Bilstein 6112/5160 & CB +2 shackles installation tips
Discussion in 'Suspension' started by Krewcial, Jan 30, 2019.
  1. Jan 30, 2019 at 7:17 AM
    Krewcial
    Krewcial [OP] So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    After jumping around and researching tons of information online. I figured I would post what steps and videos I used to complete my Bilstein 6112(third setting 1.9” lift)/5160 & CB +2 shackles installation on my 2010 Tundra without a spring compressor.
    Also the reason I choose the 1.9” setting was to have a balance of lift/comfortable ride and the CB +2’s would give me some lift to maintain rake in the rear. This will also help me avoid cost on other major suspension components when it comes to lifting above 2.5”.
    Enjoy and hopefully this makes life easier for some of us Tundra owners!
    Special thanks to:
    David Ekstrom
    Ekstrom Design and Fabrication
    (Appreciate the group buy price on CB +2’s and working with me to get the lift I wanted)
    801-635-4872
    https://shop-coachbuilder.myshopify.com/
    Randy Rusk
    Xkstensive Offroad
    (David Ekstrom referral awesome deal on the Bilstein 6112/5160’s)
    (318)-792-7767
    https://www.xkstensiveoffroad.com/
    Tools needed:
    -Hydraulic jack
    -Jack stands (please use jack stands to support your vehicle)
    -Torque wrench
    -Breaker bar
    -Cheater bar (leverage to break loose some tough bolts)
    -Socket wrench’s
    -24, 22, 19, 17, 14mm sockets
    -19, 18, 17, 14mm wrench’s
    -Vise-Grip locking pliers (used to hold the shock rod from spinning)
    -loctite
    -Anti seize
    -Wire brush
    -pry bar
    -rubber mallet
    -flat head screw driver
    -ball joint press (rented from O’reilys)
    -impact gun(will make pressing the bushings for the shackles out much easier)
    Videos:
    Installing front 6112’s
    (tip while the car is still on the ground unbolt the front sway bar on both the front driver and passenger side. When done make sure the sway bar is in its groove and rebolt them with the truck on the ground or you will struggle getting it aligned)
    Shock assembly
    (the two washers he threw to the sides are used for spacers on the bump stops. Two per a side/1 spacer per bump stop)
    *Thanks @dirtydeeds
    https://youtu.be/A0ww8bRNrw4
    Used the videos as a reference as they are the same for the tundra besides having to deal with the front sway bar and different bolt sizes.
    Alignment bolts to adjust are towards the rear of the truck and towards the front tighten/loosens which allows for adjustments. Mark them since you’re moving the lower control arm and ALWAYS get an alignment after any suspension modification. (Firestone has lifetime alignment)
    Alignment tips for tech:
    -Camber = 0 - .1 (Get as close to 0 as possible)
    -Caster (Get as much as possible)
    -Toe = 0.05 (.1 total)
    https://youtu.be/5E6u7dC7EHg
    https://youtu.be/jo0FJSi-KYs
    (FYI... Your shoulders will burn installing the bolt to the rod that secures the top hat to the shock with the spring fully compressed)
    Installing CB +2’s
    -Poly bushing removal with ball joint press
    https://youtu.be/QbwT5DEYe6E
    Shackle removal/install
    (Install Bolt side on inside for clearance and nuts to the outside)
    -Torque bolts 70 ft/lbs once there’s weight on the shackles (the video states 90 ft/lbs for the older steel shackles)
    *Thanks @Coachbuilder1
    https://youtu.be/zmJ6Xjjtpe8
    Torque specs:
    *Thanks @csuviper
    https://www.tundras.com/threads/suspension-torques.4740/
    Please feel free to correct or add any information that I have left out. We’re all human lol.
  2. Jan 30, 2019 at 8:11 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Good tips. I did a similar write-up with tips and advice after I did my 6112s last summer. Seems like most on here have a shop install new suspension parts for them, but threads like yours are always helpful for those of us who like to tackle it on our own.
    15whtrd, Tundrablue and Krewcial[OP] like this.
  3. Jan 30, 2019 at 9:07 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Krewcial Excellent job on your writeup, we all greatly appreciate posts like this :thumbsup:
  4. Jan 31, 2019 at 7:08 AM
    VBTundra
    VBTundra New Member
    Great write up man!
    Krewcial[OP] likes this.
  5. Feb 25, 2019 at 9:57 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Thanks!
  6. Feb 25, 2019 at 10:06 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Another way to remove the leaf spring bushings for those without impacts or want to rent a press.
    I took a torch to my stock bushings. Got them good and hot. Damn near on fire. Then drilled through them with a 1” milaukee hole saw. Once I got the core out. I then cut the top and bottom of the outer sleeve with a sawzall. Then got a 1 1/4” socket which is the exact diameter of the outer sleeve. Couple hits with a maul and it popped right out.
    Krewcial[OP] and equin like this.
  7. Feb 25, 2019 at 10:14 AM
    itsBryantP
    itsBryantP New Member
    B
    Awesome write up! Gonna be using this to tackle the same job pretty soon here.
  8. Feb 25, 2019 at 3:22 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  9. Jul 9, 2019 at 7:14 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Any photos of the truck now? Still on Bilstein or switch to the Pros? Shackles in the rear?
  10. Jul 9, 2019 at 9:11 AM
    Krewcial
    Don
    I’ll take some photos tonight once I get home. Stuck with Bilstein 6112’s (1.9” setting) and 5160’s in the rear with CB +2 shackles.
  11. Jul 10, 2019 at 4:41 PM
    Krewcial
    Don
    equin and cmiller219 like this.
  12. Jul 10, 2019 at 5:03 PM
    cmiller219
    Nashville, TN
    Thanks for the photos looks great
  13. Jul 10, 2019 at 5:23 PM
    Krewcial
    Don
    No Problem, forgot to add that my rake is 1.5”. The front bumper dropped the front lift to 1.75” at the 1.9” setting
    equin likes this.
