08 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Jojococomo, Apr 10, 2025.
  1. Apr 10, 2025 at 7:54 PM
    Jojococomo
    Jojococomo [OP] New Member
    08 king cab V8 tundra 4wd
    My step dad with memory issues put the battery in backwards.... Iv checked fuses an replaced. Replaced the brake light switch on the gas pedal I still cannot get my vehicle out of gear and I do not have any lights or brake lights what's my next step cuz I'm stuck?
  2. Apr 10, 2025 at 8:15 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check more fuses below the dash.
  3. Apr 10, 2025 at 8:17 PM
    Jojococomo
    Iv checked all fuses under the hood an interior of truck an replaced needed fuses
  4. Apr 10, 2025 at 8:19 PM
    blackdemon_tt
    Maybe the body ecu is toast, but I would wait for other's input.
  5. Apr 10, 2025 at 8:21 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I want to say there is a "master" fuse that you need to check. Not sure if under hood or in cab.
    Good luck!
  6. Apr 10, 2025 at 8:38 PM
    Jojococomo
    The truck runs an starts... Just have no lights or brake lights... And can't shift out of park
  7. Apr 11, 2025 at 3:57 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Tow the truck to dealer, let step-daddy fix on his dime since he f**ked it up.
  8. Apr 11, 2025 at 4:01 AM
    Jojococomo
    While that maybe nice to have happen... I support my father completely an truthfully don't have the financial ability to afford a shop to fix said issue
  9. Apr 11, 2025 at 4:02 AM
    Jojococomo
    Anyways any advise would be much appreciated an excepted concerning my trucks issue...
  10. Apr 11, 2025 at 4:51 AM
    koditten
    Kirk
    Midland of the Mitten
    I think you are on the right track. You can't get the truck out of park if you have a bad brake lights.
    Double check the cab fuses. They are a pain to get to, but meter each fuse for conductivity.
  11. Apr 11, 2025 at 10:23 AM
    Jojococomo
    Ok ... But I have checked each fuse several times over... How do I check the light bulbs at the rear of truck? Forgive me... But I'v never been in automotive repair tell now...
  12. Apr 12, 2025 at 10:11 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    You say no lights or brake lights, do you mean no headlights & parking lights or no interior lights? And the warning lights on the dash check good when you turn the key on but don’t light up when you start the truck?
    It seems like when this has happened in the past on this forum it often blows one of the main fuses (150-180 amp). But that usually would cause more issues than just lights.
  13. Apr 14, 2025 at 4:28 PM
    Jojococomo
    I can't get it out of gear either! An I have no headlights tail lights or brake lights! Everything seems good on the dash board though
