10k vs 5k mile oil change
Discussion in 'General Tundra Discussion' started by sabet, Aug 3, 2022.
  1. Sep 24, 2022 at 10:22 AM
    #271
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Ahh the ole sign of defeat. I provide good info, that you can't argue with, and you think its made up since I didn't provide a source. Tsk tsk. Read my other posts carefully. I told you I'd put you in touch with people who can help you understand things better. But if what you're doing is working, keep doing it. Just try not to spout nonsense about seal longevity due to oil varnish as a fact, when it's just your opinion.
    Just an FYI. My 1995 f250 7.3 diesel has 300k miles with no leaks, all extended oil changes :eek: my tundra is at 247k with no leaks and extended OCIs
    The quality of your oil plays a part in seal longevity as well (seal conditioners, etc)
    But I'm fighting a lost cause at this point. I feel I provided good information to help you learn something. I change my views and opinions as more knowledge becomes available. Some people don't and stick to their guns, refusing any new knowledge and information as it challenges their current views and long held beliefs. Nonetheless, I hope your tundra serves you well for a million more miles, completely leak free :thumbsup:
  2. Sep 24, 2022 at 10:34 AM
    #272
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yep. I've got not one but TWO coworkers with Tacomas both of which have well over 300,000 miles on the factory stock Mama Toyota transmission oil and they report they drive just fine. And they have no plans to ever change it.
  3. Sep 24, 2022 at 12:13 PM
    #273
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    Even though Toyota Care would give me a free oil change at 10k miles, I didn't feel comfortable waiting that long especially since it's the first 10k miles on the truck.
    Changed oil myself, and glad I did!
    Right cap is what came out, left cap is fresh oil!
  4. Sep 24, 2022 at 12:30 PM
    #274
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    That’s just mean the oil is doing it’s job, cleaning the engine
  5. Sep 24, 2022 at 1:20 PM
    #275
    Sumo91
    TN
    I've worked in Alaska a bit, I know about cold. I have buddies there that run extended OCIs with no I'll effects
    It sounds like you need a good cold weather oil. Well I know the perfect one for you if you're interested, and it also contains esters and Alkylated napthalenes to not only prevent, but remove varnish and carbonaceous build up. If you're as worried about varnish as you say you are, I can definitely get you pointed in the right direction. Shipping might be a bit much, but considering you would rather spend money on oil to save yourself from an engine failure, I don't think that will be an issue. If anything it would be good oil to run every few OCIs just to keep things squeaky clean and shiny. If you want to know more about it, ill be more than happy to help
  6. Sep 24, 2022 at 2:07 PM
    #276
    Sumo91
    TN
    Well if you use amsoil, this picture will be right up your alley. Here is a side by side picture of amsoil SS 15w40 next to HPLs 15w40 premium cold climate HDEO
    HPL on the left, Amsoil on the right
    Both tipped over at the exact same time. -30C
    texasrho83 likes this.
  7. Sep 24, 2022 at 2:17 PM
    #277
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Do you have a pic of the same comparison but both oils 0w20 or 5w30?
    JLS in WA and Sumo91[QUOTED] like this.
  8. Sep 24, 2022 at 2:21 PM
    #278
    Sumo91
    TN
    I do not. But HPLs premium plus PCMO and HDEO outperforms amsoil in cold weather conditions. I can see if David will be kind enough to throw some of it in his oil freezer and give me some photos side by side, but it might be awhile. What really blows my mind is that John Deere branded 15w40 did better than the amsoil ss 15w40 o_O
  9. Sep 24, 2022 at 2:40 PM
    #279
    Terndrerrr
    Music City
    6UR-FE
    Interesting. Amsoil says its premium API 15w40 has a pour point of -40ºF. Pour points for other diesel oils are listed below:
    I would expect any oil with severe cold weather formulations to outperform any oil without those same additives at temps near the pour point to be honest.
    Sumo91[QUOTED] likes this.
  10. Sep 24, 2022 at 3:07 PM
    #280
    Sumo91
    TN
    Here is the Premium Plus PCMO, it's what I would run in extremely cold climates.
    Screenshot_20220924-180412_Acrobat for Samsung.jpg Screenshot_20220924-180420_Acrobat for Samsung.jpg
    Terndrerrr[QUOTED] likes this.
  11. Sep 24, 2022 at 3:20 PM
    #281
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    *scans document for signatures, finds none...
  12. Sep 24, 2022 at 3:53 PM
    #282
    Sumo91
    TN
    :rofl: you got me @hagrid of all people I didn't expect to get got by you. Don't I get an award for this or something :monocle:
    I could see if Leslie Rudnick would sign off on it if it would help.
    Leo's first and hagrid[QUOTED] like this.
  13. Sep 24, 2022 at 4:50 PM
    #283
    Terndrerrr
    Music City
    6UR-FE
    My oil was signed.
    “Kirk L. And”
  14. Sep 24, 2022 at 5:35 PM
    #284
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    22 below zero.....
  15. Sep 24, 2022 at 6:50 PM
    #285
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    That's two things Spraynard.
    hagrid[QUOTED] likes this.
  16. Sep 24, 2022 at 6:51 PM
    #286
    Melikeymy beer
    Muscogee Nation
    7,500 mile oil change for the win.
  17. Sep 24, 2022 at 9:14 PM
    #287
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    They signed mine too.
    Terndrerrr[QUOTED] and hagrid like this.
  18. Sep 24, 2022 at 9:15 PM
    #288
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Well, you have to pick one. They are mutually egg-sclusive... like a really great handy from a gal with lumberjack callouses.
  19. Sep 24, 2022 at 9:27 PM
    #289
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
  20. Sep 24, 2022 at 9:55 PM
    #290
    Eagleye
    Eagleye New Member
    22 SR5 4x4
    Rear seat cover, bed mat
    A faulty PCV will cause sludge fest. Infrequent oil changes, short drives and starting car without driving to full operating temp cause sludge fest as well.
  21. Sep 25, 2022 at 4:49 AM
    #291
    Terndrerrr
    Music City
    6UR-FE
    Also signed by Mr Signature :laughing:
  22. Sep 27, 2022 at 4:46 AM
    #292
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    As I have stated before, 2001 F-150 had yearly oil changes with dino 5w30 bulk, low bid oil. Was retired just before it hit 200k, only because the body was toast. No burning, no leaking or any oil related issues. Used and abused , ridden hard and put away wet. The life of a municipal owned truck.
    This discussion can go on forever with no resolution or right answer !
    WVI likes this.
  23. Sep 27, 2022 at 8:39 AM
    #293
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    I never change my oil, not once. Doesn’t burn a drop, she’s got 250k+. I only change the oil filter once every year. Still running strong!
    This is what I hear
  24. Sep 27, 2022 at 8:44 AM
    #294
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Let me try some of that next time…:D
  25. Nov 5, 2023 at 4:12 AM
    #295
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    I feel the exact same way. People are confusing opinions for facts. Every vehicle that I've owned has gotten a 10k OCI and it was backed by oil analysis from Black Stone labs.
    Leo's first likes this.
  26. Nov 5, 2023 at 4:29 AM
    #296
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Why guess or suffer through all the internet blowhards?
    Hire a truck psychic and find out exactly what's going on inside your truck.
    Bulldog9, hagrid, texasrho83 and 2 others like this.
  27. Nov 5, 2023 at 6:17 AM
    #297
    CMikeB
    CMikeB New Member
    My T H O U G H T S too.
  28. Nov 5, 2023 at 7:24 AM
    #298
    coTony
    Tony
    Montrose, CO
    Sad the stealership's are to blame for the early failures and eager to step up and put you in a new car... with 10K oil change intervals
    CaptRussia253 likes this.
  29. Nov 5, 2023 at 9:14 AM
    #299
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It took years for me to adjust to doing them at 5k vs 3k. You'll never convince me to do them at 10k :rofl:
  30. Nov 5, 2023 at 9:22 AM
    #300
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    Fact is, change your oils however the eff you want. This site is not a large enough or coordinated enough sample set to draw a conclusion about anything.
    Now if this was a F-150, RAM, or Chevy forum, it may be different. We are driving the most reliable trucks on the road today. Just change it, and you will be happy.
    Now for an opinion piece! I have had very successful results testing Maple Sap as an oil. All natural straight from the tree. Smells good too and you can use it on pancakes when you're done.
