10 PLY tire recommended PSI
Discussion in 'Wheels & Tires' started by matambo, Dec 10, 2017.
  1. Jan 1, 2018 at 10:01 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have only driven a few miles on them with whatever the tire shop set them at, where I mounted them I didn't have an air compressor or a psi gauge, so I'm not sure what they are at.
    I plan to set the psi around 50 today unless I learn otherwise sooner.
    I will drive it a bit tomorrow, but not enough to reach any accurate conclusions. Once it warms up I plan to do the chalk test and experiment a bit.
    I will let you know how things shake out.
  2. Jan 1, 2018 at 12:16 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    285/65r18 K02's here. I'm running them at 48 psi which seems to work pretty well.
    MotoTundra likes this.
  3. Jan 1, 2018 at 12:42 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Same here BFG said 50 but I almost lost a tooth filling so I usually stick around 48 when I tow the camper. This time of the year I drop em down to about 44 cuz of the snow.
    blizz86 and MotoTundra like this.
  4. Jan 1, 2018 at 1:00 PM
    Borgs
    Borgs New Member
    PA
    I have 40 PSI in them and drove about 50 miles on the TP today. A little stiffer than the 35 PSI I had in of course (which with the cold temps probably was running 32 or 33 PSI), but about 1 MPG better on gas mileage.
    MotoTundra[QUOTED] likes this.
  5. Jan 1, 2018 at 5:49 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good to know!
  6. Jan 1, 2018 at 5:52 PM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    That picture is worth a million dollars...Nice truck..What brand wheels you have on there?
  7. May 16, 2018 at 8:28 PM
    Borgs
    Borgs New Member
    PA
    How’s it handling? 50 PSI?
  8. May 17, 2018 at 3:36 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    I have mine filled to 36 front 35 rear.
  9. May 17, 2018 at 3:55 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I haven't checked the PSI since I first put them on, I need to see if they have dropped any. This is a good reminder, thank you.
    It certainly isn't as plush as 35 or 40 but I am used it to by now.
    What PSI have you been running?
  10. May 17, 2018 at 3:58 AM
    Borgs
    Borgs New Member
    PA
    Just checked the other day after my new suspension. 48. Last I checked when it was colder it was 43, so the warmer temps certainly expands it
  11. May 17, 2018 at 6:39 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Is 1mpg worth $1000+ tires wearing more quickly? Don't see the ROI
    Did you do the chalk test?
  12. May 17, 2018 at 7:03 AM
    Borgs
    Borgs New Member
    PA
    I am not following. My point wasn’t about economics, it was just commenting on ride characteristics following the change in PSI. And I dont see any depreciating asset as an investment; it’s essentially a toy, hobby and a mode of transport for me. In any event the tire shop had 35 in at install. BFG recommends 50. I am running 45 (which varies from 42 - 48 depending on temps) based off BFG recommendation, because, in essence, I trust them more than my shop who only had 35 in them.
    Edit: the 45 is a compromise for me based off BFG recommendation because 50 was too harsh and knocked my teeth out.
  13. May 17, 2018 at 8:14 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    If you call/contact BFGoodrich direct they recommend 55 psi for those specific tires on our trucks.
    I am running 50 because I want them to wear properly. You get a nicer ride with 35-40 but I'm hoping/assuming the tire company is giving accurate information. If I notice premature center wear I will definitely drop the psi. I don't have enough miles on them yet to notice much wear.
    If MPG's were that important to me I never would have bought this truck, haha.
    I need to do the chalk test. When I bought the tires it was way too cold and lately I have been very busy I haven't gotten around to it.
  14. May 17, 2018 at 12:56 PM
    Borgs
    Borgs New Member
    PA
    Apologies, yes, it's 55 PSI recommended. My bad.
  15. May 17, 2018 at 2:25 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Same thing haha either one feels like....
    SouthBoundSteve likes this.
  16. May 17, 2018 at 2:29 PM
    Borgs
    Borgs New Member
    PA
    Ha, no, 55 is MUCH worse!!!
  17. May 17, 2018 at 4:58 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I have 38psi front and rear in my load range D Generals on my first gen. Shoot the tire manufacturer an email. Give them year, make, model, original tire size and GVW and new tire size. An engineer should be able to tell you. That's the route I took when I bought my tires
  18. May 17, 2018 at 5:34 PM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    On the Falken website there is an inflation chart for different sizes. The main thing I got from it is that it provides load capacity for different tire pressures. I know it’s not the same tire, but you could probably look and have a decent idea of where your tires fall.
  19. May 22, 2018 at 10:55 AM
    #49
    Marco
    Marco New Member
    LT275 65 20 E rated like I have require 65psi front 70psi rear .i run them at 58 for good ride on 5100 top setting
  20. Jun 1, 2018 at 12:01 PM
    #50
    Beetlespin
    Beetlespin New Member
    2017 Tundra trd quicksand
    Does the change in tire pressures mess with the tpms?
  21. Jun 1, 2018 at 12:14 PM
    #51
    mudslinger79
    Christopher
    Williamsburg, Va
    Not that I can see. Mine are fine.
    Beetlespin[QUOTED] likes this.
  22. Apr 24, 2019 at 6:40 PM
    #52
    Marco
    Marco New Member
    I have LT 275 65 20 tires and 80psi max psi. I have 5100 on top setting and 65psi
    Is recommended but the ride is rough. I have 58 front 60 rear nice ride now.
    Lower psi on 10 ply E LT tires like below 45 the tire will heat up and the bead can break .
  23. Apr 25, 2019 at 5:34 AM
    #53
    SgtNewundies
    Eric
    Been running 38 front 36 rear on 10 ply tires for a while. The Tundra has even wear on the tires. My Tacoma has 70,000 miles on the E rated with the similar results.
  24. Apr 25, 2019 at 7:00 AM
    #54
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I ran my KO2's at 40 PSI, because I'm pretty sure that is what Discount Tire recommended. I drive mostly city and highway.
    I put just over 60K miles on those tires and I could've gone a little longer.
    When Discount Tire put new Wildpeaks on my truck they inflated them to 38 PSI.
    The ride is definitely smoother and quieter, but I'm not sure how much of this is due to tire pressure and how much is due to having brand new tires.
    I'll probably up it to 40 PSI just to see how I like it.
    Personally, I'm willing to put up with a somewhat harsher ride if it means better mpg and longer tire wear.
  25. Apr 25, 2019 at 8:12 AM
    #55
    neirbot
    neirbot New Member
    I run 50 psi on my 275/65r20 tires. Really nice (wife approved) ride with the 6112's.
  26. Jun 5, 2019 at 12:25 PM
    #56
    sundance
    sundance New Member
    All those ranges seem very high. Most people are running rims that won't handle the weight rating of a good E rated tire.
    I've run 42 front and 40 rear for multiple sets and over 100,000 miles. Seems like a good balance of wear/ride. If you get too low they will wear uneven and roar more. If you get too high, it will bounce all over creation. Just my penny.
  27. Jun 5, 2019 at 2:03 PM
    #57
    Could you snap a pic of that label please? I'm at 44 on mine.
  28. Jun 5, 2019 at 4:16 PM
    #58
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    I run 40 psi on my 10 ply
    correct rotation 5000 miles or so
    I put 115000 on my last ones set of cooper at3
    sundance likes this.
  29. Jun 5, 2019 at 4:27 PM
    #59
    Marco
    Marco New Member
    What is your max psi on your 285 55 20 tires side wall.
  30. Jun 5, 2019 at 5:17 PM
    #60
    Marco
    Marco New Member
    Mine are 80psi max 275 65 20 LT E my psi is 60psi
