12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Dec 14, 2019 at 8:59 AM
    #751
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks, I thought I looked and didn't have the sensor, I'll double check.
  2. Dec 28, 2019 at 3:46 PM
    #752
    shootis
    shootis New Member
    James
    I just wrapped up my install and the truck will start and run fine with the key in. It will crank and start once after programming and then will die after a minute or so. Next time it will just crank with no start.
    I did tap the white wire with black stripe into the gray key sense wire up by the ignition key per James's suggestion. I did the programming 3 times disconnecting the battery and Evo connections between each try. I have a 2017 CrewMax with a factory alarm.
    UPDATE:
    I emailed James and he responded in minutes. He had me double check my connections.
    The TPMS connection was loose. A totally rookie move on my part. :mad:
    I’m up and running now.
    Thanks James for the excellent remote support!!!
    Stainlesst and paradizecityz like this.
  3. Dec 29, 2019 at 5:26 PM
    #753
    Buster1
    Buster1 New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    What is the toms harness? Link?
  4. Dec 29, 2019 at 6:17 PM
    #754
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
  5. Jan 11, 2020 at 11:08 AM
    #755
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Just installed mine. Only issue was tapping the white&black wire for the factory alarm. The factory alarm wire was such a small wire that none of the taps I had on hand would work. I just exposed some of the wire with a razor blade and wrapped the other wire around it and taped it. Not pretty, but it works.
  6. Jan 22, 2020 at 6:22 PM
    #756
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Hi, new here and a Google search brought me to this awesome thread!
    This link still works for me.
    Does this mean this group buy is still available?
    When would it ship if I purchased this weekend?
    I hope to have my sweet used 2014 1794 tomorrow afternoon :)
    The 2011 4runner Ltd I'm trading in had the crappy factory open door engine off remote start.
    Thanks for any information
  7. Jan 22, 2020 at 6:28 PM
    #757
    gdiep
    Syracuse, New York
    I bought mine on Dec 29 and it arrived at my doorstep around Jan 9.
    BravoDeltaRomeo likes this.
  8. Feb 8, 2020 at 12:19 PM
    #758
    guey_out_there
    guey_out_there New Member
    2017 Tundra SR5 Double Cab TSS
    Just installed this morning. If the truck shuts off after remote start and beeps for a long time, what am I doing wrong? Seems like a fault alarm
  9. Feb 8, 2020 at 4:13 PM
    #759
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    shuts off when?
  10. Feb 9, 2020 at 5:06 AM
    #760
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    If its the fortin Evo you can add the this .I have it and the range is awesome but its almost 200$ now. When I got it 6 months back it was 140$
  11. Feb 9, 2020 at 3:14 PM
    #761
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I have the alarm go off after 15 minutes, but it's a good reminder for me to get my ass in gear and get going to work.
    I wish I would not have lost my gauge readouts on my Kenwood 9903s and my TPMS without constantly draining the battery or having to unplug / replug the OBD. I thought I had asked James about this and was under the impression that I would not lose any functions. But, I really like the remote start. I like it a lot. I like it so much that I realize that I almost don't care about the loss of other functions.
  12. Feb 9, 2020 at 3:15 PM
    #762
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
    I need this in my life
  13. Feb 17, 2020 at 12:53 PM
    #763
    guey_out_there
    It was shutting off about 5 seconds after remote start.
    3-click the lock button (3 beeps from truck/3 door lock engagements)
    truck responds (1 beep from truck)
    door lock engages (1 door lock engagement)
    truck starts
    engine dies after 5 seconds
    I'm not sure why it was doing that but I've run the remote start about 30-40 times the past couple of weeks now without any further issues. Obviously I was doing something wrong but for the life of me I still can't figure out exactly what was happening. Either way, this has been a very useful mod especially in the mornings it has dropped to freezing temps and afternoons that have been above 85 degrees (this Texas winter has been weird)
  14. Feb 17, 2020 at 1:54 PM
    #764
    AZBoatHauler
    So.Arizona
    This can happen when you have the battery disconnected long enough for the idle settings to need reset. It’s happened to me a few times (even with a keyed start) and it’s always after I’ve had to battery unhooked.
    guey_out_there[QUOTED] and focal like this.
  15. Mar 1, 2020 at 6:16 AM
    #765
    Ketchumj
    Ketchumj New Member
    South Texas
    2020 Tundra SR5 4x4 Double Cab
    2020 Tundra 4x4 SR5 Magnetic Grey – TSS Off Road Toytec Complete performance 3” Lift kit with Aluma Series 2.5 Coilovers, SDP Upper Control Arms, Black Rhino 18” Gauntlet Wheels - +12 Offset, Nitto Terra Grapplers – 295/70R18, Victory 4x4 strike Front Bumper, Fab Fours Premium Rear Bumper, Smittybilt X20 12k Winch
    Will this work on a 2020 SR5? I have an H key. Looks great
