0.75 wheel spacers - work on TRD wheels?
Discussion in 'Wheels & Tires' started by warhammer44, Mar 4, 2020.
  1. Mar 4, 2020 at 1:16 PM
    warhammer44
    warhammer44 [OP] New Member
    Grant
    Kansas
    2016 Tundra Crewmax Black 4x4 SR5
    I have been scouring Tundras.com, Tundratalk.com and the World Wide Web in general without a definitive response. I have a 2016 Tundra that I am wanting to add 37x12.50r18 tires on the stock 18x8 +60mm offset TRD rims. I saw you can use a 0.75 wheel spacer on Rock Warrior wheels, but do you know if those same spacers would work on the TRD wheels? I may not even need them but just want to be prepared in case I run the UCA
  2. Mar 4, 2020 at 1:18 PM
    warhammer44
    Grant
    Kansas
    Shit forgot to add I have Bilstein 5100 on middle setting. Otherwise stock suspension
  3. Mar 4, 2020 at 1:21 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Even with the knockouts in the back of the wheels, you'd probably need to grind the studs down to get the wheels to seat correctly. Also, you're going to have a hard time finding legit shops that will mount a 12.5 on an 8 inch rim. You're better off getting the right wheels with the offset you want.
  4. Mar 4, 2020 at 1:49 PM
    warhammer44
    Grant
    Kansas
    That’s the thing though is I want to keep things tucked in. Not even a huge fan of the +25 mm offset
  5. Mar 4, 2020 at 2:39 PM
    15whtrd
    15whtrd Mr. Blonde
    Pretty sure I’ve read of a case or two around here where it worked with the .75 spacers and trd wheels. But I don’t know if they will put a 12 1/2 inch wide tire on that rim.
  6. Mar 4, 2020 at 2:51 PM
    warhammer44
    Grant
    Kansas
    15whtrd likes this.
  7. Apr 16, 2025 at 11:03 AM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Did you ever end up using the .75 spacers?
