$1,000.00 upgrade
Discussion in 'Suspension' started by MAN N BLK, Aug 1, 2020.
  1. Aug 3, 2020 at 4:55 PM
    MAN N BLK
    MAN N BLK [OP] New Member
    Rickie
    2015 Black Tundra TRD CrewMax
    In time
    Ok so I’m ordering 6112’s. Currently running 285/65 AT revo2’s. So next I get to decide on new tires.
    MTRock likes this.
  2. Aug 3, 2020 at 5:13 PM
    MAN N BLK
    Rickie
    In time
    Another question.... will I need new isolators or anything else while I’ve got it apart?
  3. Aug 4, 2020 at 12:05 AM
    Tundrafan23
    Tundrafan23 New Member
    You never want to have differing pre-loads on shocks!
    JimboSlice413 and Hbjeff like this.
  4. Aug 4, 2020 at 12:07 AM
    Tundrafan23
    All Tundras are level at stock height, when you add a lift is when you start to see a lean.
    ckkone likes this.
  5. Aug 4, 2020 at 2:55 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Did you see the link I posted with the instructions from Bilstein?
  6. Aug 4, 2020 at 3:42 AM
    brobert225
    brobert225 Firm grasp of the obvious
    I installed Bilsteins on my 2015 and have no lean.
    MAN N BLK[OP] likes this.
  7. Aug 4, 2020 at 3:50 AM
    Tundrafan23
    That may apply for 4Runners, I am not familiar with the suspension on them, but for a Tundra it is much easier just to add a shim to the drivers side and keep the same preload on each shock.
    Hbjeff likes this.
  8. Aug 4, 2020 at 6:43 AM
    MAN N BLK
    Rickie
    In time
    Ordered 6112’s last night. I’m so fkn excited!
    MotoTundra, Hbjeff and MTRock like this.
  9. Aug 4, 2020 at 9:00 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    As long as you have the correct coil selected preload does not matter until the preload force is greater than the corner weight of the truck. Adding a shim increases the effective length of the shock. IIRC, the factory "coilovers" come preloaded differently from the factory to account for the lean. IIRC there is a specific drivers vs passenger side coilover or spring that accounts for the lean. I could be wrong but thats what I recall from my research.
    Darkness and Hbjeff like this.
  10. Aug 4, 2020 at 9:00 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    Congrats!!!
    MAN N BLK[QUOTED][OP] likes this.
  11. Aug 4, 2020 at 10:27 AM
    MAN N BLK
    Rickie
    In time
    Would Toytec add a little more to one and mark it as drivers side? I just ordered online so I haven’t contacted them on phone. But curious if maybe that’s an option. Any adjustments would be blind since they don’t know if it will lean or not I guess. Are they easy to adjust on the truck? I’m full of questions eh?!
  12. Aug 4, 2020 at 10:35 AM
    MAN N BLK
    Rickie
    In time
    Never mind that question about adjusting. I read back through replies.
  13. Aug 5, 2020 at 12:40 PM
    MAN N BLK
    Rickie
    In time
    6112’s shipped out today! So should I order shims and install on both sides for a little more lift? Or just order them to have just in case she leans after install? How far back in do I have to go to add shim if needed after install?
    MotoTundra and Hbjeff like this.
  14. Aug 5, 2020 at 12:44 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    If you do not have the lean now, I doubt you will have the lean after the install of the 6112s. But if you want to order them to have if you think you will need them then I would order them.
  15. Aug 5, 2020 at 1:15 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    I would pass on the shims
  16. Aug 5, 2020 at 1:32 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You don’t want shims on a 6112. They are already longer on full compression than stock(Thus the bumpstop extension). Adding shims will hurt your up travel even more for little gain
    Ace402 likes this.
  17. Aug 5, 2020 at 5:39 PM
    MAN N BLK
    Rickie
    In time
    So do I need bump stop extensions?
  18. Aug 5, 2020 at 8:07 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    they come with the 6112
  19. Aug 6, 2020 at 6:48 AM
    #49
    MAN N BLK
    Rickie
    In time
    Says they will arrive on Saturday! :bananadance::bananadance:
    Hbjeff likes this.
  20. Aug 8, 2020 at 2:52 PM
    #50
    MAN N BLK
    Rickie
    In time
    6112’s have arrived! Thanks Toytec!
    Darkness, MotoTundra and Geo4x4 like this.
  21. Aug 8, 2020 at 5:23 PM
    #51
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    Awesome! Let us know what you think of the ride quality!
  22. Aug 8, 2020 at 5:27 PM
    #52
    AZBoatHauler
    So.Arizona
    Mine had lean from the factory. Many others on here have reported the same. Always driver’s side that is lower - usually more in the back than front.
  23. Aug 8, 2020 at 5:32 PM
    #53
    MAN N BLK
    Rickie
    In time
    So many on here set at top setting or at 1.9 with shims. So confusing. I ordered at 1.9 but........:annoyed:
  24. Aug 8, 2020 at 6:07 PM
    #54
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    I think you made the right move. I would install without shims.
  25. Aug 8, 2020 at 6:17 PM
    #55
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    installing shims (On both sides) on 1.9 setting is just ill informed and incorrect. You did the Right choice. 2 inch is the sweet spot for lifting our IFS. Any more and it is just serious ride deterioration
    Darkness likes this.
  26. Aug 8, 2020 at 7:56 PM
    #56
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    With just $1k, I would either save more for the suspension I want instead of settling or spend near $1k for TRD Pro LED Headlight’s
    My favorite mod.
  27. Aug 8, 2020 at 8:41 PM
    #57
    MotoTundra
    MotoTundra The Ocho
    Don
    Haha show us!!
  28. Aug 9, 2020 at 4:16 AM
    #58
    Tundrafan23
    Adding shims does absolutely NOTHING to change the ride! You are not changing the preload at all, you are basically just lengthening the shock!
  29. Aug 9, 2020 at 4:18 AM
    #59
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Gosh there is so many stupid comments in here. Congrats on the coils and being able to decipher the ignorance
  30. Aug 9, 2020 at 5:27 AM
    #60
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    Why do you want to lengthen the shock. You are just making a small spacer kit. Have you seen the photos of all the broken suspension due to spacer lifts?
