“Sport” gears
Discussion in '2.5 Gen Tundras (2014-2021)' started by Anothersmith, Jul 23, 2019.
  1. Nov 22, 2019 at 6:25 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I believe some folks on here reported getting the best fuel economy when they use S mode to keep the engine around 2000 rpm.
  2. Nov 22, 2019 at 7:13 PM
    Eric32444
    Eric32444 "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    brake pads are cheap, transmissions and engines are not...i would only use in an emergency
    TTund16 likes this.
  3. Nov 25, 2019 at 8:12 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    I tow 7500 (+-) on a fairly frequent basis, hills, flats, etc...PA, WV, NY, VA...plenty of grades and some flat (when going to the shore / MD, DE..etc)...
    When the Trailer is connected...ALWAYS in Tow/Haul....and MOSTLY in S4. It will shift normally from a stop up to 4th gear...and I keep it 65 or so on the Highway...70 Maybe...and am around 3000 RPM...I usually keep the RPM up there and not really worry about the speed..mostly watch RPM - 3000 RPM is a happy place - especially if there are some inclines
    occasionally, on a LONG STEEP hills...I may find a lower gear to keep it above 3000 if I need the additional grunt to climb. like S2 for a long 10% grade for several miles...from a dead stop. and just keep pulling the trailer up that hill...doesn't give a crap. Temps are normal...and the truck just pulls.
    I may drop in to S3 when coming down a hill...or S2 if coming back down that 10% grade...and try and limit the speed using the motor / engine braking, vs smoking my brakes...depends. Occasionally when rolling through VA/WV and the speed is 45 and plenty of rolling hills...45 and 3000 RPM - S3...great gear, transmission doesnt shift from 4-3-4-3 all the time...just leave it there (3) for the local towns, and when the speed limit goes back up - increase speed, move to S4 and keep the RPM up...and motor on.
    but for the most part - s4 - Tow haul...and not really give a crap about what i'm towing...she just grins an bares it. 99% of the time, just leave it in the S4 and Tow haul...unless there is a specific need for a lower gear for a longer period of time (dont want to shift in and out of gears to create heat) - S4 and tow haul. If I lived in a FLAT state...maybe s5...to save some gas...but with ANY hills around, best to leave it in S4
    temp on the tranny is cool, the motor is cool...and just a very pleasing towing experience...yes, I know its there...but the Tundra really doesn't care - the Tq converter is locked, temps cool. plenty of power...A/C blasting, music playing.
    life if Grand.
    Much better towing experience than my older Silverado...same concept if Tq converter locking and needing 3000+ Rpm for hills...just the Tundra does it WAY better...the 4.30 rear, more HP, and 6 speeds - has a lot to do with it...
    Cpl_Punishment, Luckydog and drobb like this.
