12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Aug 25, 2019 at 12:21 PM
    #421
    TheBeast The Beach
    gotta have all the connectors inserted before programming. re-try the programming phase.
  2. Aug 25, 2019 at 12:39 PM
    #422
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    The video for 18 and 19 show the black box module connections after the 10 button press sequence.
  3. Aug 25, 2019 at 12:52 PM
    #423
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    I guess I'll try it both ways.
  4. Aug 25, 2019 at 1:40 PM
    #424
    teamtlr
    teamtlr New Member
    Denver Colorado
    Any luck with yours. James has me check orange wire but my horn is still going off on my 2019 after truck starts.
  5. Aug 25, 2019 at 1:46 PM
    #425
    chinadog
    chinadog New Member
    Knoxvegas
    Just reprogrammed it with and without the connectors, same result. Then I doubled check the spliced wire to see if I screwed that up, but nope, it was connected correctly. Don't have a horn issue, just what I mentioned above.
  6. Aug 25, 2019 at 2:03 PM
    #426
    chinadog
    chinadog New Member
    Knoxvegas
    Come to think about it, that extra orange wire was not called out in the video. I had it, but it's tied into a connector on one side and spliced inline with something else. Didn't think too much about it, figured it was needed for certain models.
    Edit: Looking at the schematic, looks like that wire is for the OEM alarm. I bt that's where your problem is, its probably not disarmed, hence the horn.
  7. Aug 25, 2019 at 2:16 PM
    #427
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    My 18 also doesnt relock after starting.
    One thing i tried is instead of pressing 3 times for the truck to start press 4 times and truck stays locked after starting and alarm isn’t going off.Hope that helps
  8. Aug 25, 2019 at 2:22 PM
    #428
    chinadog
    chinadog New Member
    Knoxvegas
    Good to know.
    I noticed that after I got in, turned the engine off and pulled the key that the door would lock (open or closed). I emailed James, he's looking into that.
    Apparently, after inserting the key into the ignition after remotely started and the wheel not telescoping (or drivers seat positioning hasn't adjusted) is an expected result according to James. You have to hit the memory key to get it to work while it's still on. That seems to work and I'm good with that.
  9. Aug 25, 2019 at 2:22 PM
    #429
    AZTundra
    Paul
    Phoenix, AZ
    My factory alarm was going off when trying to stop the engine through the mycar app. James told me to connect the black/white wire for the key sense, tried that today and it resolved my issue. Both remote start and mycar app functions now work as expected.
    AZBoatHauler and jewsNbrews like this.
  10. Aug 25, 2019 at 2:24 PM
    #430
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I emailed James and as others have stated, he emailed back within 5 mins. It's suppose to relock and he stated he is going to call Fortin tomorrow to ask.
    I'm guessing a few people have emailed him about this same issue...
    YsoSeRiouS! likes this.
  11. Aug 25, 2019 at 2:28 PM
    #431
    TheBeast The Beach
    looks to be the 18-19 with H key.
  12. Aug 25, 2019 at 2:28 PM
    #432
    TheBeast The Beach
    my bad thought you had G key where it shows to have all connectors plugged in
  13. Aug 25, 2019 at 2:37 PM
    #433
    teamtlr
    teamtlr New Member
    Denver Colorado
    My 19 is relocking after pressing the fob 3 times but if it sits for 10-15 minutes the horn starts going off when it restarts. Like the alert button is being pressed on fob. If I try to turn off engine immediately and remote start it again horn does not go off. It’s only after sitting for a while.
    Edit- The horn disarm issue appears to have gone away after I put a new connector on the orange wire tap that James provided. Truck is still unlocked after engine starts so I just won't do it in a parking lot but James is contacting Fortin today.
  14. Aug 25, 2019 at 2:45 PM
    #434
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Trucks with the alarm and glass break sensor need the key sense wire connected :thumbsup:. If you truck has this option, connect the wire key sense wire up.
    Others have said it isn't needed but something has changed with the evo1 module. James said the same thing to me when I brought it up to him trouble shooting the issue last week.
    AZTundra likes this.
  15. Aug 25, 2019 at 2:55 PM
    #435
    teamtlr
    teamtlr New Member
    Denver Colorado
    My 19 does not have an alarm. Just in case I need the key sense wire how can I tel which wire that is? Appreciate the input.
    Edit. That is the orange wire that has a tap into it. Mine is already connected and I ohm’ed the wire to make sure the wire tap was not faulty
  16. Aug 25, 2019 at 2:58 PM
    #436
    TheBeast The Beach
    is there an auto shut off once you get back in the vehicle ? I think i pressed the brake before inserting key and the engine shut off
  17. Aug 25, 2019 at 2:59 PM
    #437
    GiantsFanDan
    Alarm is enabled if the truck starts honking after the remote start times out after the 15min limit.
    PNWOffroader likes this.
  18. Aug 25, 2019 at 2:59 PM
    #438
    teamtlr
    teamtlr New Member
    Denver Colorado
    Mine does the same thing.
    TheBeast[QUOTED] likes this.
  19. Aug 25, 2019 at 3:01 PM
    #439
    GiantsFanDan
    If you press the brake before turning your key to on, the truck will shut off.
    AZTundra and TheBeast[QUOTED] like this.
  20. Aug 25, 2019 at 3:04 PM
    #440
    TheBeast The Beach
    thanks I'm gonna have to get used to that. I always press the brake before cranking.
    GiantsFanDan[QUOTED] likes this.
  21. Aug 25, 2019 at 3:06 PM
    #441
    GiantsFanDan
    It keeps people from stealing your truck since you have to press the brake to get into gear ;)
    viha22, AZTundra and TheBeast[QUOTED] like this.
  22. Aug 25, 2019 at 3:07 PM
    #442
    teamtlr
    teamtlr New Member
    Denver Colorado
    I think this is a different module because it does not match the evo1 but think you are onto something with the disarm. I check all the wires with ohm meter and they are good so I am at a loss. Definitely something with the disarm.
  23. Aug 25, 2019 at 3:09 PM
    #443
    GiantsFanDan
    Email James. He is very helpful
    TheBeast likes this.
  24. Aug 25, 2019 at 3:09 PM
    #444
    AZTundra
    Paul
    Phoenix, AZ
    This wire solved my issue. 2017 limited with factory alarm and glass break sensor.
  25. Aug 25, 2019 at 3:16 PM
    #445
    teamtlr
    teamtlr New Member
    Denver Colorado
    Was it the orange wire that has a tap into green wire?
  26. Aug 25, 2019 at 3:25 PM
    #446
    teamtlr
    teamtlr New Member
    Denver Colorado
    Yep. In contact with James. Just said check orange wire. It’s Sunday so I will probably have to wait until tomorrow and was hoping one the members ran into something similar.
  27. Aug 25, 2019 at 3:26 PM
    #447
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    James is going to contact Fortin tomorrow and get back to me
  28. Aug 25, 2019 at 3:41 PM
    #448
    AZTundra
    Paul
    Phoenix, AZ
    Mine is probably different being a 2017. I had to connect the white/black wire from the evo one to the black wire (pin #2) on the lower plug of the bcm.
    Same as the picture in post #455.
    Magnetic15 likes this.
  29. Aug 25, 2019 at 4:25 PM
    #449
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    Anyone else have their truck just crank for about 5 seconds and never start?
  30. Aug 25, 2019 at 4:31 PM
    #450
    TheBeast The Beach
    no.
    I have a 2012 and install was a breeze. maybe try to redo the whole programming phase. You are using the black G key during the install right ?
    I connected the battery back then started connected the plugs to the fortin device as described in procedure.
