'07-20 TOYOTA TUNDRA SDHQ BUILT TRACTION BAR KIT
Discussion in 'SDHQ Offroad' started by sdhq_offroad, May 29, 2020.
  1. May 29, 2020 at 5:29 PM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    PRODUCT OVERVIEW:
    Our #SDHQBuilt Traction Bar Kit for the 2007-2020 Toyota Tundra is designed to improve drivability, stability, acceleration, and control axle wrap. Our kit is 100% bolt-on, 100% American made and manufactured in-house.
    KEY FEATURES:
    • Fits 2007-2020 Toyota Tundras
    • Designed to help prevent axle wrap while not limiting travel or adversely affecting ride quality
    • 3D CAD designed, engineered & built in-house for our typical SDHQ Built quality, fit, and finish
    • Designed to work with these rear leaf spring configurations:
      • Icon rear expansion pack
      • Icon RXT spring pack
      • Stock OEM spring pack
      • Stock OEM spring pack with add-A-leaf kits that retain the overload spring
      • Most Deaver sprung over packs
    • Clearance Specs:
      • Rear: 1/2" of clearance gained at the rear axle
      • Front: Zero loss of clearance if you have a fuel skid plate & 1/4" of clearance loss at the shackle near the gas tank if you do not have a gas tank skid plate
    • Works with lifts up to 6” - The 6" lift is measured at the front which will, in turn, lift the rear 4" to level out the Tundra
    • Designed to control axle wrap common with progressive multi-rate leaf springs
    • Prevents driveline damage caused by axle wrap
    • Greatly improves drivability, stability, and acceleration
    • No need to remove leaf springs for install
    • No cutting, drilling, or welding is required for install, 100% bolt-on
    • Ships powder-coated our SDHQ standard textured black
    • We include 8" u-bolts which work with most spring configurations with no block
    • Our kit is 100% American made and manufactured in-house
    TECH INFO:
    • Designed to work with the following Tundra Cab and Bed Configurations
      • Crew Max Cab Configuration (5.5ft Bed)
      • Double or Single Cab Configuration (6.5ft Bed)
    • If you are running a lift block with your spring pack now, new u-bolts may have to be purchased separately. The new u-bolts will be the same size as what you have now. We always recommend replacing your u-bolts because a previously torqued U-bolt will suffer from distorted threads. U-bolt nuts should be tightened once and re-torqued, never loosened and retightened.
    WHAT'S INCLUDED:
    • All fabricated components are manufactured in-house
      • Qty 2-Frame Mounts
      • Qty 2-Axle Mounts
      • Qty 2-Traction Bars
      • Qty 4-Shackles Plates
      • Qty 2-7/16" Frame Clamp Brackets
      • Qty 1-Complete Hardware Kit
        • Includes FK Heims
    Benefits of our traction bar kit over ones currently on the market:
    • Greatly improved ground clearance, pivot points are tucked up in front of the axle
    • Transfers energy into the frame with no added stress to the leaf spring
    • Does not add any noise, vibration or harshness
    • Originally designed for off-road use where travel and articulation are much greater than at the track, yet still performs 100% on the street, at the track, or towing.
    • Does not limit travel or change the leaf springs natural arc path or pinion angle.
    • Does not require removing leaf spring bushing for install.
    • Does not require removing the leaf springs for install.
    • Does not require cutting, drilling, or welding for install.
    • No core charge.
  2. Jul 12, 2020 at 8:52 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    So in the video on the product list page the dude mentions a modified version coming out for those with lift kits. More info, @sdhq_offroad?
  3. Jul 13, 2020 at 9:24 AM
    sdhq_offroad
    GILBERT, AZ
    We were thinking that we were going to need to make a different length for 6-7" lifted trucks (4-5" of lift in the make) but it was not required. We include 2 different length spacers that go on the bumpstop so you can adjust the engagement point to your liking. So these will fit from stock to 5" of lift in the rear.
    Rica25 likes this.
  4. Jul 13, 2020 at 11:35 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    id assume i would be fine but i run ome with add a leaf rear springs...any issue?
  5. Jul 13, 2020 at 12:50 PM
    sdhq_offroad
    GILBERT, AZ
    Should be no issue but we haven't done a physical install with that add-a-leaf set up.
    Rica25 likes this.
  6. Sep 21, 2020 at 5:51 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Any real world experience out there with this kit OFF ROAD yet? I'm running Icon RXT pack and shocks and after regearing am having pretty bad axle wrap on road, rubbing tires on the front of the rear wheel well/bed support bolt heads, and increased pinion angle. BUT I love how the RXT flexes offroad and don't want to limit that travel and function. I'm looking into other options as well but that's a discussion for another thread.
  7. Sep 21, 2020 at 7:46 AM
    sdhq_offroad
    GILBERT, AZ
    We have tons of offroad miles logged with these. This doesn't limit how the leaf pack flexes, droops, or travels.
    Rica25 and blackoutt like this.
  8. Oct 23, 2020 at 10:50 PM
    Neshra54
    Neshra54 New Member
    DE
    2016 TRD PRO
    I have 6+ Readylift lift on my truck. Basically 5.5 inch blocks in the back, can you tell me if this kit will work on my truck ? @sdhq_offroad .
    Rica25 likes this.
  9. Oct 26, 2020 at 4:55 PM
    sdhq_offroad
    GILBERT, AZ
    If the truck has 5.5 inch blocks on the back, that kit is closer to 7-8" of lift. A 6" inch kit typically comes with a 4". Would it physically fit, however, I do not know if there will be enough adjustment in the heim for that lift height.
  10. Dec 30, 2020 at 6:43 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Anything for flipped axles ?
    Been looking at options for the lowered crowd.
  11. Jan 4, 2021 at 7:19 AM
    sdhq_offroad
    GILBERT, AZ
    Unfortunately not.
  12. Feb 22, 2023 at 5:09 PM
    BabyBlackYota
    BabyBlackYota New Member
    Alex
    Longview TX
    2015 Black Tundra SR5 offroad
    AFE cold air intake, Outlaw Catback Dual Exhaust, ProRunner Fender Flares, DAPTISED 37x12.5x20’s, (soon to be 38x13.5x17) Zone 5 bracket lift kit /with pro comp spindles and outer tie rods grip pro lsd rear, Revolution 5.29 gears Deaver U748 springs Camburg shackles Fox 2.5 Coilovers 7” BDS Icon Billet adj/UCA’s
    Would you know how much this kit weighs?
