03 tundra won’t shift out of park
Discussion in '1st Gen Tundras (2000-2006)' started by Blinkink, Sep 29, 2022.
  1. Sep 29, 2022 at 6:00 PM
    Blinkink
    Blinkink [OP] New Member
    Truck has Been sitting for almost a year and after replacing the battery and getting it started it will not shift out of park
  2. Sep 29, 2022 at 6:03 PM
    shifty` One great big festering neon distraction
    Where are you located?
    Have you tried manually shifting it?
    Does the lever move at all?
    If it does, does the gauge cluster show gear changes?
    FrenchToasty likes this.
  3. Sep 29, 2022 at 6:31 PM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Shifter cable underneath is probably rusted to shit
    Mr.bee and shifty` like this.
  4. Sep 29, 2022 at 6:34 PM
    Yup, I'm sure you know that's the intent behind the 1st question. :rofl:
    But I also know some folks have broken the shift arm, armature on the transmission housing is frozen, shift cable snapped or frozen, PNS issues (no Viagra needed), and if I remember right, there's that stupid issue on some 1st gens where, if the circuit for the tail or reverse lights is incomplete (like a reverse bulb or brake light bulb is out or something?) it won't shift out of park, but I'm fuzzy on that one.
  5. Sep 29, 2022 at 7:00 PM
    Blinkink
    I’m near Erie,pa.it feels locked like if u try shifting it without pushing the brake pedal
  6. Sep 29, 2022 at 7:17 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Disconnect the shift cable, and shift it by hand while on a dolly, and have someone steer the truck. :D
    shifty` likes this.
  7. Sep 29, 2022 at 7:22 PM
    Have you checked:
    • The brake light switch is fully engaging when the pedal is depressed?
    • All brake lights are fully functional?
    landphil and Siebler like this.
  8. Sep 29, 2022 at 7:41 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Wiggle test, rock it back & forth, if that doesnt break it loose, its the cable. Dont try to force it. What does the trans fluid look like? Water can make the bits sticky.
    shifty` likes this.
  9. Sep 29, 2022 at 7:59 PM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    My 06 sometimes will lock up. It unlocks when I rock the entire truck backward and forward. Just shifting my body back and forward sitting in the drivers seat works most times. I have had to get someone to rock it a few times before I can move the shifter.
  10. Sep 30, 2022 at 4:59 AM
    Blinkink
    Thanks guys. I’m gonna try all these things in a couple hours wen I get home and let u all know
    shifty` likes this.
  11. Oct 18, 2022 at 6:40 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    On steering column is pin that prevents shifter moving out of park unless brake pedal depressed. Might need dab of grease and push with screwdriver if it’s frozen
  12. Oct 19, 2022 at 4:23 AM
    Blinkink
    Anything is worth a try. Thanks
