07-14 38 Gallon Tank swap install thread
Discussion in '2nd Gen Tundras (2007-2013)' started by papasmurf, Jun 11, 2018.
  1. Mar 26, 2019 at 10:17 PM
    #151
    ginocara74
    ginocara74 New Member
    North Carolina
    2017 SR5 5.7 V8 FFE 4WD magnetic gray with front bench seat and off road package
    TRD dual exaust, TRD drop in air filter, Weather Tech rain GUARD, tri-fold bed cover
    Does anyone knows of anybody capable of getting this job in NC or anywhere close to it please?
  2. Apr 20, 2019 at 7:22 PM
    #152
    Cozzie
    Cozzie New Member
    League City, TX
    2007 Tundra Crewmax SR5
    No mechanical mods, just added headache rack, toolbox, grill guard & Ventvisors.
    Haven’t looked under my truck yet, to see if it’s possible. But after looking through several different sources, yes the conversion to the 38 gallon tank can be done, not cheaply no matter which way you go.
    So I’m left wondering if there’s room on the passenger side to install another 26 gallon tank directly across from the original one. Plumb & pipe it in, then use a toggle switch to choose which tank to draw from, like the old 2 tank trucks used to do?
    Obviously having a fuel fill door on both sides would be a bit inconvenient, but not undoable.
    I have a 07 Crewmax SR5 that I use for pilot car work & better range between fuel ups would be a good thing.
    My other thought is to just add an in-bed aux tank, some can be plumbed in so it works in tandem with the stock tank, but I’m thinking leave it as a transfer tank that I could use to refuel my truck or someone else’s should they need it.
    The aux tank can be had for about $1,000, with the electric pump, hose & handle. It’s a simple bolt down install. Gives an additional 42 gallon capacity, not that I’d fill it up completely very often. It only takes up about 9” of the floor, between the front wall & the crossover toolbox I have. The bed space isn’t a big issue, as this truck isn’t really used for hauling anything other than the equipment required for a pilot truck.
    The only downside I see of the in-box version is potential fumes out of the vent.
    Anybody else have an opinion on this?
  3. Apr 22, 2019 at 6:24 AM
    #153
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    exhaust is in the way
    Cozzie[QUOTED] likes this.
  4. Apr 22, 2019 at 7:47 AM
    #154
    Cozzie
    Cozzie New Member
    League City, TX
    I figured that might be an issue, but like I said, never really looked under there with this specific reason in mind. Never really had a need for more fuel capacity until now.
    Thanks for your reply.
    osidepunker[QUOTED] likes this.
  5. May 1, 2019 at 12:51 PM
    #155
    el_taco
    el_taco New Member
    Phantastic81, Cozzie and kparrow like this.
  6. May 2, 2019 at 4:29 AM
    #156
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I wonder if the shape has changed?
  7. May 3, 2019 at 1:00 PM
    #157
    559WeekendWarrior
    559WeekendWarrior New Member
    Menger
    2010 SR5 5.7L PreFlex Warrior
    Custom Build Tubing 3.5 with 3.7 Trd Intake 2014-2019 with Turbo Head Shield Air Filter, Jet Performance MAF, Throttle Body Spacer With Econoaid Throttle Body Booster Gasket. Exhaust 2.5 Cherry Bomb 7841 single with dual Side frame exit or in front of the rear passenger tire. Pedal Commander plug in play for the gas pedal. Last is leveling kit 3-1 front and rear with 32-33 MT tires.
    It's awesome how you can do a little minor work just to get a bigger gas tank but the only problem or issues is that there is going to be a lot more extra weight on the truck now especially on the driver side. All you have to do is bounces out the weight on the passenger side than you're g2g. Let's see in the long run how the gas tank is Worthy to do or not. Anyhow it's a great project for more fuel but it's going to kill you at the station.
  8. May 6, 2019 at 5:44 AM
    #158
    el_taco
    el_taco New Member
    Anyone with the larger gas tanks add any fuel stabilizer?
    I only use it for towing and long distance road trips so the tundy sits more than it's being driven as I don't DD it.
    Thnx
  9. May 6, 2019 at 6:08 AM
    #159
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Enjoyed the write up. Anyone considering the larger tank should make the switch. It is very nice to have while traveling. Wouldn’t want a smaller tank now
  10. May 8, 2019 at 10:15 AM
    #160
    Maxtor
    Maxtor New Member
    Mark
    Enjoyed the writeup as well... have been doing a lot of reading. Ordered the Transferflow 46 today, can't wait to make the swap! Range is only part of the PIA when pulling my 24' car hauler, a lot of gas stations are very congested and tough to manuver when pulling the trailer. Will be so much nicer to have nearly 2x the range. Thanks to everyone who contributed here!
    nuclearlemon likes this.
  11. May 8, 2019 at 12:14 PM
    #161
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    I have all the parts for the 38 gallon swap waiting to put on, but now wishing I would of waited for the discontinued tank to be re-introduced with a extra emissions canister :(
  12. May 10, 2019 at 8:19 PM
    #162
    Goneforgood
    Goneforgood New Member
    Mark
    2017 tundra
    Was wondering how you dealt with the fuel lines that are run back further for the 26 gallon tank since the 38 gallon tank is so much further forward.
    About to swap and would appreciate any help you can offer with that part, the rest seems pretty straight forward and you did a great job with the parts list.
  13. May 10, 2019 at 8:45 PM
    #163
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    From what I read and ask of others is they just pop them out of the tank runners and run the lines on top similar to what the TF tank would do, the issue is clearance were the new front cross-member goes. Tomorrow I am hopefully going to try and make a small bracket or spacer to mount the parking brake lever up higher and start fitting the cross-member. From looking at it last weekend and spraying some penetrating fluid on it, the lever seems to be mounted by 2 screws.
    I have about a half tank of fuel so just doing some preliminary work.
    I am going to be drilling and not sure on 2 or 4 holes per side. I might even cut the bottom off like nuclearlemon did, as my truck isn't lifted so the bar might be tight squeeze..
  14. May 11, 2019 at 10:14 AM
    #164
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    Anybody want to buy a 38 tank package? Close to U. P. of Michigan :) I have to get ramps or a hoist as it's pretty tight under there with the side steps and no lift!
    TXRailRoadBandit73 likes this.
  15. May 12, 2019 at 9:37 PM
    #165
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    I have a 15 and have the holes too for the crossmember. What did you use to attach the crossmember to the frame? Frame Rivets or bolts and nuts?
  16. May 12, 2019 at 10:24 PM
    #166
    Dammit I'm in Texas
    Y0TA PR0 likes this.
  17. May 12, 2019 at 10:50 PM
    #167
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Road trip :D
  18. May 12, 2019 at 11:10 PM
    #168
    Too much gas :rofl:
    Y0TA PR0[QUOTED] likes this.
  19. May 13, 2019 at 7:41 AM
    #169
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Lol!
  20. May 13, 2019 at 9:17 AM
    #170
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    I asked a guy at work and might be able to rent/borrow time with his hoist. Otherwise not sure on the projects future, if I could unload it for what I got into it I might consider. Alberta is a little bit farther than Texas though!
  21. May 13, 2019 at 9:38 AM
    #171
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Lol ya I’m 27miles farther!
    @ARamirez73 wants the tank. :D
    So did you install your 38g tank or no?
    How come you selling it?
  22. May 13, 2019 at 9:51 AM
    #172
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    I didn't install it yet, waiting to hear back on renting some hoist time. I might attempt this weekend again in my driveway, with jackstands under rear axle.
    I would sell it because I would put the money towards the TF 46gal tank which wasn't available when I purchased all the parts.
  23. May 13, 2019 at 9:57 AM
    #173
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Ah ok gotcha! :thumbsup:
  24. May 13, 2019 at 8:12 PM
    #174
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    You can get this one with the spray-on-bed-liner spray coat for an extra $200 (bringing the total to $1887)
  25. May 13, 2019 at 10:42 PM
    #175
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    I did the install in a drive way on @jc153 truck in 6 hrs start to finish w no lift and he has sliders... it’s easily doable all you need is a jack and some patience
    osidepunker, Sunnier and Y0TA PR0 like this.
  26. May 14, 2019 at 6:33 AM
    #176
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    Yeah I had lifted the front with my oil change ramps, I think lifting the rear would be better. Trying to talk myself out of it I guess. And of course when the snow is gone it's busy time and hard to work on all day projects. My biggest concern is the drilling. Would you use multiple bit sizes or one of those step bits? That is going to be the hardest part I think. I am thinking only 2 holes per side should be enough to support the additional crossmember.
  27. May 14, 2019 at 6:42 AM
    #177
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Two hopes a side is plenty... for the drilling just make sure it’s a good bit keep it lubricated w cutting oil and I’m not sure a step bit will work. I’d just get a good steel drill bit designed for metal. And speed is not your friend when drill thick steel.. heat destroys bits and drills and actually makes it harder to drill
    Sunnier and legger99[QUOTED] like this.
  28. May 14, 2019 at 6:43 AM
    #178
    gjcarving
    gjcarving New Member
    I had mine installed by a friend with a local shop. 2 bolts per side is totally fine for the front cross member. Honestly it seems like it is really extra insurance and is not supporting that much. If you look at the TF and LRA tanks they are larger and MUCH heavier and they only use the 2 stock mounting points. Honestly, if you are not off roading the truck I bet the two straps would hold the tank just fine.
  29. May 14, 2019 at 7:25 AM
    #179
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    The thought did cross my mind, but the Toyota tank is plastic which could deform over time.
  30. May 14, 2019 at 7:29 AM
    #180
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I Was wondering this on the way back from Atlanta last week, dual 38s, would be the ultimate highway cruiser. Could it be done?
