0 offset with 3 in lift
Discussion in 'Wheels & Tires' started by Dustydirt19, Feb 27, 2017.
  1. Feb 27, 2017 at 11:21 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    So I finally have enough money for my lift, tires and rims. I'm going with the Toytec boss lift but the question I have is I like the wide stance tires. I know a lot of guys run +18 offset with 295's with no rubbing. I was wonderino if I went with a 0 offset if I would have rubbing issues? Could I go with 35's with a 0 offset without rubbing? How bout 0 with 295's. I don't want to CMC if I don't have to and I don't trust the shops by me to do it and I definitely can't. What are your thoughts? Attach some pics and your specs if you don't mind
  2. Feb 27, 2017 at 11:23 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    correction, +18 and 295 do rub. That's the setup I have, also @joem1cha3l
  3. Feb 27, 2017 at 11:26 AM
    chphilo
    chphilo Tundra addict
    Western PA
    With 0 offset, 3 inch lift, and no body mount chop, 33 inches is the maximum diameter you are gonna able to install.
    With 18 mm, you will still have to do the fender liner mod, but you won't have to chop the body mount, most likely. My tires are veeeery close to the body mount though.
    koshe and Dustydirt19[OP] like this.
  4. Feb 27, 2017 at 11:29 AM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    let me clarify, +18 and 295s (34.3" diameter) clear the body mount and skid plate, only rubbed the liner
    Sundog and Dustydirt19[OP] like this.
  5. Feb 27, 2017 at 11:33 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You will 100% rub the plastics and depending on your UCAs 50/50 on the cab mount.
    *edit- I meant this for +18. At 0 offset it's 10,000%
    Erichudgins likes this.
  6. Feb 27, 2017 at 11:44 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Ok +18 it is then. Don't mind trimming the fender liner just don't want to CMC. Still under warranty and don't want any issues
  7. Feb 27, 2017 at 11:46 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Any issues at full lock..reverse etc? I know we've talked before...I'm just anxious now cause I have all the $$
  8. Feb 27, 2017 at 11:48 AM
    I ran 295 on +20
    Had to the CMC, trim corners of front bumper and re-tap fender lining.
    Black Wolf likes this.
  9. Feb 27, 2017 at 11:51 AM
    Dustydirt19
    Dustin
    Duluth, MN
    3rd Gen? I can't view your profile anymore. I haven't been vetted lol
  10. Feb 27, 2017 at 11:53 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup, even at +18 theres a good chance you'll need a CMC
  11. Feb 27, 2017 at 11:53 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
  12. Feb 27, 2017 at 11:59 AM
    Dustydirt19
    Dustin
    Duluth, MN
  13. Feb 27, 2017 at 11:59 AM
    Dustydirt19
    Dustin
    Duluth, MN
    No chop?
  14. Feb 27, 2017 at 12:13 PM
    Ya
  15. Feb 27, 2017 at 12:18 PM
    joem1cha3l
    Albany, NY
    Had to chop the front fender liners but no CMC
    Jrharvey02 likes this.
  16. Feb 27, 2017 at 12:37 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  17. Feb 27, 2017 at 12:58 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I'm running 295/60/20 on +20mm wheels which equals 33.94" and clear the body mount by about 1/2"
    if my math is correct, 295/70/18 will equal 34.26" plus the +2mm extra offset your hoping to get with the +18's will bring you extremely close to the body mount. Not saying it can't be done, but you might be on the edge about having to do the CMC.
  18. Feb 27, 2017 at 1:14 PM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    THIS
    I have 6" lift with 35s and 0 offset BMF and I had to cut plastic and metal
  19. Feb 28, 2017 at 1:43 AM
    chphilo
    Western PA
    You will probably have to remove front flaps and push in the fender liner. I cleared the body mount (only a few mm to spare). But Nitto Trail Grappler tend to be larger than spec. I do have 3.5 inch OME lift, but as far as fitting goes, there doesn't seem to be much difference between 3 and 3.5.
  20. Feb 28, 2017 at 12:01 PM
    Local46er
    Local46er New Member
    Neil
    Ontario Canada
    2016 Tundra SR5 TRD double cab
    I believe adding the lift will void your warranty anyway or at least on the power train.
  21. Feb 28, 2017 at 12:37 PM
    How so?
  22. Feb 28, 2017 at 12:43 PM
    Local46er
    Neil
    Ontario Canada
    That's what I was told by my dealer. I guess I will find out because the truck is in the shop getting it installed.
  23. Feb 28, 2017 at 3:21 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I don't know about that....
  24. Feb 28, 2017 at 4:29 PM
    joem1cha3l
    Albany, NY
    Yeah I'm pretty sure that's incorrect. Don't think it does anything to the warranty
    T-Rex266 likes this.
  25. Feb 28, 2017 at 4:49 PM
    Find a new dealer. A c/o lift, spacer will not void your warranty. If something were to occcur they would have to produce proof that said lift caused said issue.
    Sunnier and Local46er[QUOTED] like this.
  26. Feb 28, 2017 at 6:04 PM
    Local46er
    Neil
    Ontario Canada
    That's good to hear. My wife was more upset about the void warranty over the 5 grand spent on upgrade.
    Thanks. :amen:
    Sunnier likes this.
  27. Feb 28, 2017 at 6:14 PM
    sc134
    sc134 O.P.S.
    2017 Tundra PreRunner
    Front 2.5 Fox Factory Extended Length Coilovers, Total Chaos Upper Control Arms, Swapped projector Headlights, Tint, Dual Carven Exhaust
    Warranty is voided with any lift not installed by your dealer and even then they will make it near impossible to approve your claim.
    Trust me, I know by experience. I got rid of my Tacoma due to having transmission issues that were blamed on my lift and tires. If your planning on arguing for them to prove to you how the lift/tires caused the issue they will ask you "how can you prove it wasn't due to the modifications." And if they decide to proceed to show you how the mods became an issue they will more than likely be correct and charge you the fees, services, and etc that had to be done to prove to you the issue was due to mods.
    Bottom line, warranties are ready to fight. I learned my lesson and did not purchase any extended warranties. Also, I doubt a tundra will have an issue dealing with a simple lift and a few inches taller tire than stock so why worrie about warranty IMO.
  28. Mar 2, 2017 at 5:05 AM
    az1441
    Steeler Country
    Got a pic of the tire clearance from the side?
  29. Mar 2, 2017 at 5:44 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I'm still sitting stock height and have just very minimal rubbing on the plastic fender covers. That's a +1mm offset (Zero really...what's a millimeter between friends)
    Sunnier likes this.
  30. Mar 2, 2017 at 7:52 AM
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    It seems to me that a lot of problems with the rubbing could be solved by getting an aftermarket bumper. I know it is another cost but not all bumpers cost a fortune if you don't need a winch right? Why not save up a little more cash and install the lift and bumper at the same time and get the tire size and look you REALLY want. After all, you will be stuck with whatever size you get for at least 2-3 years......just sayin'.....:stirthepot:
    Bear and az1441 like this.
