03 Tundra fuel gauge not working
Discussion in '1st Gen Tundras (2000-2006)' started by Pminc, Aug 1, 2020.
  1. Aug 1, 2020 at 4:38 PM
    Pminc
    Pminc [OP] New Member
    2003 Tundra SR5 with 213K
    Hello my name is Pablo and i just recently purchased an 03 Tundra with 213k miles. The fuel gauge doesnt work well and at times it says empty when I filled with gas. Could this be an issue with the gauge itself or something else?
    Thanks
  2. Aug 1, 2020 at 5:06 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Hola and welcome, Pablo.
    Hopefully your problem is as simple as this. https://www.tundras.com/threads/stuck-fuel-gauge.66843/
  3. Sep 24, 2021 at 11:36 AM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    I have the same issue.
    Banged on the dash didnt work
  4. Sep 24, 2021 at 11:39 AM
    Lil Steve
    Gilbert, AZ
    Try banging on the tank on your next fill up.
    des2mtn likes this.
  5. Sep 24, 2021 at 2:08 PM
    shifty` Animals and insects don't do drugs
    Do you know how to use a digital multimeter (DMM)?
    It's typically one of two things. Either there's no change in electrical resistance/voltage from the tank float (i.e. it's stuck or malfunctioned) or the dash gauge isn't responding to the resistance.
    I don't know the specific electrical output or impedance the fuel float should be sending out, but I'm guessing you can easily find out and test for it! If you see something with a DMM, then I'd lean towards the gauge cluster.
  6. Sep 24, 2021 at 2:15 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Like from under the truck? By hand?
  7. Sep 24, 2021 at 4:10 PM
    Lil Steve
    Gilbert, AZ
    Yes, if the problem is the float is hanging up, hitting the tank while filling might just dislodge it. It would probably work best with someone controlling the fuel nozzle while the other lays underneath hitting the tank in various places as it's filled. Sounds and may look silly but it just might work and won't cost you anything.
  8. Sep 25, 2021 at 10:29 AM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    I tried no difference. I kicked it hard as i could with not much space to work with
  9. Sep 25, 2021 at 10:37 AM
    Lil Steve
    Gilbert, AZ
    As Shifty mentioned above, it's either going to be a faulty fuel gauge or a faulty sending unit. Unfortunately the sending unit/float is inside of the fuel tank, so the tank has to be removed in order to replace it. I'm not sure on the specifics of testing the fuel gauge on our Tundra's but I'd start there before dropping the tank.
