06 Build
Discussion in '1st Gen Builds (2000-2006)' started by Gunslinger1, Dec 12, 2019.
  1. Jan 26, 2021 at 6:37 PM
    Gunslinger1
    Gunslinger1 [OP] New Member
    Rolla, MO
    06 Tundra TRD White 4 door
    9AE8A5DC-6DA1-4B4F-9CE5-1B980D00765D.jpg 8A80A3A6-97EF-45D9-9C3F-67B10EAA3C1F.jpg
    Lined the bed and she turned out beautiful. I was very happy w the work.
  2. Jan 26, 2021 at 6:44 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    oh you goin' crazy eh? nice. Excited to what the progress
  3. Jan 26, 2021 at 6:45 PM
    Gunslinger1
    Rolla, MO
    yea... this gets waaaaay out of hand
    CodyP[QUOTED] likes this.
  4. Jan 26, 2021 at 7:04 PM
    Gunslinger1
    Rolla, MO
    67B66F68-E816-4D7F-8869-ECB2BE897B74.jpg 0EDABD45-8083-4BD5-9F8B-A6226FD857DA.jpg 0EDABD45-8083-4BD5-9F8B-A6226FD857DA.jpg F2D1075D-C1FA-4CED-A285-319C5E1E6542.jpg D2490E51-B283-40A1-8FBE-FA502C8ED4BC.jpg
    Well hell as along as the bed is off sandblast the truck and paint it.
    Does look good.
    they found some leaks that needed attention and a carrier bearing that needed replaced.
    What was originally a simple project had gotten 3x bigger as well as the cost....
    CodyP likes this.
  5. Jan 26, 2021 at 7:23 PM
    Gunslinger1
    Rolla, MO
    This is the lift kit I ended up purchasing
    My son and I were going to install it. He is a newly wed and the timing never worked out. After several weeks I found a mechanic I liked to install it.
    After, watching him drag out several thousand dollars worth of tools to get it apart I was grateful I let him do it. There was rust and it did not come apart with our persuasion.
  6. Jan 26, 2021 at 7:30 PM
    Gunslinger1
    Rolla, MO
  7. Jan 26, 2021 at 7:32 PM
    Gunslinger1
    Rolla, MO
  8. Jan 26, 2021 at 7:36 PM
    Gunslinger1
    Rolla, MO
    New UCA
    Tie rod ends
    Lower ball joints
    all installed
    I thought while it was apart we would make it happy.
    When it came time for alignment the LCA bushings were seized up.....so another surprise I needed new LCA
  9. Jan 26, 2021 at 7:38 PM
    Gunslinger1
    Rolla, MO
    dust plate on this side was rusted to pieces and gone.
  10. Jan 26, 2021 at 7:40 PM
    Gunslinger1
    Rolla, MO
  11. Jan 26, 2021 at 7:43 PM
    Gunslinger1
    Rolla, MO
    FrenchToasty likes this.
  12. Jan 26, 2021 at 9:09 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    It's interesting that your frame/exhaust/rest of truck look pretty rust free but the front axle and suspension are rusted hard
  13. Jan 27, 2021 at 2:12 AM
    Gunslinger1
    Rolla, MO
    Yes on the Frame .....I looked up the vin on the Toyota site and the sub frames had been replaced I think in 2014 as well as the LCA. Maybe the frame was cleaned up and preserved then. The LCA bushings were still froze up not allowing for adjustment. The rest of the truck had a lot of surface rust. We have had no broken bolts and it was come apart reasonable well. Everything has cleaned up well at this point. The rear differential had a couple of pin holes we welded shut and the rest of it is solid.
  14. Jan 27, 2021 at 2:20 AM
    Gunslinger1
    Rolla, MO
    This is an Adventure truck and reliability is essential we replaced everything. Calipers, rotors, had a brake line not happy and seeping.
    it’s Happy now.
  15. Jan 27, 2021 at 2:22 AM
    Gunslinger1
    Rolla, MO
  16. Jan 27, 2021 at 2:27 AM
    Gunslinger1
    Rolla, MO
    new bump stops
  17. Jan 27, 2021 at 2:33 AM
    Gunslinger1
    Rolla, MO
    First 3 pieces of the skid row armor.....I like these plates they are significant. Will add the transfer case armor at some point.
  18. Jan 27, 2021 at 2:40 AM
    Gunslinger1
    Rolla, MO
    Went w a 17” wheel and a 285/70/16. I was under the impression that these would clear my frame. I think I have a -12 offset on my wheels I need to confirm that my son was in charge of the wheel/tire effort. But no, it runs a tiny bit on the frame and the mud flaps. We raised the front a bit and will remove the mudflaps. I can’t tolerate it rubbing. I addition, we added 1.25” spacers that should clear everything.
  19. Jan 27, 2021 at 2:41 AM
    #49
    Gunslinger1
    Rolla, MO
  20. Jan 27, 2021 at 2:43 AM
    #50
    Gunslinger1
    Rolla, MO
  21. Jan 27, 2021 at 2:45 AM
    #51
    Gunslinger1
    Rolla, MO
    319159C8-3B06-45D1-BE42-D6ACD3E03FE2.jpgStock wheels w lift
  22. Jan 27, 2021 at 2:46 AM
    #52
    Gunslinger1
    Rolla, MO
    Odin has been enjoying the process.
  23. Jan 27, 2021 at 3:30 AM
    #53
    Gunslinger1
    Rolla, MO
    replaced all the belts and the timing belt. It had the original timing belt in it.
    in addition to water pump and related parts.
    I have gone back with all OEM parts. Hopefully there’s A lot of Adventure left in this Truck. She’s gonna be fresh when we are finished.
  24. Jan 27, 2021 at 3:36 AM
    #54
    Gunslinger1
    Rolla, MO
    7AB5FE6C-18C3-4F7E-AB2A-0409B96C406D.jpg 17E17FA0-C3FC-45E6-AB9A-133989BC4D59.jpg EB93FD60-828E-494F-8D8F-43F8BB4E8328.jpg 40B6C082-15E7-453A-B0F4-D71E1FF24155.jpg
    Cleaned up nicely
    CodyP likes this.
  25. Jan 27, 2021 at 4:23 AM
    #55
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Let’s see the new shoe setup on it
  26. Jan 27, 2021 at 5:28 PM
    #56
    Gunslinger1
    Rolla, MO
    Had the brakes gone over in this truck a yr ago when I bought it. They never worked well. I was told it was the nature of this truck. I noticed when I pulled a boat i had to be damn carful it was stress getting it stopped.
    Turns out I had no back brakes at all.....only my front brakes worked.
    Since I will have it apart for backing plates all of this will go back new OEM.....Bearings seals and the such.
    My parking brake was nothing.....I was always nervous on boat ramps. This truck does pull my boats better than my previous 1/2 ton GMC.
    des2mtn likes this.
  27. Jan 27, 2021 at 5:46 PM
    #57
    Gunslinger1
    Rolla, MO
    soon very soon
  28. Jan 28, 2021 at 8:16 AM
    #58
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Wow, that's a lot of work, but oh so worth it!
    I'm really excited to see the end result!
  29. Jan 28, 2021 at 10:41 AM
    #59
    Gunslinger1
    Rolla, MO
    That you for that rock climber
    I like this truck and had no idea what it was going to take to get it to a place I was happy about it thus the cost has been significant.
    I will know in a yr how happy I am w my choices.
    FirstGen Vol and I have had a conversation going on..... I read over them the other day. He said, “ You can get a lot of money in these trucks”..... I didn’t remember reading that until I was in too deep to back out. He was right at a very high level.
    Haha ....
  30. Jan 29, 2021 at 5:04 PM
    #60
    Gunslinger1
    Rolla, MO
