07-14 38 Gallon Tank swap install thread
Discussion in '2nd Gen Tundras (2007-2013)' started by papasmurf, Jun 11, 2018.
  1. Mar 16, 2020 at 2:47 PM
    #331
    TRDZ28
    TRDZ28 New Member
    Southern California
    2014 Tundra TRD 4X4 BRM
    Got mine done. Took longer than anticipated but not hard. More time was spent on finding hardware and painting the crossmember than install. Installed a TRD Pro exhaust while I was at it. Don't know how to weld yet so I drilled.
    Thanks to all that shared information about this install. This is one of the things that I wished was available when I bought my truck and now I have it.
  2. Mar 16, 2020 at 3:20 PM
    #332
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Nice work
  3. Mar 16, 2020 at 3:44 PM
    #333
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    :thumbsup: Nice!
    papasmurf[OP] likes this.
  4. Mar 22, 2020 at 2:53 PM
    #334
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    On mine, I repurposed the fuel line brackets to relocate the lines.
  5. Apr 8, 2020 at 9:52 AM
    #335
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    For the 3rd Gen guys and gals, does the truck "learn" its new fuel capacity on the DTE gauge or are we stuck with the 430 DTE?
  6. Apr 8, 2020 at 10:15 AM
    #336
    TRDZ28
    TRDZ28 New Member
    Southern California
    The DTE is only 430 when you first get the truck or reset the computer by rebooting the battery. Mine settled at about 295 after a while.
    In terms of after the tank swap, I'll have to keep you posted as I'm still on the same tank from three weeks ago. I don't foresee it learning as I believe the computer is programmed for a max number of ~430 for the 26.4 gallon trucks. I have yet to determine if that can be modified with a tech stream or requires a computer swap.
    This tank is so big that after a little over three weeks, I still have have a tank left! I finished the swap just in time to have to work from home.
  7. Apr 8, 2020 at 1:40 PM
    #337
    RCdadfor2
    RCdadfor2 New Member
    Jeff
    2008 Tundra DC
    none yet
    yeah i am currently getting 3 weeks per gallon
  8. Apr 17, 2020 at 6:14 PM
    #338
    OpieTaylor
    OpieTaylor New Member
    Anyone one have a lead on a process to swap a 3rd gen 26 gallon tank to 38?
  9. Apr 18, 2020 at 4:49 AM
    #339
    Northbound Train
    Glenn
    Western MA
    On my 2016 it’s easier than putting the 38 gallon tank in a second gen because the parking brake is not an issue as it’s already relocated and the holes for the 3rd crossmember are there. There are several posts on line with pictures, if you read them all, and ignore the parking brake modifications, you have all the information you need. It could be done in a day if you have everything you need and you hustle. I took my time (I’m 60) and did it over 3. I prepped the cross member in advance. The first day I removed the old tank and installed the cross member. Then I did some painting to prevent rust. The next day I was letting the paint cure and I swapped the fuel pump. The third day I put the bigger tank in, that took a couple hours.
    If I had to do the whole operation again, it was go a lot faster obviously and if I had a lift it would be significantly easier, but it’s not bad and makes a hell of a difference.
    TheBeast, Phantastic81 and WFD473 like this.
  10. May 20, 2020 at 10:40 PM
    #340
    TRDZ28
    TRDZ28 New Member
    Southern California
    An update after 3 fill ups. The distance to empty is now 330 but I'm doing a lot more city driving since the quarantine. When the gas light comes on, I filled up with 27.5 gallons.
  11. Jul 16, 2020 at 10:20 AM
    #341
    Maxtor
    Maxtor New Member
    Mark
    An update on the TF 47 gal tank for those who don't have the time/skill/whatever to do the 38 swap.... I've ran about 25k miles with it now and can say other than getting rid of the stock crappy headlights this was easily the best mod I ever did. For day to day driving I fill up to about 25 gallons, for trips especially when towing it is so so so much nicer having the extra capacity especially getting 9-10 mpg. It is heavy as some have mentioned but I really don't notice any more body lean than what it already had and ground clearance seems about the same. It's also pretty expensive for a gas tank... but they truly offer a plug and play setup, everything was there. Not for everyone but it is a very well made product if you want to spend the $ and are less concerned about the weight.
    twistedcricket and nuclearlemon like this.
  12. Jul 16, 2020 at 10:25 AM
    #342
    papasmurf
    papasmurf [OP] Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    very true info, the biggest concern was its not CA legal, and the 38 gal swap provided a legal way to get a larger tank.
    TheBeast likes this.
  13. Jul 16, 2020 at 1:24 PM
    #343
    RCdadfor2
    Jeff
    2008 Tundra DC
    none yet
    good information. i plan to to the TF tank next year
  14. Jul 20, 2020 at 7:06 AM
    #344
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I hate how low the TF tanks hang
    and the weight
  15. Aug 19, 2020 at 11:52 AM
    #345
    Rafer73
    Rafer73 New Member
    Rafe
    2015 black tundra trd pro dc
    @papasmurf do you do fabrication? If I buy 38 gallon OEM tank would you be able to put it on my 15 TRD pro? Apologize in advance if that’s not something you do… But this 26.4 gallon tank is killing me. LOL
  16. Aug 19, 2020 at 11:54 AM
    #346
    osidepunker
    Alex
    2013 Tundra DC 4x4
    yeah he can do that. He's done a couple already
  17. Aug 19, 2020 at 11:56 AM
    #347
    Rafer73
    Rafer73 New Member
    Rafe
    No way!! That would rule...Do you have his contact?
  18. Aug 19, 2020 at 1:36 PM
    #348
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    shoot me a PM
  19. Aug 19, 2020 at 10:07 PM
    #349
    chingyeunglo
    chingyeunglo New Member
    :thumbsup: Nice info.
  20. Aug 20, 2020 at 10:06 AM
    #350
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
    Mad skills guys. I have no skills always have to pay someone...lol
  21. Aug 24, 2020 at 7:05 AM
    #351
    kentran5397
    kentran5397 New Member
    Dallas. TX
    2014 Tundra 1794 Edition
    2019 Trd Pro LED Headlight 2019 1794 Grill LED Interior and Reverse Light LED Bedlight Vled Footwell LED Driver Side Grab Handle Bullet Fender Flares MX4 BakFlip Start X Remote Start Dual USB ports for the front and rear KO2 A/T Tires 275 60 R20 *Future Mods* TRD Rear Sway Bar Leveling Kit 38 gallon fuel tank swap
    Is the skid plate for the 38 gallon tank optional? I don't do any off roading and I am looking to swap my 26 gallon tank to a 38 gallon
  22. Sep 10, 2020 at 7:16 PM
    #352
    TRDZ28
    TRDZ28 New Member
    Southern California
    It is but if you're spending the money and time for the swap, you might as well protect it with at least the basic plastic one. They can be found for cheap used.
  23. Oct 17, 2020 at 3:45 PM
    #353
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    @831Tun do you know if I’ll have to buy all those parts or it would come with ?
  24. Oct 17, 2020 at 5:11 PM
    #354
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You should be getting everything from JP
  25. Oct 17, 2020 at 7:14 PM
    #355
    Trdwillie14
    Billy
    2014 trd off road
    Is it mainly plug and play or do in need to replace parts
  26. Oct 17, 2020 at 7:16 PM
    #356
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    P&P for the most part. Your tank has 2 straps, 38 gal. uses 3. You should get 3 straps from JP. I just don't know if your truck has the fixed mount locations for the 3rd strap
  27. Oct 17, 2020 at 7:26 PM
    #357
    Trdwillie14
    Billy
    2014 trd off road
    So I may get to see warren in action ? Lol maybe I can pay u in 45 cal rounds lol
    831Tun[QUOTED] likes this.
  28. Oct 27, 2020 at 2:48 PM
    #358
    skull.daddy
    skull.daddy New Member
    So I read the whole thread... So I am understanding right, I can reuse the existing fuel lines that are on my 2007 Crewmax? Without any issue? And the existing filler neck is good too? I talked to the service dept at the dealership and that's what they warned me of when doing the swap.
  29. Oct 27, 2020 at 2:54 PM
    #359
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yup basically the only parts you really need, are tank, cross member, tank straps and pins that's pretty much the bare minimum. obviously, a skid is important, you may need a new pump retainer ring etc
    Phantastic81 and 831Tun like this.
  30. Nov 1, 2020 at 6:29 PM
    #360
    Trdwillie14
    Billy
    2014 trd off road
    Does anyone know would a 3rd gen have that cross member with a small tank? I’m upgrading and not sure if I have to buy one or if my truck has it already ?
