***UPDATE***Tech12volts door and/or dash speaker group buy.-valid through 2/28/19
Discussion in 'Deals & Group Buys' started by Pudge, Jan 30, 2019.
Thread Status:
Not open for further replies.
  1. Feb 1, 2019 at 4:21 PM
    #121
    Devi8
    Devi8 New Member
    Dave
    2017 crewmax limited
    Iron cross steps, weather techs, rain/big guards, access cover, tracrac with cantilever
    James are the factory jbl speakers 2 ohm? with the Uno's being 4 ohm doesn't that reduce output of the factory amp? Is it noticable? Can you run the Uno's 6.5 woofer and keep the factory tweeter?
  2. Feb 1, 2019 at 4:43 PM
    #122
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    Correct. if you get all those speakers, it really sounds like a lot when you put it like that lol. if you dont have tweeters in your sail panels now, you'd have to either cut a hole in the ones you have or buy new ones.
  3. Feb 1, 2019 at 4:45 PM
    #123
    Pudge
    CT
    @james@tech12volts will know. But obviously if he recommends these particular speakers for this application out of hundreds of other choices, they must be the best fit for this application.
  4. Feb 1, 2019 at 4:45 PM
    #124
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    I'm in if that ends up being a group buy too!!!
  5. Feb 1, 2019 at 4:47 PM
    #125
    Pudge
    CT
    I would be happy to put together another group buy with James. He's a pleasure to deal with, at the end of the day its totally up to him and if he approaches me for another I will gladly do whatever I can to get it off the ground.
    doggiecareman likes this.
  6. Feb 1, 2019 at 5:12 PM
    #126
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Thanks for the info!
    @james@tech12volts
    So is the 5 ch amp needed for this GB set up to work? Unless I missed them somewhere, do you have 5 ch amps on your site?
    If amp is needed for the speaker set up, what other wiring, harnesses, etc. will be needed?
    I prefer/need things as much plug/play as they can be...
    Thanks @Pudge for getting this together!!!
    Pudge[OP] likes this.
  7. Feb 1, 2019 at 5:21 PM
    #127
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    What is a sail panel and how much are they? Are these speakers just replacing existing ones? Do wires have to be ran to the head unit?
  8. Feb 1, 2019 at 5:29 PM
    #128
    Pudge
    CT
    This is a sail panel. Trucks with the JBL system have them with tweeters installed. Idk if non JBL have these, they may just be solid panels. James sells sail panels that tweeters can be installed into on his website. https://www.shop.tech12volts.com/product.sc?productId=566
    Yea this group buy is for speakers that replace the existing speakers in your truck. Included will be brackets and harnesses to make them all easy to install / plug and play. There is no need to run any wires to the head unit at all. This package is a great option for keeping the factory head unit, but will also work with an aftermarket head unit, and/or if you add an amp into the mix.
    jc153 and tightywhitey[QUOTED] like this.
  9. Feb 1, 2019 at 5:36 PM
    #129
    tightywhitey
    New Orleans, LA
    I don’t have the tweeters in the sail panel...is it still plug and play?
    This damn site is why I can’t keep my credit card bill paid.
  10. Feb 1, 2019 at 5:43 PM
    #130
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    @tightywhitey You'd either need to cut your sails or buy his pre-cut sails for $60. I'm going to have to make that decision when I jump on this in a couple of weeks, if it's still available.
    tightywhitey and Pudge[OP] like this.
  11. Feb 1, 2019 at 6:03 PM
    #131
    Tundra4us
    Tundra4us New Member
    "D"
    Just ordered doors and dash!
    Thanks Pudge! Thanks James!
  12. Feb 1, 2019 at 6:06 PM
    #132
    Pudge
    CT
    It would pretty much be plug and play. You can spend the extra 60 for new sail panels or you can mount the tweeters to your current panels, this would require cutting a hole. My guess is that the speakers come with a template and a few options / brackets for mounting the tweeters
    Edit: the tweeters do come with mounting options. So you can definitely use your current sail panels....
    "Features
    Tweeter Mounting: Brackets are included for flush mounting and angled surface mounting (60° or 30°) the tweeters. If surface mounting, holes for the mounting screws and wire will need to be drilled."
    Here are some Pics of flush vs surface mount into / onto sail panels that dont have preexisting tweeters
  13. Feb 1, 2019 at 7:37 PM
    #133
    Goonwad07
    Goonwad07 New Member
    Ohio
    2007 Double Cab Limited 4WD
    Iron Cross Bumper, Alpha Rex Headlights, N Fab Side Steps, Line x Bed
    Where does the tweeter go for the rear door speakers?
  14. Feb 1, 2019 at 8:00 PM
    #134
    Pudge
    CT
    On my platinum they go here
    FoghornTX likes this.
  15. Feb 1, 2019 at 8:56 PM
    #135
    FoghornTX
    Ft Worth, Texas
    Same place on my 2018 SR5 CM.
  16. Feb 1, 2019 at 9:03 PM
    #136
    Black Tundra TRD
    Black Tundra TRD New Member
    Any ideas where in rear doors of a dbl cab?
  17. Feb 1, 2019 at 9:17 PM
    #137
    Pudge
    CT
    Hmm that's a good question. My guess is that the rear speakers in the double cab are 2 way and not components. You'd have to find a place to surface mount these tweeters if that is indeed the case. Your best bet will be to email James for further info on this because he's the expert here.
  18. Feb 1, 2019 at 9:20 PM
    #138
    Black Tundra TRD
    Thx I may need to change to Coaxials. Ill email J.
    Pudge[QUOTED][OP] likes this.
  19. Feb 2, 2019 at 3:31 AM
    #139
    Devi8
    Devi8 New Member
    Dave
    Pudge, when you get yours installed you'll have to do areview, without James answering my questions Im not going to spend another 300.
    Cdt makes a 2 ohm woofer that I'm also considering
    https://www.cdtaudio.com/2ohm/cl-2ohm/cl6ebe2.php
    I honestly want to know how noticable the reduce output from the factory amp is going to be with the Uno's. The factory system has a harsh cut over from subs to mids so that much less power might be extremely noticable or not at all.
    As it stands, I love the 12volt sub but I now am definitely adding a small amp to give it a little more punch.
  20. Feb 2, 2019 at 5:57 AM
    #140
  21. Feb 2, 2019 at 9:00 AM
    #141
    Pudge
    CT
    Did you email him with questions?
  22. Feb 2, 2019 at 9:19 AM
    #142
    Devi8
    Devi8 New Member
    Dave
    The dude was literally on the forum last night answering other questions on the thread, why are you possibly pushing this hard on this particular group buy?
    But I will go ahead and send a email as well.
  23. Feb 2, 2019 at 9:30 AM
    #143
    FoghornTX
    Ft Worth, Texas
    He's not. He's a valued and long time member that's simply getting a good deal for the community here and answering questions that he can. The ones that he can't, he's directing folks to email the vendor rep that isn't on the forum 24/7.
    If that's something that you're having problems with, you can go it alone and find other ways to purchase items for your truck.
    Newm, TomC843, doggiecareman and 6 others like this.
  24. Feb 2, 2019 at 9:40 AM
    #144
    Devi8
    Devi8 New Member
    Dave
    I said sir I said sir, that's not how this has gone down, first OP direct my reasonable question to James @ 12volt then I was told to trust that this particular speaker is best, and lastly to ask directly off the forum my question. (I submitted on his website)
    I don't know about you, but loosing half power for a already weak amplifier is a valid question. As soon as I get the answer from the email I will post it.
    The uno's could be a higher impedance but be reactive with less current to recreate the same sound, I don't know, I think it's important
  25. Feb 2, 2019 at 11:15 AM
    #145
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    $300 is actually a great deal for everything included. Comes w two sets of components, dash speakers, custom mount brackets and pnp harness.
    The speakers you linked is $100 for a pair of mids. No crossover. No tweets, no mounts.
    I also put in an order and will defiantly put my opinion once installed.
    Thanks @Pudge for helping put this together. Myself and a lot of folks are grateful. Also thanks to @james@tech12volts for working with us. This is a great stuff!
  26. Feb 2, 2019 at 11:32 AM
    #146
    Devi8
    Devi8 New Member
    Dave
    Blue bottle that wasn't my point I think 200 hundred for the door is a fine price. BUT .. your buying speakers that are a different Impedance than factory, less power output? Less mid bass? The door speakers only have mid bass, how do you get the highs to the tweeter? Or do you replace the factory tweeter then the uno cross over isn't being used?
    I Thought this was supposed to be a upgade for the JBL system. I just want to know this stuff before buying.
    I sent a email to 12volt, hopefully I get the answers and post them up. I'm not knocking the group buy OP or vendor I just want to know a few details.
    The speakers I linked are just 2 ohm mid woofers, not easy to find, I would have to take the chance and purchase to see if they sound good. James at 12 volt does a ton of tundra's so I would think my few questions are not a big deal.
  27. Feb 2, 2019 at 11:40 AM
    #147
    LifeCycle
    LifeCycle Build..build..build..
    Hugh
    Barcelona Red SR5 XP CM 2017
    TRD Dual exhaust TRD headlights bedmat Elka with adjustment knobs, ARB leafs-ring Fuel Crush +1 offset 20 inch 5 in backspacing TOYO open country 275/65 R20
    I piecemealed install the dash speakers from James' store and now they overpower the door speakers in audio output...and i mean that in the best complimentary way possible...if i had the time and knowledge to do the doors and amp along with the sub i got from the group buy along with the dsp i won thru james' raffle on a tundra fb page i would do it...looked into one local installer and got up with james again about it and he clearly pointed out to me how it would be against my best interest to steer clear of this installer so ended up getting an appointment to just drive to his shop and have them install the system...I trust his knowledge and experience in setting up Tundras with no hesitation whatsoever. I just wanted to give the credit where it is due. I would gladly post some pics or a vid post install.
  28. Feb 2, 2019 at 12:03 PM
    #148
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    I can answer here. The impedance on door and dash to the factory seem to be better matched at 4 ohms. and is here my theory on why . Now this is just my theory after 26 years in the industry but I can tell you the aftermarket speakers we choose sound better at higher volumes than the factory do. My theory is I think the factory amplifier is non regulated and suffering greatly at 2ohms . I think that's why it distorts so badly with the factory speakers . Especially in the 14 to 19 tundra. To me the only 2 channels that do not seem so distort badly at 2 ohms are the mono channels and i would guess that is because its set up differently for the mono channels than the stereo channels . Just like an aftermarket 5 channel . The mono channel does great at 2 ohms but the stereo channel when you drop them to 2 ohms seem to distort quicker due to damping factor drop from to the 2 ohm load . so any power gain you are getting from the lower impedance you are not able to use because you lost control of movement of the speaker. So when you raise the impedance to 4 ohms you get the control back and are able to turn the amplifier up higher with less distortion than before . That is why our package has the sub and center channel run at 2 ohms as those are the mono channels of the amplifier and all other channels are 4 ohms . Hope that makes sense to everyone. If you do not understand what the damping factor on an amp does or how impedance effects its . here is the definition.
    Amplifier damping factor (DF)is defined as “the ratio of the load impedance (loudspeaker plus wire resistance) to the amplifier internal output impedance.” This basically indicates the amplifier's ability to control overshoot of the loudspeaker, i.e., to stop the cone from moving . Basically it is the amplifiers ability to control the movement of said speaker . And the impedance cut down on that control greatly . less control means more distortion .
    Unlike some companies we like to test and understand the factory system before suggesting what needs to be changed. We spend weeks with JBL Tundras and a scope and rta to see where all the speakers are crossed and where the signal and output starts to clip. And every single output in the JBL system is crossed over . This why you can not get full range signal with just four inputs to any processor .
    D3Tundra, TomC843, deedubb and 7 others like this.
  29. Feb 2, 2019 at 12:15 PM
    #149
    Devi8
    Devi8 New Member
    Dave
    Fantastic, thanks for the reply, I noticed that the mids on the factory system seemed to distorts like crazy.
    One more question
    How do you install the uno's ? Do you just plug them in the factory wiring? Or do you rerun the tweeter wire from the uno's cross over?
    Thanks again
  30. Feb 2, 2019 at 12:28 PM
    #150
    How’s he pushing hard on this? He’s simply helping us get better pricing. Feel free to order separate and not here if that’s how you feel.
    James has fantastic customer service. All I have found on FB, and here is nothing but how great his customer service is.
Thread Status:
