10k vs 5k mile oil change
Discussion in 'General Tundra Discussion' started by sabet, Aug 3, 2022.
  1. Sep 23, 2022 at 9:26 AM
    #241
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    We didn't even use Pennzoil in our lawn mowers
  2. Sep 23, 2022 at 9:31 AM
    #242
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I grew up with 3k changes. The last 500 miles on a 5k change really starts to bug me, but changing every 5k, i dont have to write down the last change, who else had a list of milage written on the back of their regestration sticker?
    Tundrastruck91 likes this.
  3. Sep 23, 2022 at 9:38 AM
    #243
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I record all maintenance in a little journal I keep in my console
    WILLINH and joe_from_iowa like this.
  4. Sep 23, 2022 at 9:47 AM
    #244
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I used to, but now, i've got a PC file with pics and reciepts.
    my last oil change i got nervous at 4k, decided to run some MMO through it, and got dirtier oil when i changed, because my first change was super clean after 3-4 k to get me on a schedule of 5's.
  5. Sep 23, 2022 at 9:49 AM
    #245
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I remember pouring in engine flush anytime I switched oil brands or went past 3k miles
  6. Sep 23, 2022 at 12:32 PM
    #246
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I've never once in my life heard of oil seals going bad after 5 years from the color of oil. The UOA will tell you everything you need to know about the condition of your oil, if changing out good oil that's slightly discolored floats your boat, then go for it.
    You change your oil based on color, well, I hate to break it to you. But every time you change your oil, then drive it any amount of time, it's contaminated, so you might wanna change it every time you drive it, based on how you change your oil now.
    I'll stick to the facts and the science behind oil, and the great team of oil engineers and chemists I know. :thumbsup:
  7. Sep 23, 2022 at 12:44 PM
    #247
    Sumo91
    TN
    Here you go, as promised.
  8. Sep 24, 2022 at 4:56 AM
    #248
    Sumo91
    TN
    From someone that does industrial forensics on seals and gaskets.
    Seals typically fail from
    Abrasion ( particulate matter grinding, shaft abrasions etc.)
    Fit (can be anything from dimension too small for proper seal tension, egg wear of shaft, misalignment creating a gap)
    Installation (cocking a seal, damaging the garter spring/element)
    Heat ( over time this will fatigue any polymer)
    Dry Running ( a seal needs a bit of lube to live- its not a quality of the oil but the long term absence leading to abrasion and/or thermal fatigue)
    Pressure ( usually seen as an extrusion but can be just blow by)
    Normal end of life ( no polymer compound lasts forever with all properties intact)
    I left off things like mechanical damage because those failure modes are usually random and external to the seal proper.
    Basically the same for gaskets but gaskets are prone to set and need retorquing evenly, sometimes they saturate/delaminate ( even rot)
    Sometimes a change to a much different fluid that's thinner or a temp change will leak at certain grades but not at others.
    So, to say a gasket or seal failed due to an oil, extended oil change interval or some "normal to that application" contamination- while POSSIBLE would be at the highest end of improbable and require significant supporting hard evidence to prove it.
  9. Sep 24, 2022 at 6:20 AM
    #249
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I have 3 oil analysis in my post. 2 analysis at 8k OCI and 1 at 10k OCI.
    https://www.tundras.com/threads/here-is-my-engine-oil-analysis.55486/
  10. Sep 24, 2022 at 6:25 AM
    #250
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I trust the oil analysis reports, and the experience of seasoned mechanics to help me determine oil change intervals. I’m at 5,000 oci on my Tundra. On my Ford Transit 3.5 TT I’m at 2,500 oci.
  11. Sep 24, 2022 at 6:32 AM
    #251
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    these oil analysis reports are like kryptonite to internet gurus.
    proves the know it all's wrong every time.
    the only time i see a real difference in oil reports is when they are taken past 7500 miles.
    under 7500 miles, all oils behave in a similar range.
    the <7500 range varies so little it is safe to say - you should not pay more than Kirkland rates for oil.
    and lather on - I rotate tires every 5k....so 2 birds get knocked out.
    JLS in WA, texasrho83 and Terndrerrr like this.
  12. Sep 24, 2022 at 6:43 AM
    #252
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    With the more aggressive MT tires I've done rotations at 3k
    Terndrerrr likes this.
  13. Sep 24, 2022 at 6:44 AM
    #253
    nobodyintexas
    nobodyintexas What?
    South of Houston
    You might need to try 0w-MT tires.
  14. Sep 24, 2022 at 6:50 AM
    #254
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I do 3k rotations with my Duratracs. The two biggest complaints I hear about them is that they’re loud on the highway, and they wear quickly and unevenly. I don’t have either one of those issues with 30k miles on them.
    Jernik and texasrho83[QUOTED] like this.
  15. Sep 24, 2022 at 7:16 AM
    #255
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep, I was doing 3k rotations on my Toyo MTs, Kumhos, and now I try to do them with the MT Baja ATs. I hate uneven wear.
    Jernik likes this.
  16. Sep 24, 2022 at 7:24 AM
    #256
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Yall throw in some criss cross or find back to front to be sufficient?
  17. Sep 24, 2022 at 7:28 AM
    #257
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I've always taken the back tires straight to the front, then crossed the front whem taking them back; LF to RR and RF to LR.
  18. Sep 24, 2022 at 7:28 AM
    #258
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I don't do criss cross
    Bammer, WILLINH, panicman and 4 others like this.
  19. Sep 24, 2022 at 7:32 AM
    #259
    COTundie
    Trey
    Pretty things
    Thank God!
    texasrho83[QUOTED] and Jernik like this.
  20. Sep 24, 2022 at 7:32 AM
    #260
    Jernik
    Jernik New Member
    Jeremy
    I've been doing 6k rotations (with my OCI). So far at 20K they haven't become loud yet and seem to be wearing evenly. I've found pretty much any AT/MT will get louder without frequent rotations.
    texasrho83 likes this.
  21. Sep 24, 2022 at 7:32 AM
    #261
    Jernik
    Jernik New Member
    Jeremy
  22. Sep 24, 2022 at 7:35 AM
    #262
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The noise factor never bothers me as I'm usually listening to my exhaust and radio :headbang:
    Jernik[QUOTED] likes this.
  23. Sep 24, 2022 at 7:36 AM
    #263
    COTundie
    Trey
    Pretty things
    Ya.
    I've been warned about the KO2s I put on just under 3k ago.
    Probably going to step it upto 3k. Had initially hoped to keep it with the oil change at 5k, but I would like to keep the tires quiet as long as possible.
  24. Sep 24, 2022 at 7:37 AM
    #264
    Terndrerrr
    Music City
    6UR-FE
    I do. Rears go straight to the front. Fronts go to the opposite rear. That’s the pattern for RWD/part time 4WD vehicles.
  25. Sep 24, 2022 at 7:40 AM
    #265
    COTundie
    Trey
    Pretty things
    Well alright.
    Thank you for making my rotations more involved ;)
  26. Sep 24, 2022 at 7:45 AM
    #266
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I'm all for this and do any AWD vehicles I've had this way. The Toyota manual says just front to back, that's what I've been doing..... Maybe next season after the snows come off I do some criss-crossing. Nothing is cut and dry. Now you've got me thinking about tires in an oil thread, down the wormhole!
    Note: I know I can't criss-cross snow tires (directional).
    Jernik likes this.
  27. Sep 24, 2022 at 7:58 AM
    #267
    COTundie
    Trey
    Pretty things
    I'll take full responsibility for the derailment...
    I've done simple front to back for so long since the bimmer has directionals on both sets. Not to say I can't learn new tricks.
  28. Sep 24, 2022 at 8:11 AM
    #268
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    OMG have to buy new higher jack and jack stand for this…
    Terndrerrr[QUOTED] and Jernik like this.
  29. Sep 24, 2022 at 9:14 AM
    #269
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    WILLINH likes this.
  30. Sep 24, 2022 at 9:46 AM
    #270
    Sumo91
    TN
    OK, this is all an opinion, I provided very valuable information pertaining to the subject, and you just keep repeating yourself. You're telling me the oil and seal manufacturers don't account for variable temperature changes and Canadian temperatures are excluded in their testing? Wrong. They test them to the extremes.
    I'm ready for some facts. Not opinions, not some youtube mechanic who just has an opinion with no scientific data to back up his claims. I can put you in touch with a number of people with different PhD credentials that can absolutely clear this up for you. I also work in the oil industry and seeing these myths and opinions is absolutely mind blowing. Gimme me some science. Gimme some facts.
