10,000 mi oil change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra694, Mar 15, 2021.
  1. Mar 18, 2021 at 8:48 PM
    #91
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    1lowlife[QUOTED] likes this.
  2. Mar 18, 2021 at 8:58 PM
    #92
    TILLY
    Massachusetts
    Great info, can you post the Blackstone report when you get it back?
  3. Mar 19, 2021 at 5:30 AM
    #93
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Agreed
  4. Apr 5, 2021 at 9:54 AM
    #94
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    local oil change place puts 0W20 synth in and yet states the change interval at 3k ... I'm going somewhere between 5-7.5k regardless ... level always looks good, oil still has clarity well past 3k mi
  5. Apr 5, 2021 at 11:56 AM
    #95
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    For me, it's the lack of motivation to deal with the consequences of letting the "experts" at the dealership mess up my rig. Other than dealing with the stupid cartridge filter setup and the skid plate, it's not too bad doing it myself.
    Side topic - Mobil 1 rebates have kicked in. You can get 5 qts of M1 EP for $24-something at Walmart (delivered free, if you buy 2) with a $15 rebate up to $30 total (2 jugs).
    Roborob70, JohnLakeman and bleach like this.
  6. Apr 5, 2021 at 12:20 PM
    #96
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Get the walmart brand for $15 and it rates better than Mobil 1.
    TWJLee and bleach like this.
  7. Apr 5, 2021 at 3:29 PM
    #97
    PKFan
    $24 - $15 rebate = $9, so I think I'll go with the M1. I'll leave the SuperTech vs M1 comparisons to the folks on BITOG.
  8. Apr 5, 2021 at 9:12 PM
    #98
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It's getting rid of the used oil that seems to be a PITA.
    I rarely go to the local Autozone or O'Reilly's, but when I do, they always have signs up reading 'used oil return tank full' or 'not accepting used oil'...:mad:
    That is what stops me from changing my Tundra oil.
    I have a TRD Pro skid plate and would love to install a Fumoto Drain Valve, but getting rid of the old oil seems to be more trouble that it is worth around here..
    The Toro's annual change I can work around...:D
  9. Apr 5, 2021 at 9:23 PM
    #99
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    My dealer told me that 5k intervals are for if you’re actually using E85. If you were using higher grade (only) 10k was recommended.
    I have a FFV and do ever 10k with end result being dark golden brown.
  10. Apr 6, 2021 at 5:53 AM
    #100
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Thanks for the "heads-up" on the Mobil1 rebate starting. I knew their annual rebate usually begins in the Spring, and had been checking the website. Nothing...until your tip. Time to lay in the annual supply. :thumbsup:
  11. Apr 6, 2021 at 6:34 AM
    #101
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    My used oil goes on the big logs in the burn pile :anonymous::bananadead:
    Between the 8 qts from the tundra and the 14 qts from my 7.3, plus the 1 hr round trip to the parts store to dump my oil, burning it is the best thing I can do. Speaking of which I have to change the oil in both of them today after I put the new fuel pump on the 7.3
    Bammer likes this.
  12. Apr 6, 2021 at 8:15 AM
    #102
    Bammer
    Monroe, CT
    We recycle at work, so disposal is super easy for me.
  13. Apr 6, 2021 at 11:13 AM
    #103
    PKFan
    I guess I'm spoiled, as I get to put used oil out with the recycling. Just put a gallon jug out there today, as a matter of fact.
    I should have mentioned the Chevron rebates as well. Yesterday I got a check for $15, $5 for each 5 qt jug of dino 5W30 that I use in all our non-Tundra vehicles.
  14. Apr 6, 2021 at 11:56 AM
    #104
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    A lot of WalMart's take your old oil if they have an auto care center. (Especially if you buy oil from them.) Even says so here: https://www.walmart.com/ideas/auto-maintenance/how-to-change-your-oil/44109
  15. Apr 6, 2021 at 12:55 PM
    #105
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Pretty sure here in NY all service stations are required by law to accept used oil.
    Keeps folks from being irresponsible with disposal I would think.
    SPP
  16. Apr 6, 2021 at 2:19 PM
    #106
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Every 10k works for the Toyota engineers and that works for me. Anyone but me changes the engine oil....been there done that! I have better things to do in retirement:thumbsup:
  17. Apr 6, 2021 at 8:37 PM
    #107
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Change mine every 7500.
    Motul 5W-30
  18. Apr 6, 2021 at 8:44 PM
    #108
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    No downside other than cost. Dirty oil is dirty oil. 5k is cheap insurance in my book.
    OHwendTrd likes this.
  19. Apr 7, 2021 at 3:39 AM
    #109
    nodak67
    nodak67 New Member
    JR
    directly from the owners manual... pp 36
    when looking for the owners manual make sure you pick the Non FFV vs the FFV manual, they are different in regards to maintenance.
    the non FFV manual is missing the FFV paragraph on pp 36 and the oil change interval is on the 10k block of the maintenance log starting on pp 38 compared to the FFV manual showing the oil change is in the 5k & 10k block on pp 38
    link to non FFV toyota pdf : https://www.toyota.com/t3Portal/document/omms-s/T-MMS-18Tundra/pdf/T-MMS-18Tundra.pdf
    link to FFV toyota pdf : https://www.toyota.com/content/ebrochure/warranty/2018/T-MMS-18TundraFFV.pdf
    R65 likes this.
  20. Apr 7, 2021 at 3:55 AM
    #110
    nodak67
    nodak67 New Member
    JR
    just to add my dealer had no issue changing the oil every 5k on our FFV tundra. heck they even told me to bring it in before 24k to squeeze in the last free oil change under toyota care.
  21. Apr 7, 2021 at 6:32 AM
    #111
    Bammer
    Monroe, CT
    I used up my last free maintenance , 25k , so I said, please change the oil. $89.89 for synthetic , no bolts missing, no issues?? I might be having them do it in the future, as much as I distrust them, for that price its a no brainer.
    Oey12 likes this.
  22. Apr 7, 2021 at 6:47 AM
    #112
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    And prior to going you can remove the skid plate. This way you don’t have to worry about any of those missing bolts and such. 89.99 is definitely a no brainer...
    Bammer[QUOTED] likes this.
  23. Apr 7, 2021 at 7:05 AM
    #113
    clarkritchie
    clarkritchie New Member
    My local dealership shooed me away for the first Toyota Care oil change because I wasn't near 10K.
  24. Apr 7, 2021 at 7:35 AM
    #114
    JohnLakeman
    :D There's that. Plus, @Bammer can tell if they actually changed the oil by the color on the dipstick...maybe. :D
    But, then...How can he tell if they actually changed the filter? :notsure:
    Maybe "secret index marks" onto the filter cap to confirm the cap was actually moved? Bad news: Index marks are unchanged. Worse News: Index mark rotated a half turn more clockwise with around 200 ft-lbs of torque on it. :eek:
    I guess @Bammer could always crawl under and loosen/retorque the filter cap before he reinstalls the skid plate. :facepalm:
    Screw that. Not for 89.89, not for FREE!
    Bammer likes this.
  25. Apr 7, 2021 at 8:01 AM
    #115
    Bammer
    Monroe, CT
    Definite color change this time, I checked pre and post.
    I can't....
    Oh the insanity !
    If I'm crawling under, I'll just change it..
    NO !
    I hear ya, its a real struggle in my mind !!!!
    :notsure::notsure::notsure::notsure::notsure::notsure::notsure::notsure::notsure::notsure::notsure::notsure::notsure::sick:
  26. Apr 7, 2021 at 8:14 AM
    #116
    JeffMac
    Jeff
    South Florida
    Thanks for the info. It’s funny because my dealer does 15k oil changes for my vehicle. Obviously they don’t know whats going on especially since they put 75w90 in our T-case but that’s another topic lol. I’ve been doing my own for years at 10k with great results.
  27. Apr 7, 2021 at 8:30 AM
    #117
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Goes to show how ****ing good Toyota (and Honda) engines are if they can survive 300K Mi with 30 oil changes.
    I do mine every 6 months regardless of use, oil starts to breaks down from the first startup no matter how good it is. Toyota "brand" is crazy cheap for the quality.
    WILLINH likes this.
  28. Apr 7, 2021 at 7:20 PM
    #118
    llbts1
    llbts1 New Member
    2018 Tundra Limited
    I'm not trying to be argumentative, you can't dispute what the manual says regarding FFV. But, if you don't use flex fuel, and never plan to, why can't you run 10K oil changes on the FFV motor? What part of the motor could this damage? Without the FF, is this motor still harder on oil than the non FF? Can anybody answer these questions? Toyota couldn't.
  29. Apr 7, 2021 at 8:12 PM
    #119
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Motor is the same. Its an insurance policy should FF/e85 become contaminated w/ water(becomes acidic). Acid and engine oil aren't friends.
    The fuel system/ECM is different in a FFV(you use approx 30% more vs gasoline...or 30% worse MPG) so the ECM needs to account. If you run regular gasoline under regular use... regular oil changes.
  30. Apr 7, 2021 at 8:18 PM
    #120
    llbts1
    llbts1 New Member
    2018 Tundra Limited
    So regular oil changes meaning 10K miles?
