10 PLY tire recommended PSI
Discussion in 'Wheels & Tires' started by matambo, Dec 10, 2017.
  1. Jun 5, 2019 at 5:28 PM
    #61
    Marco
    Marco New Member
    Well... yeah
  2. Jun 5, 2019 at 5:58 PM
    #62
    Marco
    Marco New Member
    I tried different psi 72 the truck bounces nervous . 65 still squirmy . 55 gas mileage sucks .. 60 is the magic psi
  3. Jun 5, 2019 at 7:47 PM
    #63
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, my door sticker with BFGs says 46. Dealer screwd it up at every rotation even when I told them. I was running 50 but not sure what Discount put in last rotation. TPMS light has not come on so I think they are good. 10 plies handle 50 differently than lighter tires.
  4. Jun 5, 2019 at 8:01 PM
    #64
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    35 Psi on my 10 ply ProComp AT's. As was said, the ride starts to suffer above that.
    Trust86 likes this.
  5. Jun 5, 2019 at 8:04 PM
    #65
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    18 on the trails
    40 front / 42-44 rear (depending on extra weight)
    My chalk test looked good to me. When in doubt, chalk test.
    35x12.50 Nitto Ridge Grapplers
    Edit: old ass thread lol
  6. Sep 23, 2019 at 5:25 AM
    #66
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    What tire are you running? And do you know how much the pressure is changing at highway speeds? And perhaps temperature?
  7. Jan 3, 2020 at 11:16 PM
    #67
    GasGasTXT
    GasGasTXT New Member
    Northeast WA
    2012 Rock Warrior
    10 ply BFGs KO2s on 17" were OEM on the Rock Warrior; sticker says 46 psi if I recall. I've been running 45-50, mostly towing. 4-season performance is excellent; wear is excellent.
    On the third KO2 set now, replacing at 50K intervals. They could definitely go longer, but I need deep tread for the often unplowed winter conditions and the mudpocalypse spring thaw at the homestead.
    I look at the tiny sidewalls on the mall crawler slicks on some of these trucks and shake my head. If there's one thing you can do to ruin and hobble a truck, and turn it into a Prius with a large cargo area, that is it.
  8. May 20, 2020 at 11:57 AM
    #68
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Hercules Terra Trac A/T2 - 275 65 18 - 10 ply Load E , Hercules said to run a minimum of 48 psi on the tundra with these tires , I run 53 psi unloaded and while towing , nice even tire wear so far !
  9. Jun 7, 2020 at 10:28 PM
    #69
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Just joined. 2019 TRD Pro. Trying to figure out the tire issue.
    I learned a lot when I spoke to a level 2 BFG or Toyo tire support person on the phone a few years ago.
    A load E tire is a standard rating each tire has to abide by, per Feds. Brand irrelevant. As I am sure many are aware of. At the time, I never really pondered that, that much. Makes sense though.
    That being said, I had a dually, that road like crap unloaded. I found an inflation chart, went from 80 down to 35, in 5 PSI increments with corresponding weight capacity for each 5 psi step. I hand calculated the chart down to 15 PSI. Took the front and rear axle weight of my truck. Added up the passenger compliment and fuel etc... for additional weight. End story, loaded with peeps, fuel, and a 100 lbs in bed for any groceries, traveling, etc... I ended up running 20 PSI in the rear, and 62 in the front. The ride was great compared to when the rear was inflated to more normal pressures. Tires wore normally, no issues. Did not act goofy, etc... Ran up and down I 70, usually in the left lane, not the least bit worried about not enough tire pressure. Handled better actually. Door sticker said 80 was required in the rear... With 80 in, those little seams, etc on concrete roads, etc around turns felt like might just bounce out of line around a turn. And on snow, it was a polar opposite in traction with 20 in the rear.
    This was with 3 different sets of tires. Two OEM size, one set slightly larger.
    I am not sure if I am going to go with a LT tire or non LT, like the OEM tire. LT is tougher, etc... Also, seems to be a lot of stiffness for a crappy ride. Unless running down into the 25 to 35 range. I am currently guessing, have not ran numbers. I know many of you like the 10 ply toughness for off roading. I don't see myself going off roading to such an extreme, like I used to with my full size GMC Jimmy, aka old beater.
    What is the front and rear axle curb weight, not the gross max weight? Just empty unloaded. I can't seem to find it yet.
    jordoncloutier likes this.
  10. Jun 9, 2020 at 4:42 AM
    #70
    StoneyWV
    StoneyWV New Member
    Calvin
    2020 Tundra TRD Sport
    Rough Country Level,
    I contacted Falken about tire pressures on my Rubitrek 275/70/18 and they said 43 for the rear pressure and 40 for the fronts.
  11. Aug 24, 2023 at 11:51 AM
    #71
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Old thread. Just got 285/65/18 Toyo ATIIIs. Toyo recommended 40/43 front/rear. I’ll try that and chalk it. Tire place had them at 35.
