03 tundra trans fluid
Discussion in '1st Gen Tundras (2000-2006)' started by Mark4x2, Jun 17, 2024.
  1. Jun 17, 2024 at 2:13 PM
    Mark4x2
    Mark4x2 [OP] New Member
    Ohio
    2003 AC stepside 4x2
    just bought a 03 tundra AC 4x2 4.7 auto,have a stack of dealer records since new,in 08 trans flush with what invoice frm dlr says ATFB ,at 60K miles , now at 126K ,want to drop trans pan and replace orig filter,clean out pan, fluid is bright red and smells like new, shifts great,one owner!!!,,should i do this or just drain/fill??? what type of fluid is ATFB??? THANKS TO ALL!!!
  2. Jun 17, 2024 at 2:30 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    no, I would just drain and refill.
    side note: every dealership is starving for $$$ right now due to the car market collapsing in on itself. Parts and repairs is where they're somewhat able to stay a float.
    BroHon likes this.
  3. Jun 17, 2024 at 2:39 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Dex III is the ATF we use in 00-02, Type T-IV for 03-04.
    ATBAV8 and shifty` like this.
  4. Jun 17, 2024 at 2:43 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Don’t drop pan. Too many have snapped bolts. Waste of time changing filter. Do a couple drain and fills.
    whodatschrome likes this.
  5. Jun 17, 2024 at 2:54 PM
    Mark4x2
    Ohio
    Thanks ,,sounds like drain and fill is the way to go, as I know manual says 65 inch pounds for pan bolts,,what do u think ATFB means ,,,dealer jargon for DEX III??
  6. Jun 17, 2024 at 2:54 PM
    shifty` In South Dakota Trouble ain't hard to find
    What he said! ^^ Never! drop the pan. There's no reason.
    And read this.
    Not all, at least the '03-'04 uses Type T-IV. @bfunke posted the compatibility charts previously, I'm re-linking here:
    bmf4069[QUOTED] likes this.
  7. Jun 17, 2024 at 3:00 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Thank you for the reprimand sir, I will not let it happen again. :D
    Edited my post to reflect the new info.
    shifty`[QUOTED] likes this.
  8. Jun 17, 2024 at 3:22 PM
    GreenMachineDream
    GreenMachineDream New Member
    West Central, OH
    2002 Tundra SR5, 4WD, RCLB, Metallic Green
    You can go to most Toyota Dealerships and at the service/parts counter ask for however many quarts of Dexron III. Not a hybrid mix like MaxLife or Dex/Merc.
  9. Jun 17, 2024 at 3:40 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’m willing to bet my truck there’s absolutely no reason an 03-04 Tundra tranny cannot take Dexron 3 or better ATF. What changed? The overdrive gear? I think that’s it. Toyota just wants to sell you their fluid.
  10. Jun 17, 2024 at 3:44 PM
    Mark4x2
    Ohio
    THANK U ,shifty,ATF Type T-IV If I read correctly.what do u think the dealer used in 08 4 the flush? could it be a crap shoot?
  11. Jun 17, 2024 at 4:12 PM
    Dealer should've referenced that same info, so I'm going to assume they got it correct. As for whether a non-Toyota-dealer would get it right ... can't say.
    Don't thank me, thank Bryan. He's the 1st person I saw post the info.
  12. Jun 17, 2024 at 5:05 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    They're the same trans, just the planetary gear changed.
  13. Jun 17, 2024 at 5:09 PM
    Jack McCarthy
    Bill
    North of Boston
    Exactly which is why you could potentially use either Dexron 3 or Type T-IV in my opinion. Ideally, something full synthetic.
  14. Jun 17, 2024 at 5:19 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    I wouldn't do anything.
  15. Jun 17, 2024 at 5:31 PM
    Mark4x2
    Ohio
    I like this best :)
  16. Jun 17, 2024 at 5:36 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Seriously, if it's not giving you any problems, and it's as you say, why mess with it?
  17. Jun 18, 2024 at 3:11 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    A drain and fill is called for every 30K miles (it takes about 4 quarts). With proper preventive maintenance these transmission will last a million miles. Or you can roll the dice and wait for something to break. Your call.
  18. Jun 18, 2024 at 6:50 AM
    FishNinja
    Lee
    06DC2wd
    Ehhhhhh I'm @ 260k+ and I'll be the first to do a transmission fluid drain/refill on this truck.
    ATBAV8 and FrenchToasty like this.
  19. Jun 18, 2024 at 7:05 AM
    Haven’t seen one go a million yet. Even the million mile guy replaced a trans in both of his million mile tundras.
  20. Jun 18, 2024 at 4:11 PM
    tvpierce
    Maine
    I didn't know that. How many miles on each trans?
  21. Jun 18, 2024 at 4:12 PM
    One only went like 750k if I remember right. Pitiful.
  22. Jun 18, 2024 at 4:13 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Hahah
  23. Jun 19, 2024 at 10:12 AM
    FishNinja
    Lee
    06DC2wd
  24. Jun 19, 2024 at 10:17 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  25. Jun 19, 2024 at 11:36 AM
    FishNinja
    Lee
    06DC2wd
  26. Jun 19, 2024 at 11:59 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Is this appropriate? This is a family forum.:duh: Haha! Good video though.
