07-14 38 Gallon Tank swap install thread
Discussion in '2nd Gen Tundras (2007-2013)' started by papasmurf, Jun 11, 2018.
  1. Dec 20, 2022 at 7:41 PM
    #451
    shannon
    shannon New Member
    shannon
    Manitou Springs, CO
    2010 DC
    FWIW...I put in the transferflow 46 gallon last year. Best upgrade I've ever done. Over 500 miles to the tank. DTE is not correct, but how accurate was it anyway. The fuel light comes on fairly early in relation to what's left, but get's you planning earlier than later. Any naysayers worried about it hanging down further, it's not an issue. The thing is built like a tank (Ha) and there's a ton of important shit that hangs down further.
    chugs, WVI, Dirtytruck and 2 others like this.
  2. Dec 21, 2022 at 4:30 AM
    #452
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Where we are it’s very how do I say this. I don’t see change coming at all we are way out in the country
    WVI and Dirtytruck[QUOTED] like this.
  3. Dec 21, 2022 at 4:38 AM
    #453
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I will echo this sentiment as I also have the TF 46 gal tank. I don't have the DTE indicator in my '07, but the fuel gauge indicates proper fuel level. The only difference in my truck is I have the upgraded fuel pump to feed the Magnusson SC. The corresponding tune wouldn't have messed with anything in the ECM regarding overall fuel capacity.
    Dirtytruck likes this.
  4. Dec 21, 2022 at 11:58 AM
    #454
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
    The DTE is a distraction. I had a Chevy that had a DTE but I could push a button and hide it. Only referenced it one time in two years nearing E out in the middle of nowhere.
  5. Dec 22, 2022 at 4:48 AM
    #455
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    On mine, I don’t pay attention to the DTE. I have made mental notes about how much fuel I have to add to fill the tank at the various points on the fuel guage and I have no problems.
    shannon likes this.
  6. Dec 23, 2022 at 9:12 AM
    #456
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Like previously mentioned, you will still have plenty of gas when on E. However this is typical to all factory installed 38 gal tanks, not because of swapping from 26 to 38 tanks. So technically the gauge is still OEM correct.
    Dirtytruck[QUOTED] and 831Tun like this.
  7. Dec 23, 2022 at 9:29 AM
    #457
    InfernoPRO
    Scott
    Sacramento
    This reminds me that I did have issues reusing the factory 26 tank fuel sender. The angle the sender goes into the 38 tank is different, so your 26 tank sender will hit the tank side wall. The sender hit the wall around 1/3 tank reading and won't go lower. The fuel pump has to go in a certain direction and cannot rotate to fix the issue. The part number in the first post did not fix it. I used 83320-0C050. You can see the different lengths of the arms below.
  8. Dec 23, 2022 at 9:57 AM
    #458
    Trdwillie14
    Billy
    2014 trd off road
    But funny thing is I got the 38 sender dropped the tank again and still incorrect lol
  9. Dec 27, 2022 at 10:53 AM
    #459
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    keep in mind, the sender should always read low when there is a certain percentage of fuel in the tank. that's to keep the fuel pump cool. i usually am around five gallons on the stock tank and i think it was closer to 8 gallons on the 38gal tank (sorry, took it out two years ago and haven't put it back in yet, so don't really remember)
    Trdwillie14 likes this.
  10. Apr 12, 2023 at 12:38 PM
    #460
    Kalashnikov 47
    Kalashnikov 47 New Member
    Minnesota
    2018 Sr5 double cab gang
    So I have an 18 tundra dbl cab, do I need to get the middle crossbar weldded like how you did or is it simply almost plug and play?
  11. Apr 12, 2023 at 5:12 PM
    #461
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    You'll have to do some minor trimming on the ends to get it in place and it'll bolt up fine. I did the same for my 18 DC.
  12. Apr 12, 2023 at 5:14 PM
    #462
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    I wonder if the 2.5 gens used a different sender because i reused my 26 gal tank sender without any issues. It has no problem going to E.
  13. Apr 12, 2023 at 7:39 PM
    #463
    Kalashnikov 47
    Minnesota
    @danz75 do I need any additional parts? Also cam I see some pictures by any chance I'm supposed to be picking up a 38 gallon tank tomorrow. Did you buy additional parts also
  14. Apr 12, 2023 at 10:52 PM
    #464
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    You'll need to get the bolts and nuts to attach the cross member to the frame. Holes are already there so it should be fairly easy to line it up. i don't think i took any pictures when i did it since its quite well documented in various threads.
  15. Apr 12, 2023 at 10:53 PM
    #465
    Kalashnikov 47
    Minnesota
    I assume the sensor doesn't read it correctly? I'm thinking about picking up the new 38 gallon pump and sensor
  16. Jul 5, 2023 at 11:49 AM
    #466
    physikal
    physikal New Member
    Just want to confirm - this will work on a 2012 5.7L? Thanks!
  17. Jul 19, 2023 at 4:15 AM
    #467
    legiz
    legiz New Member
    Anyone know how much total for parts and labor for a dealer to install a 38 gallon on my 4.6? I hate only getting 350 per ta m
  18. Jul 19, 2023 at 5:49 AM
    #468
    Trdwillie14
    Billy
    2014 trd off road
    A lot. Lol I would do a long range tank it would prob be cheaper then going to the dealer
    BlueCrushSC16 likes this.
  19. Jul 19, 2023 at 7:31 AM
    #469
    Northbound Train
    Glenn
    Western MA
    You could get a 38 gallon tank from a wreck in a junk yard and pay the mechanic of your choice.
    Trdwillie14[QUOTED] and Y0TA PR0 like this.
  20. Jul 27, 2023 at 9:15 AM
    #470
    nuclearlemon
    wyoming
    2012 dc
    With some mods, yes. i had one in my 2012. the front crossmember that holds the tank isn't there, so you have to make one fit. after that, fairly simple bolt up.
  21. Aug 15, 2023 at 4:03 PM
    #471
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC SR5
    Magnuson's Finest Whine
    Great thread and glad it's available! Thanks OP and everyone else who contributed.
    Just a little FYI... Perhaps this was already pointed out, and I didn't see it, but the tank skid/protector listed in post #1 — PART NUMBER: 77606-0C040 Protector Sub-Assy, Fuel Tank, NO.1 — is for the 26 gallon tank!
    The correct part number for the 38 gallon tank is 77606-0C060. I went to pick up my parts and thought my tank skid looked a little small, compared to the box... oops.
    Edit: Looks like it was brought up in post 420
  22. Jan 31, 2024 at 9:08 AM
    #472
    Oochi20
    Oochi20 New Member
    Ryan
    2008 Salsa SR5
    OME 2.5" Lift SSW Stryker Wheels 35" Nitro Ridge Grappler Tires
    Doing my swap and this issue has thrown a wrench in my gears. I wonder if the 26 gallon sending unit can be shortened or bent to make fit?
  23. Apr 24, 2024 at 8:57 PM
    #473
    kentran5397
    kentran5397 New Member
    Dallas. TX
    2014 Tundra 1794 Edition
    2019 Trd Pro LED Headlight 2019 1794 Grill LED Interior and Reverse Light LED Bedlight Vled Footwell LED Driver Side Grab Handle Bullet Fender Flares MX4 BakFlip Start X Remote Start Dual USB ports for the front and rear KO2 A/T Tires 275 60 R20 *Future Mods* TRD Rear Sway Bar Leveling Kit 38 gallon fuel tank swap
    Hi! For part number 83320-0C050, is it the sender on the top or bottom ? I accidentally ordered 83320-0C060 to do the fuel tank swap from the 26 gallon to the 38 gallon and it looks completely different from the one on my 14’ 1794 non-flex fuel. I was able to install everything and use my old sender but my gauge is reading empty so I think I need to replace it regardless. Truck is currently sitting around 195k miles
  24. Apr 25, 2024 at 7:13 AM
    #474
    Oochi20
    Oochi20 New Member
    Ryan
    2008 Salsa SR5
    Yep I had the same problem. You will need the 83320-0C050 for it to read correctly.
    kentran5397[QUOTED] likes this.
  25. Apr 25, 2024 at 7:49 AM
    #475
    kentran5397
    Dallas. TX
    Thank you! This helps a ton!
  26. Apr 25, 2024 at 3:37 PM
    #476
    FireInTheDesert
    FireInTheDesert FireInTheDesert
    Nick
    Las Vegas
    Cobalt - 2007 Toyota 4WD 4DR 35X20
    20” GFX -35X12.50R20LT
    I’ve heard there’s a 52 gal tank that swaps for the 26.
    Anyone know about this?
  27. Apr 25, 2024 at 6:31 PM
    #477
    kentran5397
    Dallas. TX
    I believe you’re referring to the 46 gallon transfer flow tank ? It was discontinued a few years ago
  28. Apr 25, 2024 at 7:58 PM
    #478
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2007 4.7 RCLB SR5 2010 5.7 RCSB Base Model 4WD
    I have a question. I’ve got a 2010 5.7 RCSB. Does this work with reg cab truck?
  29. Apr 25, 2024 at 9:45 PM
    #479
    kentran5397
    Dallas. TX
    I can’t say for certain, but I’m sure it could work. For me, my mechanic had to relocate the E brake and drill holes to place the 3rd cross member. I had the 26 gallon tank prior, so if you check under you truck for the regular cab and there’s at least 3-4 feet total above and below your current tank I would say that it’ll be possible
  30. Apr 26, 2024 at 4:55 AM
    #480
    BlueCrushSC16
    Charleston, SC
    :crazy:
    It was? No mention of it being discontinued on their website. TF shows 5 in stock and a "call...to place your order." I would take the latter as they aren't actively fabricating new ones, but they will if a) existing stock is exhausted and b) a customer calls wanting one.
    https://www.transferflow.com/46-gallon-toyota-tundra-midship-replacement-fuel-tank
