1” Rear Blocks with Bilstein 5100s On Top Setting?
Discussion in 'California' started by MULLI63, Nov 11, 2022.
  1. Nov 11, 2022 at 8:58 AM
    MULLI63
    MULLI63 [OP] New Member
    Southern California
    2015 Tundra Platinum, SnugTop Shell, Gray
    Bilstein 5100 all four corners - front at top setting Ready Lift 1” rear block 295/70R18 Falken Wildpeak Method Roost R18 Under Seat Storage Boxes - Rear Seats - see post LED Interior Lights LED Mirror, Back-Up and License Plate Lights Added Auxiliary Fuse Box and Battery Switch Plasti-Dip Chrome Mirror Covers and All Badges to Black WeatherTech Bed/Tailgate Liner Replaced tailgate strut Working On Modifications: Add Oh Sh!t Handle To Driver Side A Pillar LED Head and Fog Lights
    Know many threads on the 5100s but wanted to get straight answer for this.
    Have the 5100 front struts ready to install and will be on top setting.
    Do I need 1” blocks in rear to level? Would the 1” blocks keep the stock take?
    Will be putting Method 308 R18 w/25mm offset. Topping those with Falken Wild Peak 295/70R18.
    Thanks,
  2. Nov 11, 2022 at 9:00 AM
    Blueknights75
    Ron
    Clayton, NC
    My 5100 top setting has me perfectly level with no work done to the rear.
    Sierradevil likes this.
  3. Nov 11, 2022 at 9:10 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I ended up with 2.5 front lift with the setting I used on my 6112 and the truck sat level.
    Looks nose high but measures level.
    763B91DF-899D-4443-A7EC-B9CE39DA5452_zps_40bc24ad3f26a52479708d1be3d2d728905eb2e0.jpg
    I lifted the rear an inch with Toytec shackles..
    91CBAE5D-765D-497E-9830-48F25491821C_zps_d45f443a4ae0aa57b3c4c170003b1505c5c1a2bd.jpg
    I would do the front first and then see if you want the rear lift.
    It won't hurt to run if the front high for a week or 2.
    Just don't make the mistake I did and put the shackles on the higher setting and have to move them..:eek2::D
    3A454AD2-178D-41E0-9D0A-73D2DE1ED55E_zps_553749102fba077d425fd249d556e3abf51d3d44.jpg
  4. Nov 11, 2022 at 10:17 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Your truck has 2 inches of rake if all the springs are in good condition. So a 2 inch lift in front levels the truck (just like the TRD pro).
    If you go up 2.5 in front, you will need a bit of lift if the rear to keep rake.
    I would skip the block, nothing good comes from running a lift block on leaf springs. Ride is impacted and a block will wear the leafs prematurely. Lift shackles would be better. And RAS would be better than the shackles and give you about an inch lift in the rear, no impact on ride and RAS helps support the leafs for no sag when towing/hauling.
  5. Nov 14, 2022 at 1:18 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i have 1" blocks in the rear but plan on completely redoing the leaf pack & shackles in the next year
  6. Nov 14, 2022 at 4:27 PM
    MULLI63
    Southern California
    So it sits with a rake? Similar to the stock rake?
  7. Nov 14, 2022 at 5:31 PM
    Steelruger22
    Steelruger22 New Member
    Aaron
    All over the place
    2016 Tundra Silver Sky Double Cab
    Leer Topper, Platinum Bumpers, Limited Grill, TRD Skid plate+cat plate, 5100's all 4 corners, Rear Airlift Bags, Compass/smartlink rearview mirror, Ditch Lights, LED Headlights/Fog lights, Husky Mats, Fog Light mod, DRL Delete, Window vents, Marathon Seat Covers.
    I have the exact setup that your asking about. 5100s on all 4 corners. Fronts on top setting. After the shocks I measured all 4 corners and only had a 1/2" of rake. While it measured almost level I thought it looked like the "cali bro" lean, which is something that I detest. I added the 1" blocks to the rear(wasn't going to run them but I already had them on hand) and was very happy with the results. I really like the stance now. I also have rear airbags that I keep at only 5psi unloaded. No complaints about ride quality and 1" blocks don't cause any issues with axle warp or driveshaft vibrations. I personally wouldn't run a block over 1 5", but people do it. I can take some pics tomorrow and show you how she sits if you'd like.
    biebs96 likes this.
  8. Nov 14, 2022 at 6:12 PM
    biebs96
    PA
    I have 5100s on the middle setting, with a 1” block in rear (as previous owner stated, I had them on hand and installed them same day)
    I have a decent rake, very matched to factory.
    I know if I load up my bed or carry my utility trailer maxed out (2.5k plus trailer 1k), I am sitting just over level while still maintaining rake in the rear.
  9. Nov 16, 2022 at 3:00 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    nope. eibachs (basically 5100 clones but made better) on the top clip because why not?
    BravoDeltaRomeo likes this.
  10. Nov 21, 2022 at 8:09 AM
    MULLI63
    Southern California
    Would like to see pics when you have the time. Might order the 1” blocks just to have them on hand if I don’t like the look without. What blocks did you order and from where?
    Also, what wheels / tires (size) are you running?
  11. Nov 21, 2022 at 2:30 PM
    Steelruger22
    Aaron
    All over the place
    Yeah man, I'll get them to you in the next couple of days. Right in the middle of moving into a new house.
  12. Nov 21, 2022 at 2:59 PM
    MULLI63
    Southern California
    please take your time. Busy enough with thanksgiving week and you are moving.
    I just ordered the blocks to have them if needed.
    have a great turkey day!
  13. Nov 21, 2022 at 5:38 PM
    Steelruger22
    Aaron
    All over the place
    Cool man. But mine are Toytec 1" blocks. Rim and tire setup right now is Rock Warriors w/ 285/70r17s. Running 1" wheel spacers on all corners. Really like the stance. Can't wait to put some new shoes on her when these wear out. I'll get you those pics soon.
  14. Nov 21, 2022 at 7:08 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Check out my build page for your answer(s).
  15. Jan 21, 2023 at 5:51 PM
    MULLI63
    Southern California
    Well did the 5100s on all four corners.
    Added ReadyLift 1” inch block in rear.
    Also added 1/4” plate spacer to front driver side above strut to level out the Tundra Tilt. Remains to be seen if that worked.
    Looks great. Looks level maybe a tiny bit of rake though I have not measured yet.
    Tires are 295/70R18 Falken Wildpeak on Method 308s.
    Pics are in my driveway that tilts down toward the front of the truck.
    Some rubbing in front I will take care of with a tuck job of the wheel well liners.
    brevard828 likes this.
  16. Jan 21, 2023 at 7:34 PM
    Labrayota
    Labrayota New Member
    Central Illinois
    2017 Crewmax TRD Off Road MGM
    That looks good! I like it!
    MULLI63[OP] likes this.
