08' SR5 Backup Cam connection question
Discussion in 'Audio & Video' started by Walter_Sobchak, Aug 18, 2017.
  1. Aug 18, 2017 at 8:53 AM
    Walter_Sobchak
    Walter_Sobchak [OP] Calmer than you are.
    DFW Texas
    2018 Blue SR5 Crewmax
    I bought a back up cam that has the RCA cables thinking I would need to run them into the cab. After further investigation I found that I have a connection near my tailgate. Is there an adapter I can purchase to utilize this connector or will I need to run the RCA wire to the new head unit?
  2. Aug 18, 2017 at 9:48 AM
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    I'm sorry but I can't answer your question. What camera did you buy?
  3. Aug 18, 2017 at 9:50 AM
    Walter_Sobchak
    DFW Texas
  4. Aug 18, 2017 at 10:13 AM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    There is a connector under the truck on the left. There has been much debate as to whether it's truly pre-wired, depending on trim level. Some go only part way and have an open connector somewhere inside the cab. Some go to the overhead console for the rear view mirror monitor. I have the same camera and found it easier to use the RCA cables and go directly from the camera to the underside of the dash.
  5. Aug 18, 2017 at 10:22 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Is this a factory stock radio?
