100k recommended dealer service
Discussion in '2.5 Gen Tundras (2014-2021)' started by TilleryTundra, Jul 1, 2024.
  1. Jul 1, 2024 at 8:23 AM
    TilleryTundra
    TilleryTundra [OP] New Member
    2020 white tundra
    None
    Hello. I’m new to this site. Question for 2020 owners. I have 118k on mine and I would like to hear about dealerships recommended service of changing all fluids and belts,hoses. Thanks
  2. Jul 1, 2024 at 8:56 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    You should have a maintenance guide with your owners manual in the glove box that details what you need to check/change/drain&fill every 5k miles. Check that against the truck’s carfax history to see what has been done or missed. Then you can do whatever has been missed.
    You should do this for every used vehicle you purchase.
    Edit: here’s the guide after a quick DuckDuckGo search:
    https://assets.sia.toyota.com/publications/en/omms-s/T-MMS-20Tundra/pdf/T-MMS-20Tundra.pdf
  3. Jul 1, 2024 at 12:11 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    See Post #2
    ZappBrannigan likes this.
  4. Jul 1, 2024 at 12:14 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Well well well, look at you with the “dispensing of thoughtful advice” and “follow through” with a link.
    you’re a model citizen. Good job.
    Jaypown likes this.
  5. Jul 1, 2024 at 6:04 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Just don’t let the dealership flush your transmission. Drain and fill only.
