07-14 38 Gallon Tank swap install thread
Discussion in '2nd Gen Tundras (2007-2013)' started by papasmurf, Jun 11, 2018.
  1. Nov 26, 2019 at 7:43 PM
    #241
    el_taco
    el_taco New Member
    Wanted to update this thread. This was during the summer. A full tank on the LRA 46 netted me 653 miles before the low light came on. This was with 80/20 highway/city driving with a few times towing my bote to local lakes fishin. I believe with the low light, there should be about 5 or so more gal in it so 700 miles is attainable.
    Cheers.
    rock01 likes this.
  2. Dec 16, 2019 at 7:35 PM
    #242
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    so, i've officially found a huge downfall to the stock 38 gallon swap. i recently went to fuel up and can't. no codes, but pump shuts off immediately. tried two other gas stations...same thing. did some research and found there is apparently an issue with a piece of baffle breaking free and causing the fuel limit vent valve to stick not allowing air to flow to the charcoal canister and in turn causing fuel to not fill but instead overflow out the fill neck. this valve is part of the tank and so far the only fix is a new tank. wtf toyota!!! so i got one year of use out of my $1400 dollar conversion and now i have to put my old 26 gallon tank back in for a road trip on saturday.
    found multiple threads about this in 3rd gen section and on tundrasolutions :(
    once the 38 gallon tank is out, i'll hopefully figure out a fix or bypass or go completely unsafe and punch it out.
    Jrharvey02 and Y0TA PR0 like this.
  3. Dec 16, 2019 at 8:06 PM
    #243
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Well that sucks! Hope you can fix it and works out for you!
    Kiddnapped Tundra likes this.
  4. Dec 16, 2019 at 8:45 PM
    #244
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    @831Tun Warren didn’t you have this issue? I know you didn’t replace the tank, what was your fix?
    Vizsla and 831Tun like this.
  5. Dec 16, 2019 at 8:57 PM
    #245
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yeah @jc153, my problem was the inertia valve got stuck in Sedona. Made fueling up to get home a nightmare. I ran the tank near empty and dropped it. I removed the anti-siphon "bullseye", to access the valve, stuck a screwdriver in and the valve popped right open. I figured it would just happen again so I disabled the valve with a creatively improper application of the screwdriver.
    86Scotty, Jfuggint, TheBeast and 5 others like this.
  6. Jan 7, 2020 at 12:50 PM
    #246
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    Very interesting thread! When I shopped for my Tundra in 2015, it was to replace my Tacoma as I replaced our 4,400 pound camper with a 6,600 pounder so needed the V-8 in the Tundra to pull her. I found the 2014 Tundra used but in great shape so saved a ton buying her...I never even thought to see how large the gas tank was, wouldn't Toyota have one of sufficient size? (Nope) It sucks having to start looking for a place to refill while towing every 2 1/2 hours (especially in our Colorado mountains where the gas stations are usually not large enough to refill with a 34 foot camper on the back.)
    So I got my Tundra paid off and looking around at options...the Ford F-250 has a big 6.7 gas engine with a 48 gallon tank option...sweet! So I built one for towing with other great options (TONS more than any Tundra)....then got to the last screen....$74,000....holy sticker shock Batman! That's more than I paid for my first house in 1990!!! That's not going to happen.
    So I'm looking at either trading in my Tundra for a new one (or used with the larger tank) or just replacing the tank with at least a 38 gallon Toyota or a 46 Transferflow. It's a job above my skillset so getting a price from a local installer Transferflow recommends.
  7. Jan 7, 2020 at 2:28 PM
    #247
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    i wouldnt do the transfer flow... but thats my opinion.
  8. Jan 8, 2020 at 6:29 AM
    #248
    nuclearlemon
    wyoming
    2012 dc
    why?
  9. Jan 8, 2020 at 7:36 AM
    #249
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    He gave a little comparison at the end of his original post.
    osidepunker likes this.
  10. Feb 15, 2020 at 8:49 AM
    #250
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Starting to research this swap a little more and came across some of the issues with the vent valve sticking and seeing if this is an issue still?
    also- was originally thinking of trying to pickup a tank from a junkyard but looks like that might be asking for trouble, and when I try to look tank up at Toyota is says no longer available
    would really like the extra range but don’t want to sacrifice reliability
  11. Feb 15, 2020 at 9:10 AM
    #251
    nuclearlemon
    wyoming
    2012 dc
    mine just happened right before christmas and it was on a tank that i just bought a little over a year ago, so yeah, still an issue
  12. Feb 15, 2020 at 9:11 AM
    #252
    Jeffro22
    Jeffro22 New Member
    Man that’s frustrating. Hate to hear that.
  13. Feb 16, 2020 at 9:17 AM
    #253
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I have a question for the experts here. I was able to track down a 38 gallon tank from a local junk yard for 185 bucks. Score! However, it looks like they cut some of the lines when they removed it. You can see in the pics. Can anyone tell what all I'd need to do this? And what I can re-use? Thanks
    20200216_103846.jpg 20200216_103944.jpg 20200216_103905.jpg 20200216_103917.jpg
  14. Feb 16, 2020 at 9:30 AM
    #254
    nuclearlemon
    wyoming
    2012 dc
    the lines to the pump are ok, since you can reuse your existing. the first couple, they kinda screwed you on and now you'll have to bandaid because those are part of the fuel tank assy. big line goes to charcoal canister and the smaller line goes to your overflow on your filler neck
  15. Feb 16, 2020 at 10:55 AM
    #255
    TheBeast The Beach
    for once I'm glad I had the small tank when I installed my sliders or else it would have been a PITA :)
    if I upgrade to bigger tank size, I think the Toyota oem is the best. The vent valve sticking seems to be an issue that has nothing to do with the swap itself.
  16. Feb 16, 2020 at 11:09 AM
    #256
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Thanks so much for the info. Are these the two that I'll need? Screenshot_20200216-130734_Chrome.jpg
  17. Feb 16, 2020 at 12:23 PM
    #257
    nuclearlemon
    wyoming
    2012 dc
    those are the two you'll need to splice onto your existing ends. the two on the pump (big white round deal) are the ones that you can unplug from your old pump and reuse
    WFD473 likes this.
  18. Feb 16, 2020 at 12:25 PM
    #258
    nuclearlemon
    wyoming
    2012 dc
    correct. the swap has nothing to do with the valve sticking. they are defective. unfortunately, part of the tank, so risk it happening or punch it out ahead of time
    TheBeast[QUOTED] likes this.
  19. Feb 16, 2020 at 1:58 PM
    #259
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Would I be able to take them off the old tank and use them? In your pic, they look identical.
  20. Feb 16, 2020 at 4:49 PM
    #260
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    Supercharger, Corsa, 5100’s
    Just picked my 38 gallon tank up today and will swap this week. Lots of useful info in here, you guys are great. Where is the anti siphon valve? Filler neck? I think I’ll take care of that prior to installation.
  21. Feb 16, 2020 at 6:28 PM
    #261
    nuclearlemon
    wyoming
    2012 dc
    you would just have to figure out how to connect the hoses to the pieces on the tank
    WFD473[QUOTED] likes this.
  22. Feb 16, 2020 at 7:14 PM
    #262
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I was able to pull the larger hose for the charcoal canister off my old tank and put it on the 38 gallon tank. For some reason, the one on the 38 gallon tank is a little shorter which made it difficult to connect and also puts tension on the connector clip. You might be able to pull the thinner hose off as well.
    nuclearlemon and WFD473[QUOTED] like this.
  23. Feb 16, 2020 at 9:31 PM
    #263
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Thanks for the info!! I'll attempt this once I get everything I need and it warms up a little, which here in the Midwest, might be an eternity...
  24. Feb 17, 2020 at 5:01 AM
    #264
    Jeffro22
    Jeffro22 New Member
    Would like to hear how the installs go!
    Would also like to hear more on being able to bypass the vent
    also was wondering if anyone knows why the fuel pump for a 38 gal tank has a different part # then the 26 gal tank?
    38 gal - 77020-0C170
    26 gal - 77020-0C120
  25. Feb 17, 2020 at 5:38 AM
    #265
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    How does that hose pull off? Did you pull the whole vent or were you able to get just the hose.
  26. Feb 17, 2020 at 9:56 AM
    #266
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    Just the hose. its pretty snug so there's going to be some huffing and puffing before it comes off. There is an o-ring on the barb so be careful not to damage it.
    WFD473 likes this.
  27. Feb 17, 2020 at 9:57 AM
    #267
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    Only difference I could find was that the sender had a different part number. The pump itself is the same. I could see a different number for that reason but I also read the assembly is the same but maybe a different manufacturer
    WFD473 likes this.
  28. Feb 17, 2020 at 9:58 AM
    #268
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    the two fuel lines off the 26gal tank will work on the pump... i ended up using my 26gal tank fuel lines
    Jfuggint and WFD473 like this.
  29. Feb 17, 2020 at 1:28 PM
    #269
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    I’m guessing they sneak down the side where the new front part of the tank is on the 38 gallon, yes?
  30. Feb 20, 2020 at 3:59 PM
    #270
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    Where did you route the lines from the 26gallon to get to the main and return attached to the frame ?
