07-14 38 Gallon Tank swap install thread
Discussion in '2nd Gen Tundras (2007-2013)' started by papasmurf, Jun 11, 2018.
  1. Feb 20, 2020 at 4:50 PM
    #271
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    in their stock location works. the pump still ends up being in the same location. the extra gallons go mostly forward of the 26 gln tank, hence the need to add a crossmember and strap forward of the 26 gln tank
    WFD473 likes this.
  2. Feb 20, 2020 at 5:06 PM
    #272
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    Supercharger, Corsa, 5100’s
    Do they just lay over the top where the little dip is near the front strap?
  3. Feb 26, 2020 at 7:46 AM
    #273
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    Got mine mounted up in my 2012. I didn’t add the 3rd crossmember and honestly don’t feel it would make a difference. I also used the pump and sender from a 38 gallon equipped 2017 in mine, no issue and no electrical gremlin to this point. I’ll update if anything occurs.
    mcharfauros, TheBeast and Zebruaj like this.
  4. Feb 26, 2020 at 8:20 AM
    #274
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    This sounds like you are asking for trouble. With 26 gallon tank each mount supports 78lbs. Now you are asking the mount to support 114lbs. With 3 supports the weight would be down to 76lbs each for the 38 gallon. It looks like Toyota wanted to keep the weight in the 76-78 lb range.
    You might be right and will have no issues. But seems like you spent the money to upgrade, why risk the damage to the tank and/or supports?
    TheBeast and Vizsla like this.
  5. Feb 26, 2020 at 8:32 AM
    #275
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    its worse than that. because of the leverage the forward mount will supporting even more weight than that
  6. Feb 26, 2020 at 9:12 AM
    #276
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    I’m good with it, friend of mine is going on 3 years in the same configuration on his 2015.
  7. Feb 26, 2020 at 9:16 AM
    #277
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well for everyone else out there, I'm not good with it. I think its a terrible idea and incredibly reckless to drive on the public highways with 38 gallons of fuel that isnt properly supported on your truck.
    What if you get in an accident and burn up some other people??? smdh
  8. Feb 26, 2020 at 9:21 AM
    #278
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If the extra cross members was not needed, toyota wouldn’t spend the money on it when they build the truck
    Challenger1, Sunnier and 831Tun like this.
  9. Feb 26, 2020 at 9:37 AM
    #279
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm with you on this one Alex. I'm very much in favor of modifying trucks but some common sense needs to prevail. Risks VS rewards. Why even take a chance on something so critical with such a potentially disastrous downside?:der:
  10. Feb 26, 2020 at 11:35 AM
    #280
    RCdadfor2
    RCdadfor2 New Member
    Jeff
    2008 Tundra DC
    none yet
    This is something I plan to do at some point. My question is welding in the cross member, did you use a mig welder and if so do you need to take precautions to protect the trucks electrical system from the current of the welder?
  11. Feb 26, 2020 at 1:04 PM
    #281
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I know plenty including myself that didn’t do the 3rd crossmemeber. I skipped it at first to make sure it all worked. Been over 3 years, off-roading, crawling cross country trips. No issues at all.
    the 2 strap support the weight plenty. Also the way I saw it the 46gallon trans flow tank which is far heavier only uses 2 straps as well.
    some are just over thinking it. This isn’t a 1st gen, tanks just down fall out.
  12. Feb 27, 2020 at 12:21 PM
    #282
    TRDZ28
    TRDZ28 New Member
    Southern California
    2014 Tundra TRD 4X4 BRM
    The TF tank is metal thus much more rigid and won't flex as much as the plastic OEM tank would.
    It's even easier since you already have the holes drilled.
  13. Feb 27, 2020 at 12:49 PM
    #283
    TRDZ28
    TRDZ28 New Member
    Southern California
    Would anyone with a 2016 or newer and a 26 gallon tank check if the crossmember is there or if just the holes are drilled in the frame? I'm looking for someone local to see if I can get measurements for the locations of the holes.
  14. Feb 27, 2020 at 1:03 PM
    #284
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    And the parking brake or brake lines aren't in the way.
  15. Feb 27, 2020 at 1:27 PM
    #285
    TRDZ28
    TRDZ28 New Member
    Southern California
    Brake lines are still in the way from what @PRO BLANCO had to do.
    Y0TA PR0 likes this.
  16. Feb 27, 2020 at 1:47 PM
    #286
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    Almost a year ago I had all the parts to do this, had my 26 gal tank removed and could not figure out a way to safely re-locate the parking brake and before I butchered the crossmember further. I sold the "kit" to another member on here who had a new truck and he installed with minimal issues.
  17. Feb 27, 2020 at 1:55 PM
    #287
    TRDZ28
    TRDZ28 New Member
    Southern California
    I saw that and I was bummed when I missed you selling them. I just got all my parts together. Didn't realize you had to do much with the parking brake on the 3rd gens. Just realized yours is a 2nd gen.
  18. Feb 27, 2020 at 2:26 PM
    #288
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Did you look yet to see if holes are drilled in yours? I have a 2014 as well and they're not, unfortunately.
  19. Feb 27, 2020 at 2:30 PM
    #289
    TRDZ28
    TRDZ28 New Member
    Southern California
    They're not drilled on mine. I'm planning on drilling them myself. That's why I'm looking for someone that has it drilled so I can measure theirs to know where to drill prior to dropping the tank.
    WFD473[QUOTED] and Y0TA PR0 like this.
  20. Feb 27, 2020 at 3:27 PM
    #290
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Gotcha. Looking forward to how yours progresses. As soon as tax returns come in, I'll be ordering the cross member and strap and do mine.
  21. Feb 27, 2020 at 3:44 PM
    #291
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    the tanks isn’t goin to slip out, these tanks don’t move, you squeeze the tank down as is when you tighten the straps. The 38 gallon even has less room to move let alone slip out than the 26 gallon.
  22. Feb 27, 2020 at 4:27 PM
    #292
    InfernoPRO
    Scott
    Sacramento
    I don’t think anyone’s concerned about the tank slipping out under normal use. It’s about reducing the factor of safety. The trucks are designed to save your life in the event of an accident. Sure you have tested 2 straps off roading and it’s been fine. But I doubt you know what will happen if you were in a significant accident. Adding a 3rd strap takes a few hours max. Don’t be reckless with your life and others life on the road around you.
    osidepunker, sr5shark and Challenger1 like this.
  23. Feb 27, 2020 at 6:01 PM
    #293
    Jfuggint
    Jfuggint New Member
    Jeff
    NW Indiana
    2012 crewmax
    If the accident manages to get the tank to slide out with two straps then I’d guess that the tank staying in place is the least of my worries. If it ever falls out I’ll let you guys tell me you told me so
    ChargedToyo likes this.
  24. Feb 27, 2020 at 6:26 PM
    #294
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    If the
    if the accident is that bad, it prolly won’t matter how many straps are on it. The 3rd strap doesn’t make the tanks invincible, and it doesn’t make it reckless lol.
    Hbjeff likes this.
  25. Feb 27, 2020 at 7:33 PM
    #295
    InfernoPRO
    Scott
    Sacramento
    Hey I am not here to tell you how to live your life. But you really should consider installing the 3rd brace.
    In unrelated news Toyota just announced you only need to use 3 of the 5 lug nuts. The other 2 was just over engineering. Classic Toyota.
    joonbug, sr5shark, jc153 and 2 others like this.
  26. Feb 28, 2020 at 1:05 PM
    #296
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    prolly skip that and finally finish adding plates underneath like I’ve been planning. Then everyone is happy,
    On another note, 3 lugs will do, just ask Midas
    Jfuggint likes this.
  27. Feb 28, 2020 at 1:26 PM
    #297
    RCdadfor2
    Jeff
    2008 Tundra DC
    none yet
    Who uses lug nuts? Double sided tape
  28. Mar 1, 2020 at 12:03 AM
    #298
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Dayum, fuel tank swap!!!, I'm glad I joined this place, since I've been planning a sequoia headlight swap, but this may redirect my attention since I need to replace my fuel pump anyway.
  29. Mar 1, 2020 at 11:07 AM
    #299
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    Definitely gonna need to do this. I’m barely getting 200miles out of one tank
  30. Mar 1, 2020 at 2:50 PM
    #300
    blackdemon_tt
    In traffic, can definitely see that..
