08 Trailer Wiring pinout problems
Discussion in 'Towing & Hauling' started by Duhockey, Oct 6, 2020.
  1. Oct 6, 2020 at 8:26 PM
    Duhockey
    Duhockey [OP] New Member
    2008 Tundra Limited
    BSD lift, Tough Country Deluxe bumper, compustar remote start/security, rino lining, XD wheels,
    So the 7 pin connector on my truck is corroded and the plastic around the connector was brittle and broke off when I pushed the trailer connection into it.
    I bought another connector that I was going to wire in. I would cut the Toyota connector off and put this new connector on that I got at a trailer store. Before I cut the wires I noticed a few issues. First the pinout on the Toyota harness is clockwise from 1:
    1. White 2. blue 3. Green 4. Black 5. Brown 6. Yellow/gray and 7. Gray.
    The connector I bought is clockwise from 1:
    1. White 2. Blue 6. Brown 4. Black 3. Green 5. Red center (7)
    So first off, Toyota doesn't have a red. Instead a yellow/gray. And notice the order of the new connector is completely different than the Toyota wires. Do I wire it the way the Toyota wires are on the connector right now? Or per the pinout on the actual replacement connector?
    Anyone have a wiring diagram for the Toyota connector?
  2. Oct 6, 2020 at 10:14 PM
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    Wire it such that the oem wires will be in the same position they were in.
    Duhockey[OP] and 1lowlife like this.
  3. Oct 6, 2020 at 10:24 PM
    runCMD
    runCMD BAMF Nerd
    To add - I can’t imagine the connectors on the back are in a different position than the sockets on the front of the plug but you can check with a continuity test on a multimeter. I suspect the numbering is arbitrary.
  4. Oct 6, 2020 at 10:24 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ What he said.
    The colors stamped on the plug don't matter..
    Duhockey[OP] and runCMD[QUOTED] like this.
