‘21 Hood Replacement?
Discussion in 'General Tundra Discussion' started by BlueT21, Dec 18, 2021.
  1. Dec 18, 2021 at 4:24 PM
    BlueT21
    BlueT21 [OP] New Member
    2021 Cavalry Blue Limited
    Apologies if this has been asked/answered on here, but my Tundra’s hood has taken a beating from acorns and branches this fall and the quote for paint-less dent repair was about $1500 for the hood and acorn dents on the roof. Am I better off replacing the hood, and is it even an option to get them paint matched from Toyota, or would a body shop have to paint it?
  2. Dec 18, 2021 at 4:31 PM
    ArdnuT trd
    ArdnuT trd New Member
    Blake
    2021 Tundra MGM TRD 4x4 CM limited
    I’ve been looking for a pro or sport hood with the scoop for my mgm. That’s a more widely used color and they don’t have paint matched hood factory only through their contractors maybe that the dealer uses. Pointless will be cheaper than buying a replacement hood. Replacement even oem one will not be completely straight they’ll have to body work it prime it paint it then fit it to your truck. The labor hours will be expensive. Usually 100_175 a hour out here plus the hood won’t be cheap.
    at least in my experience
  3. Dec 18, 2021 at 4:34 PM
    BlueT21
    That makes sense. Appreciate the response. Sounds like paint-less it is then. Hope you find one that works for your truck. Maybe you could just add a scoop? I feel like I’ve seen posts of guys on here doing that.
  4. Dec 18, 2021 at 10:29 PM
    Blue By U
    Blue By U New Member
    My 08 Tacoma hood has the clear coat failing, no dents or scratches and they want $2400 to redo it.
  5. Dec 19, 2021 at 5:49 AM
    2mchfun
    I would be putting a chainsaw to work and removing the source of the problem before fixing the hood.
