07-14 38 Gallon Tank swap install thread
Discussion in '2nd Gen Tundras (2007-2013)' started by papasmurf, Jun 11, 2018.
  1. Feb 25, 2021 at 6:40 PM
    #391
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Got my truck back and went to fill up gas everywhere not sure what went wrong maybe a kink or line issue :annoyed::annoyed::annoyed::annoyed:
  2. Feb 26, 2021 at 9:04 AM
    #392
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Should be able to look underneath really quick to see if the fill tube is twisted or not fully seated into the inlet. If that's ruled out, you might want to look into roll over valve issue that has occurred on a few with the 38 gal tank. When that valve closes, it prevents any gas from going into the tank.
  3. Feb 26, 2021 at 9:42 AM
    #393
    Trdwillie14
    Billy
    2014 trd off road
    No it took 13 gallons already I’m assuming something is loose or a kink
  4. Feb 26, 2021 at 9:45 AM
    #394
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    Sounds like something came loose which should be an easy fix.
  5. Mar 31, 2021 at 12:21 PM
    #395
    Trdwillie14
    Billy
    2014 trd off road
    Help needed. After a few weeks my traction control light and engine light came on. I got the code scanned(located in pic below) when I went to fill up and the truck was reading half tank (half tank and 136 miles ) I was able to fill up 31.8 gallons. Any help is very much appreciated. Thank you
    @TSands83
  6. Mar 31, 2021 at 1:41 PM
    #396
    New2TundraTRD
    New2TundraTRD New Member
    Adrian
    Ontario
    2011 SR5 CrewMax TRD
    Offset rims with lift in the rear w/275-65-18 10s
    Does this mean I will get further down the road? Currently have an 80L tank, sorry metric here in CANADA...EH!
  7. Mar 31, 2021 at 5:30 PM
    #397
    TSands83
    TSands83 USAF Jet Engine Mechanic
    OKC, OK
    2015 Attitude Black Tundra Platinum CM 4x4
    Black TRD Pro headlights, iHacker LED Plug N Play harness, black LED fog lights, TRD Pro grille, TRD skid plate, TRD front and rear sway bars, TRD Pro Fox shocks, TRD intake, TRD dual exhaust, Lexus/Toyota aluminum oil filter cap, Stahlbus oil drain valve, black Fuel Offroad Pump 20x9+20 wheels, color matched mirror caps and door handles, stubby antenna, black tube steps, driver side assist handle, Rago dash plate with ICS backing plate, SR black interior door handles, SR black dash center panel, Tacoma/4Runner left and SR right black steering wheel switches, black steering wheel emblem, black TRD shift knob, AJT Designs shifter and cup holder bezels and HVAC control knobs, Husky floor mats, Trail Edition bed storage boxes, bed LED strip lighting, bed mat, Charvonia Design Billet Tie-down Anchors, 38 gallon fuel tank, RCI fuel tank skid plate, AVS window deflectors/visors, Recon taillights, Recon smoked 3rd brake light, GTR Lighting interior and exterior bulbs, Morimoto mirror puddle lamps, center console wireless charging tray, RAM Mounts Quick Grip wireless charger, Alpine iLX-F509/DVE-5300/KCX-630HD/DVR-C320R, Maestro RR, Garmin Drivesmart 65 & Traffic, Llumar FormulaOne Stratos Nano-Ceramic Window Tint. More to come...
    PM'd
  8. Apr 26, 2021 at 2:58 PM
    #398
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    possibly damage to the sending unit on the pump its a replaceable unit just have to drop the tank and pull the pump to replace the little float sending unit.
  9. Apr 26, 2021 at 3:46 PM
    #399
    Trdwillie14
    Billy
    2014 trd off road
    Yah I think your right I found out I have a flex truck and the sender is different in part and part number so I swapped it and it seems to work i haven’t had the chance to run it empty but it seems to move past half empty now so hope it works
  10. May 5, 2021 at 1:47 PM
    #400
    Trdwillie14
    Billy
    2014 trd off road
  11. Jun 2, 2021 at 1:06 PM
    #401
    Phantastic81
    Phantastic81 New Member
    2011 matte white CrewMax
    KING 2.5 COIL OVER all around . 20 Inch WORX wheel on 34's Roll n Lock cover. Go RHINO Bull Nose Bar Grill , GO RHINO Side Steps ,Volant air intake ,flowmaster dual exhaust. tinted OEM front n rear lights, 2018 Sequoia headlights ,kb voodoo 20 inch bed rack,rhino rack platform ,
    Anyone in the bay area that can help with the install or recommend a shop? Any help is appreciated .
  12. Jun 2, 2021 at 1:14 PM
    #402
    Trdwillie14
    Billy
    2014 trd off road
    I had a dude in Santa Clara do mine but it needed to come back out and get a the right sender so I had a loca shop finish
  13. Jun 19, 2021 at 4:35 PM
    #403
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    After cutting the shit out of the cross bar, the parking brake cable and fuel lines are still in the way. I don’t see anyone mentioning that really.
    thoughts?
  14. Jul 10, 2021 at 3:45 PM
    #404
    tconrad
    tconrad New Member
    Tom
    NJ
    2019 Tundra SR5 CrewMax 5.7L FFV 4WD
    I looking at a pre owned 2019 Toyota Tundra TRD PRO… benchseat sold me ;)
    • the smaller fuel tank is a miss though ; and I’d want to upgrade it to the larger ~ this is possible based on your experience?!
    If anyone can verify.. and thanks for the post !!!
  15. Sep 27, 2021 at 10:11 AM
    #405
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Priced this MOD out and it's about $50 less expensive than going with the TF 46 gallon tank.
    Trdwillie14 likes this.
  16. Sep 27, 2021 at 10:25 AM
    #406
    Trdwillie14
    Billy
    2014 trd off road
    Yah and when your done the sender is not to accurate to so it always says ur empty and your not. If I didn’t get such a good deal
    On the tank or had to deal with crappy cali emissions I would have gone around route
  17. Oct 18, 2021 at 3:02 PM
    #407
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Finally did this swap. Anyone have any leads on the white clip that holds the evap hose to the carbon canister? My used tank didn't have it on there and the red clip off the 26 gallon doesn't fit. Unfortunately the parts list shows that only comes with the whole tank. Here are some images I found online of what it should be.20181027_134756.jpg
    GodlessPro and joonbug like this.
  18. Oct 18, 2021 at 3:31 PM
    #408
    Trdwillie14
    Billy
    2014 trd off road
    Is that off the sender I can call the guy who did my tank he may have the old one still
    InfernoPRO[QUOTED] likes this.
  19. Oct 18, 2021 at 3:51 PM
    #409
    InfernoPRO
    Scott
    Sacramento
    I think I saw the image of your tank on this thread. The clip would have been reused and is now on your truck. I did think it was weird your used tank came with the carbon canister attached.
  20. Oct 18, 2021 at 4:05 PM
    #410
    Trdwillie14
    Billy
    2014 trd off road
    It was a flex fuel what I learned
  21. Oct 18, 2021 at 4:10 PM
    #411
    Trdwillie14
    Billy
    2014 trd off road
    Just don’t forget the new sender but even still it only reads like 298 till empty it’s still not right lol
  22. Oct 18, 2021 at 4:38 PM
    #412
    InfernoPRO
    Scott
    Sacramento
    I bought a new sender. When I sent to swap it over to the new pump I realized they sent me the wrong sender, even though the sender box had the right part # on it. I put my old sender back on. My tank is reading empty even though I just filled it. So I will be dropping it again when the new sender arrives. :annoyed:
  23. Oct 18, 2021 at 4:58 PM
    #413
    Trdwillie14
    Billy
    2014 trd off road
    Lol
    I know I learned the hard way I was like you gotta be kidding me lol
  24. Jan 17, 2022 at 7:31 PM
    #414
    Buildingdoc
    Buildingdoc New Member
    So I just did mine today. But I do have a question. How important is the cross member and the strap for the front? That thing is pretty solid without it and completely full.
  25. Jan 18, 2022 at 6:20 AM
    #415
    Trdwillie14
    Billy
    2014 trd off road
    If it were me I would but I also had the big one welded lol
  26. Mar 25, 2022 at 6:59 AM
    #416
    fastcarsfastride
    fastcarsfastride New Member
    Thunder Gray RIP
    Well, I've been following this thread for close to a year and want to swap out my 26 gallon tank.
    Prices have fallen just a bit with local discounts to about $1300 for OEM.
    I have a 2021 Tundra Crew Max with the 26 gallon tank and yes in 2021 only the Front Bench seats do not come with the 38 gallon.
    I've got all my parts listed and ready to order, but there's one detail puzzling me.
    The fuel tank skid plate.
    I am not sure which one I need and that's because the part descriptions mention 26 gallon along with the TRD grade as well.
    Are there 3 skid plates for the Tundra?
    The 26 gallon base version, the 38 gallon base version and the 38 gallon TRD version?
    Below are the part numbers in this thread.
    77606-0C040 Protector Sub-Assy, Fuel Tank, NO.1 $178.97
    77606-0C060 38-Gal, Off Road $178.97 (needs 3 studded straps)
    Your help would be greatly appreciated.
  27. Mar 25, 2022 at 7:56 AM
    #417
    Trdwillie14
    Billy
    2014 trd off road
    Are you asking what skid to get?
  28. Mar 25, 2022 at 8:52 AM
    #418
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    I don't believe the non TRD trucks come with any type of skid. I know on my 2017 TRD Offroad it has just a piece of plastic. So I would assume they have a 26 gal and 38 gal version of this plastic skid. Back when I had my 2013 and was all set to do this swap, I wasn't going to install a factory skid as it would allow me to reuse some of the existing straps (If I recall). The skid ones need the studs like your bold comment says.
    Maybe the TRD Pros come with a metal version?
  29. Mar 25, 2022 at 8:59 AM
    #419
    Trdwillie14
    Billy
    2014 trd off road
    I’m not to sure of the trd pro but some argue the skid can do more damage off road by causing a puncture but I think the normal part is just a piece of plastic. You could also get rci skid for it tho if you need something
  30. Mar 25, 2022 at 11:16 AM
    #420
    fastcarsfastride
    Thunder Gray RIP
    I was just going off the list of parts needed and as you can see the price for the non TRD is just about the same as the TRD which puzzled me.
    This is what pappasmurf said a long time ago.
    "PART NUMBER: 77606-0C040 Protector Sub-Assy, Fuel Tank, NO.1 (Skid for tank, you can opt out and buy aftermarket skid)"
    If you're correct and it is just a piece of plastic, I can't imagine it would cost that much because if it did, I'd go with the TRD.
    My truck is on a road trip with my wife so I have no way of confirming what it has right now.
    I've only had the truck for 5 months and before that I had a 2021 DC for 5 months also.
    Never had a 2nd or 2.5 gen truck before this.
    Below references both of those part numbers that have been mentioned in this thread.
    Fuel Tank Skid Plate
    [​IMG][​IMG]
    Part Number: 776060C060
    Supersession(s): 77606-0C060
    Protector. Fuel. Plate. pump Assembly gasket. SUB - Assembly,. Tank Skid. Protect.
    A heavy steel Plate which protects the Fuel Tank during travel off-road. Off Road Package.
    Fits TUNDRA
    Stock Code 776060C040
    Price: $ 179.57
    Notes: Fuel Tank Skid Plate. Protector SUB - Assembly,.
    A heavy steel Plate which protects the Fuel Tank during travel off-road. Off Road Package. W/offroad Package. (more...)
    Category: Fuel, Exhaust and Emissions
    Assemblies: Fuel system components. (26 GALLON. w/off road pkg.. ); FUEL SYSTEM COMPONENTS. (Protect plate. w/offroad package. ); FUEL TANK & TUBE; FUEL TANK & TUBE (TUNDRA (UCK50),55,TUNDRA (USK50),55; TUNDRA (UCK51),56,TUNDRA (USK51),56; CMAX,DCB
    TUNDRA (UPK50),55,TUNDRA (USK50),55; TUNDRA (UPK51),56,TUNDRA (USK51),56; CMAX,DCB
    TUNDRA (USK56); (CMAX,DCB); SR-5 TYPE,GLX TYPE
    TUNDRA (USK56); LIMITED TYPE)
    Additional Images:
