4.88 or 5.29
Discussion in 'Performance and Tuning' started by turboser91, Jan 30, 2019.
  1. Jan 31, 2019 at 6:51 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Know anyone that has broken any of them from regular use on 35's and not geared?
  2. Jan 31, 2019 at 7:18 PM
    You will not "break" it, more so added wear and tear due to extra heat to get the same amount of performance from a stock tire and drivetrain truck. For instance, for a truck with 35's to get up to 60 mph with stock gearing takes more energy than the same truck in factory form.
    Make sense?
    JuanTon21, jc153, BestGen and 2 others like this.
  3. Jan 31, 2019 at 7:22 PM
    Vizsla
    Vizsla pretend2send
    Not so much about breakage, less mpg and more wear from higher temps. This refers to 5.7 transmissions. We have a 6 speed transmission with two overdrive gears(5th and 6th), and also have torque converter lockup on 4th, 5th, and 6th gear. When running 35” tires you will almost never reach torque converter lockup in 6th gear, this means lower mpg, and slightly higher transmission temperature because the torque converter is slipping instead of locked. If you have 35” tires, pay attention while downhill under very light throttle, you can feel when the torque converter locks in 6th gear. Tundras with smaller tires will cruise at highway speed in 6th gear torque converter locked.
    des2mtn, tundra_20, 831Tun and 5 others like this.
  4. Jan 31, 2019 at 7:27 PM
    Sas
    OKC, OK
    Didn't know that about the torque converter. Not sure I've ever felt the torque converter lock though, even on the original tires TBH.
  5. Feb 1, 2019 at 4:30 AM
    Mnorris1206
    08 tundra
    So I should be seeing my transmission temp go up then? while pulling my camper threw mountains for sure. I really have not had those .I really understand the issue that can aries for sure .
  6. Feb 1, 2019 at 4:38 AM
    Professional Hand Model
    Fred
    Hand Protectors
    You are in good shape then.
    One thing I don’t hear about being under-geared is the possible benefit of less stress on trans at highway speeds. A higher geared diff is good for low speeds and an under-geared diff good for high speeds? Anyone am I wrong here?
    Mnorris1206[QUOTED] likes this.
  7. Feb 1, 2019 at 4:42 AM
    Fred
    Hand Protectors
    I understand your point here.
    So, with that chart recommendation list, would you slide all those recommendations to the right to factor in weight/wind drag?
    If so, how many blocks would you slide? Based on average weight and normal wind drag.
  8. Feb 1, 2019 at 5:07 AM
    One thing I'm not seeing asked is what about the speedometer? How do 35s ungeared compare to geared? Stock tires on my other car are 215 55 r16. When I bought it it has 225 40 zr18. Bigger wheels, but smaller overall OD. Even that small difference of about 3% puts me 5 under at 70 mph. That's why I'm planning on some 235 45 zr18s pretty soon.
  9. Feb 1, 2019 at 6:06 AM
    I would push one block to the power side. If the chart said 4.88, if 5.13’s were available, that’s what I would choose. I went through this on my 2nd re-gear on the heep. I went 4.88’s and a buddy went 5.13. Same setup and i regretted it.
    Some areas to consider also is pinion gear size. Depending on what the purpose is for the vehicle. Smaller ring and pinions are known for failure by having to much gear.
    Darkness, Grumpy Uncle and 15whtrd like this.
  10. Feb 1, 2019 at 6:17 AM
    Grumpy Uncle
    Pat
    CO
    I really enjoy my 4.88s, hind sight being what it is I kind of wish I waited for the infamous 5.29s. I would like a little more grunt. Do I need it it? No! Do I want it? Yes
  11. Feb 1, 2019 at 6:19 AM
    Great thing about the Tundra is it actually has power. Jeeps...lol. You can get away with it.
    I can’t wait for LS time.
    15whtrd and Grumpy Uncle[QUOTED] like this.
  12. Feb 1, 2019 at 6:24 AM
    Grumpy Uncle
    Pat
    CO
    My buddy has a jeep, currently running 35s. He wants to go up to 37s. He wanted more lift, I told him, he better go to deeper gears.
    I thought you already went LS. When do you plan on swapping?
  13. Feb 1, 2019 at 6:27 AM
    Not yet. Been lazy or busy. Lol
    As it sits right now...
    Been doing other little things to make the heep a better wheeler. This weekend is getting the 5 point harnesses back in.
  14. Feb 1, 2019 at 6:31 AM
    Oh, and an aluminum roof.
    15whtrd likes this.
  15. Feb 1, 2019 at 6:54 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I need to point out that this is getting mixed up with 5.7 and 4.7 Tundras. You overgrown behemoths are very different and will get different results, this is first gen land.
    :boink:
    For 35s with stock gears the speedo will read really slow compared to actual speed. For 35s with gears it depends on the gears, 4.56 will read close to correct while 4.88 or up will read faster than actual speed.
    My truck has 33s and 4.56, it was about 8% over actual speed (says 54 when GPS says 50). I corrected my speedo and now it's dead on.
  16. Feb 1, 2019 at 6:56 AM
    That extra 100 hp would be nice for the 1st gens.
    Grumpy Uncle and Darkness like this.
  17. Feb 1, 2019 at 6:59 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    One day I will get the elusive supercharger.
    831Tun likes this.
  18. Feb 1, 2019 at 7:03 AM
    Grumpy Uncle
    Pat
    CO
    That might wake it up a little. :mudding:
  19. Feb 1, 2019 at 7:10 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yes in theory but no I practice. If you had a very torquey diesel that could keep you going at low rpm, sure. Or if you were on the Wyoming highways where it is completely flat maybe.
    But our automatic transmissions downshift at the slightest grade. When i had 35’s on stock 4.30 gears, the trans was shifting like crazy on the freeway. Every overpass, gradation, hill.
    831Tun likes this.
  20. Feb 1, 2019 at 7:51 AM
    #50
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Who did your install?
  21. Feb 1, 2019 at 7:53 AM
    #51
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    ^^^^^ This^^^^^ Unhappy tranny with 35s and 4.30 gears.
    Ely010606 likes this.
  22. Feb 1, 2019 at 8:02 AM
    #52
    Sas
    OKC, OK
    Really? I don't get this at all in mine. I run mine in tow/haul mode though and am typically going around 75-80 on the highway, so maybe it's always in 5th or something lol. I still get about 15-16 MPG on the highway though, so who knows?
  23. Feb 1, 2019 at 3:54 PM
    #53
    Oh yeah, you did the yellow box thing a few months ago, right?
    Darkness[QUOTED] likes this.
  24. Feb 1, 2019 at 4:02 PM
    #54
    deedubb
    deedubb New Member
    2018 Tundra SR5
    Install pending, but will be done by Colorado Axle and Gear in the next few weeks
    smslavin and 831Tun[QUOTED] like this.
  25. Feb 1, 2019 at 8:59 PM
    #55
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yes I did! Anybody with an 04 or older and a miscalibrated speedo should do the same.
  26. Feb 1, 2019 at 9:01 PM
    #56
    Casper421
    In the woods
    06 DC
    :frusty:
  27. Feb 1, 2019 at 9:38 PM
    #57
    I'm 02. Sad face...
  28. Feb 2, 2019 at 3:52 AM
    #58
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It will work on an 02
  29. Feb 4, 2019 at 11:12 AM
    #59
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Are 5.29 already out? Nitro website still say 03/31/2019.
    Rica25 and 831Tun like this.
  30. Feb 4, 2019 at 11:23 AM
    #60
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    chugs, Rica25, BestGen and 4 others like this.
