10k vs 5k mile oil change
Discussion in 'General Tundra Discussion' started by sabet, Aug 3, 2022.
  1. Sep 23, 2022 at 3:46 AM
    #211
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Good thing you don't own a diesel.
    hagrid and Sumo91 like this.
  2. Sep 23, 2022 at 5:33 AM
    #212
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Wait till he finds out clean oil can cause varnish :eek:
    Bammer[QUOTED] likes this.
  3. Sep 23, 2022 at 5:55 AM
    #213
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    5k all the way. Oil is cheap and engines are not.
    WILLINH and Chris001 like this.
  4. Sep 23, 2022 at 6:07 AM
    #214
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wouldn't say oil is cheap but relative to the cost of an engine, yeah. I've only bought Mobil 1 when it was on sale. Now that I'm an Amsoil member, I'm having to recalibrate my idea of what I wanna pay for oil
  5. Sep 23, 2022 at 6:12 AM
    #215
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Don’t get me wrong, Amsoil is good but it’s overpriced. Most common brand full synthetic oils that meet API specifications required by the manufacturer will do the job just fine.
    Bammer, RitcheyRch and KNABORES like this.
  6. Sep 23, 2022 at 6:20 AM
    #216
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I feel like with oil you get what you pay for.
    Sumo91 likes this.
  7. Sep 23, 2022 at 6:21 AM
    #217
    Sumo91
    TN
    If you run 5k OCI, amsoil is a waste, 10k is about break even, 15k-20k OCIs makes its cheaper to run than off the shelf oils. API specs also have a ceiling, so when oil blenders make an oil that is truly superior than anything off the shelf, it exceeds the API spec, and therefore cannot get the label on the bottle without taking a step backwards.
    The API spec is a great thing to adhere to, but where it limits inferior oils from getting the label, it also limits superior oils from getting it as well.
    Bammer likes this.
  8. Sep 23, 2022 at 6:23 AM
    #218
    Sumo91
    TN
    I paid a little less than $1200 for my current stash of oil :eek: but I have enough to last me for several years.
    WILLINH and Bammer like this.
  9. Sep 23, 2022 at 6:24 AM
    #219
    Bammer
    Monroe, CT
    Agreed, run Amsoil 15,000 + miles to make it worth spending the extra $$$$
  10. Sep 23, 2022 at 6:26 AM
    #220
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'm a bit unwashed as it relates to Amsoil.
    why is it so hard to find?
    How does one buy it?
    is it still $10/qt?
  11. Sep 23, 2022 at 6:27 AM
    #221
    Bammer
    Monroe, CT
    I too was a BITOG hoarder of the green elixer of the God's that was Castrol Syntec 0W30 red label ! Had 300 quarts at one point.
    Sumo91[QUOTED] likes this.
  12. Sep 23, 2022 at 6:28 AM
    #222
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    what’s the shelf life look like on that stuff?
  13. Sep 23, 2022 at 6:30 AM
    #223
    Sumo91
    TN
    You definitely have me beat :fistbump:
    I'm running High Performance Lubricants now, if you haven't been on bitog in awhile, you should check them out. They're a site sponsor now, and Dave is one the best people I've ever had the pleasure of meeting, and he is entirely too humble for his own good, he also makes an incredible oil, with an amazing group of people working with him such as Leslie Rudnick, and many others.
    texasrho83 and Bammer[QUOTED] like this.
  14. Sep 23, 2022 at 6:33 AM
    #224
    The trouble with extended OCI is it really depends on individual use. Synthetic oil is superior to Dino oil in that it doesn’t break down and degrade over time the way Dino oil does. So cool, my oil lasts a long time! But we change oil not just due to oil degradation, we also change due to contamination. Environmental, like dust and debris ingested through the air intake and contamination from byproducts of combustion. If you’re running in dusty conditions, 15k intervals is probably a bad idea. Especially you K&N filter guys. If you’re all highway and not towing, extended intervals may be possible.
    nobodyintexas and Sumo91 like this.
  15. Sep 23, 2022 at 6:35 AM
    #225
    Sumo91
    TN
    This was brought up during the open house at HPL, the oil doesn't necessarily go bad, most oils just have additive separation. Every single batch of oil they make, they keep a sample of it in a clear bottle, and they have samples that have been sitting on the shelf for 10yrs with no product separation at all. It's pretty incredible.
    I had an incident running pennzoil where all the additives dropped out of suspension and were resting on the bottom of the jug, it was a brand new jug straight from store.
    texasrho83 and Clay J[QUOTED] like this.
  16. Sep 23, 2022 at 6:38 AM
    #226
    Bammer
    Monroe, CT
    I will check it out . Thank you :cheers:
  17. Sep 23, 2022 at 6:40 AM
    #227
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Wow that is crazy. Wasn’t it Pennzoil that was known for having issues with paraffin wax back in the day?
    Randy Morton and Sumo91[QUOTED] like this.
  18. Sep 23, 2022 at 6:41 AM
    #228
    Sumo91
    TN
    No problem brother. What's really great is the customer service, the owner, Dave, will let you call him and answer any of your questions (what other oil company can you call and talk to the owner?). He even made me a special batch of 75w for the transfer case, no extra charge from their regular gear oil prices.
    If you ever want a tour of their blending facility, they're happy to oblige. You can literally eat off of the floor in there
  19. Sep 23, 2022 at 6:42 AM
    #229
    Sumo91
    TN
    Hmm I'm not entirely sure on that one.
  20. Sep 23, 2022 at 6:55 AM
    #230
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I would think if you tow in S4 you should probably change the oil at 2.5k due to the forced higher revs under load...but the transmission fluid stays cooler so they have that going for them.
  21. Sep 23, 2022 at 7:06 AM
    #231
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sumo's Oil Reserve?
  22. Sep 23, 2022 at 7:07 AM
    #232
    Sumo91
    TN
    Looks like I have a name for it now :thumbsup:
    Here is most of it.
  23. Sep 23, 2022 at 7:25 AM
    #233
    Bammer
    Monroe, CT
    That is customer service ! Where are they? Never mind, I'm heading to their website now. Thanks for the info @Sumo91
  24. Sep 23, 2022 at 7:35 AM
    #234
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sumo hooked me up with HPL's info too and I reached out to them. The lady responding to my emails didn't know if they could make custom batches but I told her uh yeah you just made some for Sumo lol anyway love their service.
    Bammer[QUOTED] and Sumo91 like this.
  25. Sep 23, 2022 at 8:10 AM
    #235
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    The Car Care Nut says your 5.7 leaks a small amount of gas into your oil over time. If you’re going longer than 6mo, it’s happening regardless of which oil and filter you use. He says 5k/6mo OCI is what keeps Toyotas happy the longest. Anyone care to confirm or deny this?
    That’s basically why I switched to Kirkland and 5k OCI. Plus, I’m actually saving money. Engine isn’t louder, either. Running Mobil1 0w20 however sounded like I had a bad lifter. :eek2:
    Sumo91 likes this.
  26. Sep 23, 2022 at 8:12 AM
    #236
    Sumo91
    TN
    A UOA should show any fuel dilution. I'll post some 10k UOAs later today. Gotta run some errands.
    Terndrerrr[QUOTED] likes this.
  27. Sep 23, 2022 at 8:18 AM
    #237
    nobodyintexas
    nobodyintexas What?
    South of Houston
    RE: fuel dilution
    this was the test right after all the dyno tuning.
    Terndrerrr and KNABORES like this.
  28. Sep 23, 2022 at 8:27 AM
    #238
    Terndrerrr
    Music City
    6UR-FE
    Nice. Wonder if that’s something that increases over time and as you enter higher miles.
  29. Sep 23, 2022 at 8:30 AM
    #239
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I would guess both.
    a higher mileage engine probably has worn rings and thus more blow by.
  30. Sep 23, 2022 at 9:19 AM
    #240
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I'm not sure about Pennzoil, but Amalie and Valvoline were both known for sludging up engines.
