08 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by ToyotaCm, Mar 1, 2021.
  1. Mar 1, 2021 at 8:58 AM
    ToyotaCm
    ToyotaCm [OP] New Member
    Carrie
    08 Tundra
    Hello I have an 08 Tundra that has been make a noise. So I had the all the pulleys replaced, water pump and alternator replaced thinks this is the sound, but didn't fix it. So I just took it to a Toyota dealership to see if they could figure it out. They told these nothing wrong with it. It makes a noise that sounds like chain hitting together them quits. It very loud, has anyone else heard this or had this happen to there truck.
    Rex Kramer likes this.
  2. Mar 1, 2021 at 9:00 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My 2007 5.7 is just about to hit 300,000 miles, and it sounds like a diesel clacking & ticking.
    It runs great, no codes, no issues, just noisy.
  3. Mar 1, 2021 at 9:12 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome to the Tundra forum.
  4. Mar 1, 2021 at 9:15 AM
    ToyotaCm
    Carrie
    08 Tundra
    Thank you
  5. Mar 1, 2021 at 9:54 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Pour about 1/4 of a can of Seafoam into the engine oil and see if it goes away.
  6. Mar 1, 2021 at 10:08 AM
    TTCrewmax
    TTCrewmax New Member
    Sounds like Timing Chain Tensioner. If the noise only happens when you first start the truck then my guess would be that. Somewhat common component that needs to be replaced as the mileage increases on the motor.
    snivilous likes this.
  7. Mar 1, 2021 at 10:20 AM
    ToyotaCm
    Carrie
    08 Tundra
    I asked if it could be the timing chain tensioners and they said they've never had any issues with them. It doesn't make the noise often just on occasions when starting up I also get a squeal noise from it as well when it first starts doing that noise.
  8. Mar 1, 2021 at 10:25 AM
    TXTundraFan
    TXTundraFan New Member
    Mine squeals upon start up, especially when it's been wet outside. Usually it goes away after a few seconds but lately it's been several minutes before it goes away. 217.5K miles on a 2010 5.7L
  9. Mar 1, 2021 at 11:08 AM
    Rex Kramer
    Georgia
    I had the same issue in 2017 when it was really damp & foggy, but it just went away later that year and never came back.
  10. Mar 1, 2021 at 2:22 PM
    TTCrewmax
    If it's a squeal then my bet is serpentine belt. If it's a clunky chain like noise then timing chain.
  11. Mar 1, 2021 at 3:04 PM
    audiowize
    Paul B.
