12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Sep 3, 2019 at 4:23 AM
    #601
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    Can't wait to use my cell module when hunting. Coming back to a nice warm truck after hours in the woods is going to be amazing.
    TheBeast[QUOTED] likes this.
  2. Sep 3, 2019 at 4:47 AM
    #602
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Have you tried locking the door, then pressing 3 times? I had mine apart yesterday because I needed to program it again. When I got it all back together I pressed it 3 times and nothing. Then it dawned on me to lock it first. Hope it helps.
    Magnetic15 likes this.
  3. Sep 3, 2019 at 8:46 AM
    #603
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    I guess I need to install mine to find out if will re lock the doors since mine is a 19,
  4. Sep 3, 2019 at 9:18 AM
    #604
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Thanks, Kyle. I did try that, but I'm not sure it's necessary....I believe you only have to press lock three times. James is sending me a replacement module.
    Patch999[QUOTED] likes this.
  5. Sep 3, 2019 at 10:03 AM
    #605
    Magnetic15
    Magnetic15 Steel City Member
    Eric
    2015 Platinum Crewmax
    2019 TRD Pro Black LED Headlights, 2019 TRD pro grill. Color matched door handles. Diamondback Tonneau cover.
    Definitely buying this before winter.
    AZTundra[QUOTED] likes this.
  6. Sep 3, 2019 at 3:20 PM
    #606
    BigLoggerhead
    BigLoggerhead New Member
    North Shore of Pontchartrain
    2019 Cavalry Blue Crewmax 4x4 TSS package
    Can someone help me with finding some instructions for installation. I received my remote start today and there were no instructions.
  7. Sep 3, 2019 at 4:08 PM
    #607
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    Everyone has been getting them in the shipment notification. Check your email. A pdf and a video. Both are links.
    BigLoggerhead[QUOTED] likes this.
  8. Sep 3, 2019 at 4:50 PM
    #608
    Magnetic15
    Eric
    They were emailed to you, or should have been. Check spam folder
  9. Sep 3, 2019 at 6:58 PM
    #609
    AZTundra
    Paul
    Phoenix, AZ
    I don't think you can disable the truck that way, but I can give it a try and see what happens.
  10. Sep 3, 2019 at 7:06 PM
    #610
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    There’s also a DIY I posted and included a video
  11. Sep 3, 2019 at 8:34 PM
    #611
    BigLoggerhead
    In this thread or another? If in another can you post the link?
    jewsNbrews likes this.
  12. Sep 3, 2019 at 8:41 PM
    #612
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  13. Sep 4, 2019 at 12:06 AM
    #613
    AZBoatHauler
    So.Arizona
    Just got mine installed today. I had one issue that scared me a bit so I’ll share to hopefully avoid someone else having the same sinking feeling I did...
    I ran the wires and made all the connections to the truck. I had to splice the key sense wire having the glass break sensor (thanks GiantsFanDan) and that was a pain because you have practically no wire to spare off the factory harness.
    I was then able to easily program the unit and tested it out. Truck fired right up. Great, so far so good.
    I then inserted the key and turned it to on. Truck systems (dash, radio) come to life as they should. I then turn the key back to off thinking mission accomplished... truck keeps running. Take the key out of the ignition... truck keeps running. Put the key back in flip it on and off again... still running. The only way I can get the truck to turn off is to hit lock button again 3 times.
    I figure I’ve done something to screw this up and how the hell do I fix it. It’s 2am in Georgia so I’m not going to call James.
    I then decide to check if taking the truck out of park makes any difference. Bingo. Truck shuts off when the key goes to off as it should.
    Despite the scare, this is a great product at an amazing price. Thanks James!
  14. Sep 4, 2019 at 5:57 AM
    #614
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    2010 - installation complete - tested and buttoned back up...less than 2 hours....and that was with cleaning the corrosion around the battery terminals (yuck)...
    seems to be working fine!
    thanks for a great product!
    one recommendation...better video! lol....especially the part about having to remove the OBD II...was easier to "remove" the airbag and pull it off the back side...EZ access. I saw another video somewhere..what showed this.
    THANKS!!!
  15. Sep 4, 2019 at 5:54 PM
    #615
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    You may have tried this, but I believe you turn the key to on and then press the brake. You shouldn’t have to put it into gear.
  16. Sep 4, 2019 at 5:58 PM
    #616
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Installed today. Took my time. Took an hour. Had to call Randy but he hooked me up and cleared up my confusion. Had one silly moment (scared I messed something up). After installing it, programmed it, I closed the doors, and it did nothing. Issue was my hood was up..... hahaha :rofl:
  17. Sep 4, 2019 at 6:18 PM
    #617
    AZTundra
    Paul
    Phoenix, AZ
    Mine was a tight fit (had to push it in really good for it to lock into place). Make sure it's pushed in far enough to lock the tab on it, that should ensure it's going to stay in place and not come back out.
  18. Sep 4, 2019 at 6:21 PM
    #618
    gdisarray
    There is also a car setting in the stereo that will automatically lock the doors after so many seconds. Make sure that is off.
  19. Sep 4, 2019 at 7:52 PM
    #619
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You could try running a zip tie through the harness and around the module maybe?
    I did have to give it a good push to fully click in, and I think there's a premature click that makes you think it's fully secure.
    phogallen[QUOTED] and jewsNbrews like this.
  20. Sep 4, 2019 at 8:16 PM
    #620
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Looking forward to getting mine installed. It will be perfect for upcoming winter.
  21. Sep 4, 2019 at 8:21 PM
    #621
    AZBoatHauler
    So.Arizona
    You are correct. I just confirmed the truck will shut off with the key as long as you touch the brake while the key is on.
  22. Sep 5, 2019 at 6:53 PM
    #622
    Bsincs2k
    Bsincs2k New Member
    Kansas
    2019 Voodoo Blue TRD Pro
    I see you’re from Kansas. I might need help with my install. Lol.
    I will pay for your time sir!
  23. Sep 5, 2019 at 8:52 PM
    #623
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    Hey guys,
    I installed my remote start about 2 weeks ago and am having some weird issues with my truck this week. I'm trying to diagnose whether it could be because of the remote start or if it is something else before I uninstall the remote start.
    Here is what is happening. Installed the remote start 2 weeks ago. No issues before the install and none for about a week. Then a few days ago some weird things started happening.
    Day 1 - Driver side DRL goes out. Turn signal starts hyperflashing. No big deal. Go to Autozone and get a new bulb and replace it. Old bulb doesn't look bad but put new bulb in. Works again.
    Day 2 - DRL goes out again. Hyperflash on signal. Don't replace the bulb yet. huh???
    Day 3- DRL miraculously works again in the morning. Stops working in the afternoon. WTF??
    Day 4 - Works again. But the truck has a little trouble turning over in the morning.
    Day 5 - DRL out again. ???
    Today - Truck starts no problem. Drive to grocery store. Truck is completely dead when trying to leave. Didn't even try to crank. Jump start (from a friendly fellow Tundra owner) and start drive home. Stopped at a light. Go to turn on left turn signal. As soon as I push the lever down the truck dies. Doesn't sputter or slowly shut off but like instantly dies. Push it to the side of the road. Get my wife to come meet me. Jump the truck again. Make it the 2 blocks back home. After parking, truck won't start again. Put a battery charger on. As the battery gets some juice the car starts acting funny. It sounds like it is repeatedly trying to unlock the doors. I put the key in and turn it to On, try to crank it, turn it off. Still won't stop trying to unlock doors. Finally, try to crank again and turn key to off and door issue stops.
    The battery is about 1 year old. Could be bad but not too likely. Maybe alternator issue?
    Anyway, just trying to figure out if this may be due to something with the remote start since the issues didn't start until after I installed the remote start a couple weeks ago and haven't done anything else to the truck since. I don't want to uninstall the remote start because I like the feature. But if it is causing this issue I will pull it out.
    Any thoughts?
  24. Sep 5, 2019 at 9:02 PM
    #624
    TheBeast The Beach
    it's pretty easy to unplug. just plug back oem wires and leave module there. see if all issues go away. that should take you 30 min top.
    AZTundra likes this.
  25. Sep 5, 2019 at 9:05 PM
    #625
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    That's a good point. Is there anything that needs to be done to reprogram anything? Or does just unplugging the module and plugging the OEM wires back in essentially reset everything?
  26. Sep 5, 2019 at 9:08 PM
    #626
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    There was another thread recently where the DRLs stopped working after a similar install. He ended up pushing the BCM plug on the left side of the dash in slightly more, fully seating it, and the issue was resolved. Give that a shot. That plug is very touchy.
    TheBeast likes this.
  27. Sep 5, 2019 at 9:09 PM
    #627
    AZBoatHauler
    So.Arizona
    My bet is you have a bad battery and it’s not related to the remote start.
  28. Sep 6, 2019 at 7:11 AM
    #628
    idAg9010
    idAg9010 New Member
    David
    2018 black cm TSS SR5 5.7
    Center console storage
    So are you guys able to install on a 18+ truck with no issues? I see some had to do a lot of extra work other than the "cut one wire.' Others able to install as easily as they initially thought? Hate to do it and it not work or have to be re-programmed or something. Thanks!
  29. Sep 6, 2019 at 9:43 AM
    #629
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you have the factory alarm, it sounds like you will have an additional wire or two to mess with. If you're just a standard 2018/2019, it's just the one TPMS splice to mess with.
  30. Sep 6, 2019 at 9:13 PM
    #630
    GlocKoMA
    GlocKoMA New Member
    2018 MGM Tundra SR5
    does anyone parking tail light does not come on after remote start? i have 2018 CM set to auto headlights. it only comes on if its dark out.
