AM
    #225
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    Product is great works perfect jus did not really show to run hood pin everything else went easy 1 hr install
  16. Aug 14, 2019 at 6:30 AM
    #226
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    Ordered Aug 4th. Still no shipping notice. Hoping by the end of day I'll get something.
  17. Aug 14, 2019 at 7:45 AM
    #227
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Hope that wire nut is temporary. Makes me cringe whenever I see those used in automotive applications.
    BlueBottle likes this.
  18. Aug 14, 2019 at 8:27 AM
    #228
    Beetlespin
    Beetlespin New Member
    2017 Tundra trd quicksand
    I read somewhere the motor runs for only 15 mins then shuts off. Is that true and is there a way to make it run longer? 15 minutes in a WV winter isn't long enough to heat up my truck.
  19. Aug 14, 2019 at 9:13 AM
    #229
    PJR202
    PJR202 New Member
    I'm in KY and work in WV and as mild as the past couple winters have been here, it'll be a miracle if we need it more than a few times.
    Glad I saw this group buy post. I was about to drop $500+ elsewhere.
  20. Aug 14, 2019 at 10:02 AM
    #230
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    I have a Compustar autostart on my wife's Subaru and it runs for 15-minutes before shutting off as well. That is plenty of time to warm up the vehicle here in Alaska before getting in to head to work. The kicker is we installed a block and battery heater that we plug in when temps reach single digits.
  21. Aug 14, 2019 at 1:00 PM
    #231
    GiantsFanDan
    Here’s the one wire that needs to be spliced on the 2014-2017 trucks. Didn’t see it posted in here. Should make it easier for everyone
    Pbear1454 and TheBeast like this.
  22. Aug 14, 2019 at 1:04 PM
    #232
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Wait, what? I thought it's supposed to be 100% plug & play for 14--17?
    TheBeast likes this.
  23. Aug 14, 2019 at 1:12 PM
    #233
    GiantsFanDan
    First page James said 1 wire had to be spliced. Couldn’t find anywhere on here what wire it was so I looked it up and found this wire.
    My truck would start and power right off and would no longer beep if I had this wire disconnected. Also redid programming sequence once I connected the wire.
    TheBeast and Uhhhh....[QUOTED] like this.
  24. Aug 14, 2019 at 1:16 PM
    #234
    Alaska
    Alaska New Member
    Says no cutting on 2010-2017 only on 2018 and 2019.
  25. Aug 14, 2019 at 1:22 PM
    #235
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    no cutting on 17 and under. Just 18+. I know because I got his kit last year and installed on my 16. Just rechecked first post, no cutting. Old internet instruction out there you still had to cut, but new harness last year.
    Pbear1454 likes this.
  26. Aug 14, 2019 at 1:40 PM
    #236
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    You get the THAR-TOY2 and the THAR-TY50 harnesses with his kit for a 2016, that's what's in my shipment that I received, along with the EVO-One module. I had previously inquired if this included the TOY7 harness, and was told that it did. The THAR-ONE-TOY7 kit are the latest version of the harnesses from Fortin and includes these two part numbers. James states this is 100% plug-n-play.
  27. Aug 14, 2019 at 2:09 PM
    #237
    Redleg119
    Redleg119 New Member
    2019 Cement Gray TSS
    I'm in. Thanks for the group buy.
    T-Rex266[OP] likes this.
  28. Aug 14, 2019 at 2:16 PM
    #238
    TheBeast The Beach
    so TOY 7 is the one we should be getting ?
  29. Aug 14, 2019 at 2:17 PM
    #239
    danno266
    danno266 n00b
    Fortin's website shows this harness kit for 2010 through 2017.
  30. Aug 14, 2019 at 3:06 PM
    #240
    ctdomain
    ctdomain Expeditioner
    Clint
    2019 Limited Quicksand Tundra
    Suspension: ADS Front C/O's w/adjusters, ADS Piggyback rears, Toytec Shackles, Icon Rebound 17in wheels +25 offset, 35x12.50xr17 Nitto Ridge Grapplers. Miscellaneous: Tech 12 volts remote start, Tyger side steps, Color matched pro grille & bulge, Black handles off of SR5 Tundra
    Just ordered the remote start and the mycar, can't wait! thanks for the group buy!
