08 Tundra sounds like it has exhaust leak up front
Discussion in '2nd Gen Tundras (2007-2013)' started by JerseyTundra, Jun 5, 2016.
  1. Jun 5, 2016 at 4:36 PM
    JerseyTundra
    JerseyTundra [OP] New Member
    08 Silver Tundra DC Limited 4x4
    Bilstein 5100's all corners, AVS aero skin bug shield , Avs ventvisors, Husky x-act fit liners, Extang Trifecta signature series bed cover, TRD shift knob, TRD cup holder inserts, Front eyebrow LED lights with toggle kill switch.
    I have a 08 Tundra with only 36000 miles purchased 6 months ago . Recently driving with windows up I noticed a exhaust leak type flutter sound up front when on the gas. When idling can't really here it. I hope it is not anything major. Annoying as hell. I have to get it checked out soon. Unfortunately not under warranty. On top of that that my transmission on 2 occasions has missed when on the gas hard. I am starting to believe I may have made a mistake. The Carfax was clean when purchased but I know that does not always tell the whole story. Anyone else ever have this issue with such a low mile truck. Did 08's have issues with cracked manifolds. I don't know but I am really pissed the hell off for i paid a decent amount for this truck to deal with this B.S.
    Mnorris1206 likes this.
  2. Jun 5, 2016 at 4:42 PM
    Never heard of any issues to what you're describing.
    Hell, first trans drain and fill is @60k.
  3. Jun 5, 2016 at 5:18 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I had the same issue with what I thought was an exhaust leak a few months ago. Had the Master Tech at my dealership take a ride with me, he said most of the 2nd gens sound like that once they get over 50-60k miles? Hell if I know.
  4. Jun 5, 2016 at 5:32 PM
    JerseyTundra
    If he is a master tech then I am the President. Mine has only 36700 miles on it. I am no master tech but I sure know it did not sound like this when I purchased it. And it sure does not sound normal to me. But thanks for the info though.
  5. Jun 5, 2016 at 8:28 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Just what I know man.
    Rica25 likes this.
  6. Jun 5, 2016 at 10:33 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Post up some video of the sound. If you open the hood and just hit the gas in park does it make the noise you describe? Could it be a bearing going out on a pulley? Not ruling out a gasket failure or crack on the exhaust manifold thought, just a thought.
    Might want to just to the tranny flush and fill to ensure its at the right level. Shouldn't be having issues that soon.
    Rica25 likes this.
  7. Jun 6, 2016 at 11:49 AM
    JerseyTundra
    Called local shop today. If indeed cracked manifold (which they say is common) they can weld it. 4-5 hours labor. Looking at around $500 bucks. Or you're talking $500 for new manifold and $500 for labor. Think I may go the weld route. To be continued.......
  8. Jun 6, 2016 at 4:57 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Hey Jersey Tundra, I did some reading on this common problem and I would look at your steering seal. It may be a cracked seal. They say it will have or cause that ticking sound. $20 fix. And as a welder for 25+ years, 4-5 hrs seem a little much to me. Depending on prep time and length of crack, 2 hrs at the most. My opinion that is. Hope this helps
    camillethetoy likes this.
  9. Jun 6, 2016 at 5:22 PM
    JerseyTundra
    Thanks rons23. I will look into it. The labor is removing the manifold, welding and putting back together. That is if it is the problem. Definitely sounds like a exhaust leak to me. Thank you for the info.
  10. Jun 6, 2016 at 5:23 PM
    rons23
    Ron
    Kill Devil Hills
    Good luck man, hopefully it's nothing serious.
  11. Jun 6, 2016 at 5:27 PM
    JerseyTundra
    Thanks man. Me too. Keep you posted :thumbsup:
    rons23[QUOTED] likes this.
  12. Jun 6, 2016 at 5:33 PM
    rons23
    Ron
    Kill Devil Hills
    Oh by the way, how are them leds you installed in the lower panels. I got the same ones and had them color matched, but haven't installed yet as I'm gonna do a retrofit and do it all at once.
  13. Jun 6, 2016 at 5:47 PM
    JerseyTundra
    Doing good. Knock on wood..... I had a toggle installed so I can shut them off when I want. You should do the same. Might save some life. I have a new set of Nfab stainless chrome nerf bars waiting to go on. After I figure out what is going on I will install.
    Rica25 and rons23 like this.
  14. Jun 17, 2016 at 9:41 AM
    JerseyTundra
    Turns out it was a piece that comes off the manifold that was pressed on in two spots from factory broke off all the way. The shop is going to weld it back together. Looking at around 5 bills for the work I hope . Waiting for the call. He said he would take a picture of it. Will post a pic of the failed part when I get it. I did not know the truck already came with like a factory type header on it...... That is good.
    Rica25 likes this.
  15. Jan 24, 2019 at 12:24 PM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    Where the pic man?
    Rica25 likes this.
  16. Jan 25, 2019 at 2:31 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    It happened almost 3 years ago
    Rica25 likes this.
  17. Jan 26, 2019 at 1:03 PM
    swank501
    swank501 New Member
    2007 single cab 4x4
    Ok. Still want to see a pic if available.
  18. Jan 26, 2019 at 1:21 PM
    Mnorris1206
    08 tundra
    I have this with my 08. Not sure if it is a manafold crack of just gasket I'm thinking gasket only because when its hot out and I'm driving the sound goes away when truck is warm. O I have 80k miles right now .It started around 56k miles or so .
