08 Tundra
Discussion in '2nd Gen Builds (2007-2013)' started by Big Ben, May 2, 2018.
  1. May 2, 2018 at 7:50 AM
    Big Ben
    Big Ben [OP] New Member
    Ben
    2008 Toyota Tundra
    My 08 tundra will crank and then shut down. It will do it a couple of times and I let it sit for a couple of minutes and then it will crank and run like nothing is wrong with it. It has happened twice in the past 3 weeks. Any clue what is going on?
  2. May 2, 2018 at 7:56 AM
    Miles?
    You need air, spark, fuel.
    I’m betting your losing prime on your fuel system. First time you crank the system is priming, second time it starts normally.
    If your over 100k miles, have you swapped out the old spark plugs yet? I believe the service was at 120k miles, but I would do them much earlier than that.
  3. May 2, 2018 at 8:09 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Ben.
  4. May 2, 2018 at 8:46 AM
    Big Ben
    Ben
    2008 Toyota Tundra
    It has 142k on it. I’m going to replace plugs this weekend.
