08' 5.7 4x4 is losing power
Discussion in '2nd Gen Tundras (2007-2013)' started by Badfish74, Oct 14, 2019.
  1. Oct 14, 2019 at 6:34 PM
    Badfish74
    Badfish74 [OP] New Member
    08' tundra crewmax 4x4
    Hi everyone. I'm totally stumped here. 2008 tundra crewmax 4x4 is failing at anything after 1/2 throttle. I'm at 214xxx miles. It only seems to be doing this while in gear. I can floor it in park or neutral and it revs to the moon. However while driving, it falls on its face. Very noticable while cruising on the interstate and trying to pass someone or going up a hill. It really seems like it's a certain spot in the foot pedal rather than a certain rpm. FYI, tried a new MAF sensor, cleaned TB, new air cleaner (stock airbox) , new plugs. Oh and no CEL either. I tried searching a solution before posting but I didnt have much luck. Any help is greatly appreciated
  2. Oct 14, 2019 at 6:45 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    To be completely honest it sounds more like a transmission issue than an engine issue. I'd love to hear other members' opinions.
    If there was some sort of misfire or lean/ rich issue causing poor performance then A) it would do it in all gears including park and neutral and B) you would surely have an illuminated malfunction indicator lamp.
    If it were me I would start by doing a transmission service including dropping the pan, changing the filter, and filling it back up to spec. If that helps, I would do a few more drain and refills every few hundred miles until the fluid you drain out still looks close brand new.
    MS22 and Black Wolf like this.
  3. Oct 14, 2019 at 6:50 PM
  4. Oct 14, 2019 at 7:01 PM
    Badfish74
    Do our trucks require toyota specific fluid or is their an aftermarket fluid thats acceptable?
  5. Oct 14, 2019 at 7:56 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Your owners manual will tell you type and capacity for every fluid in the truck.
    They call for Toyota WS ATF which is a non synthetic fluid generally good for 100K miles (depending on usage).
    The only manufacturer I know of making an ATF compatible to WS is Valvoline max life synthetic. It's in a red jug. Plenty of people have had good experience with it.
    ColoradoTJ likes this.
  6. Oct 14, 2019 at 8:37 PM
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
    What about when you manually shift it?
  7. Oct 14, 2019 at 8:39 PM
    Badfish74
    It does the same thing when manually shifted
  8. Oct 14, 2019 at 9:41 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Fuel pump.
    Ericsopa and ColoradoTJ like this.
  9. Oct 14, 2019 at 9:48 PM
    I would check the following:
    - fuel rail pressure. Test kits are relatively cheap. May even have one for rent at a local parts store.
    - I have had on other manufacturers engines have a throttle position sensor have a dead spot and not trip a CEL. I also own a Jeep that has had a CEL light for the TPS for the past 9 years and it’s been replaced 3 times.
    -The transmission sounds suspect to me as well. I would get a service done.
  10. Oct 15, 2019 at 12:50 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    It sounds like fuel issue to me. Check out the fuel filter.
  11. Oct 15, 2019 at 3:52 AM
    Badfish74
    Trans needs to be done so I'll do a filter, drain, and fill.
    And try to work on the other areas to see if I can get this cleared up.
    GODZILLA likes this.
  12. Oct 15, 2019 at 6:50 AM
    Badfish74
    I dont believe the 08 has a standalone filter. It's part of the fuel pump correct?
    Rex Kramer likes this.
  13. Oct 15, 2019 at 8:16 AM
    Badfish74
    I tried to google it but got nothing. do the 2nd gen tundras have fuel pressure regulators?
  14. Oct 15, 2019 at 10:16 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Could be a disintegrating Cat that is blocking the exhaust. It's possible that you you wouldn't notice it when the engine is not under load. You should notice a change in the exhaust note when this happens if this is it.
  15. Oct 16, 2019 at 1:09 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    Yes.
  16. Oct 16, 2019 at 2:16 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Aren't the CEL being on, with Jeep's, standard. I was thinking they come from the factory that way.
    :boink:
  17. Oct 16, 2019 at 4:11 AM
    Ha! I do believe you’re correct sir.
    For as much as the damn things cost now days, one would think some reliability would come with that cost.
    easleycrawler[QUOTED] likes this.
  18. Oct 16, 2019 at 4:21 AM
    easleycrawler
    Travis
    As much crap as I've gave you about Jeep's, I sure hope you don't end up being my secret Santa, cause I will definitely get something with the word jeep on it. Lol
  19. Oct 17, 2019 at 4:04 PM
    Badfish74
    I picked up a fuel pressure test kit today and ran a test. Key on pressure, 41. Start/idle pressure, 41.
    I took it a step further and rigged the gauge up to the windshield, under the windshield wiper and went for a drive. Here's where things failed. All good up to about 3000rpm. After that it starts dropping and the more I pushed the pedal down, the lower the pressure got.
    I disconnected the vacuum line from the air intake to the fuel pressure regulator and performance improved however it still wasnt how it should be.
    Now is this 100% fuel pump or just a bad pressure regulator?
  20. Oct 17, 2019 at 4:27 PM
    How far did the pressure drop when on the drive?
  21. Oct 17, 2019 at 4:49 PM
    Badfish74
    I didn't get exact numbers (angle of gauge agaisnt windshield+me driving+other cars+60mph=disaster) but roughly in the 20's.
  22. Oct 17, 2019 at 4:53 PM
    Sounds like a fuel pump to me. Fuel pressure regulators that are failing have different symptoms.
  23. Oct 17, 2019 at 7:48 PM
    ND_Porkchop
    Neat, good test
  24. Dec 10, 2019 at 10:41 AM
    Badfish74
    Ok so I'm lazy and still haven't dropped my tank yet. But here's a thought... does anyone know anything about the fuel pump controller mounted on the inner drivers side frame rail above the rear axle? Seen somewhere else on the interwebs that someone bypassed or jumped a wire on theirs. How?
    The odd thing is I'm fine up until about 2500rpm. That's when everything drops (power, acceleration, etc) to zero.
  25. Dec 10, 2019 at 10:46 AM
    Badfish74
    The part I'm referring to is 89570-34010
  26. Dec 10, 2019 at 2:35 PM
    Lifeislarge
    Lifeislarge New Member
    2007 Tundra 4X4 TRD 5.7L
    Sounds like you're being lazy and looking for the easy way out. Run it down till the light comes on and replace your faulty fuel pump already. You can do more damage than you think running it low on fuel. Fuel cools valves and the tops of the pistons before ignition and if you're starving it you could burn a hole in it somewhere.
  27. Dec 10, 2019 at 2:49 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    My first thought....
  28. Dec 10, 2019 at 3:09 PM
    Larly5000
    NV
    07 Crewmax
    Not really that odd. Its tell tale behavior of a bad fuel pump.
    Lifeislarge likes this.
  29. Dec 10, 2019 at 3:21 PM
    Badfish74
    Not true. I just dont want to dump $400 on a new fuel pump then find out it's not it. I'll splurge on a new pump if I 100% know that's it.
  30. Dec 10, 2019 at 3:31 PM
    Lifeislarge
    You did a fuel pressure test and it failed. You have the classic symptoms of a bad fuel pump. Unless you have some phantom voltage drop going to the fuel pump causing it to slow down at 2500 RPM it's dying. You can always test fuel pressure before the filter to see if it drops there but you'll need the right adapter to put it in-line. KISS usually wins in the end.
