Installing Sub to stock stereo - my install
Discussion in 'Audio & Video' started by csuviper, May 28, 2015.
  1. Apr 19, 2018 at 12:15 AM
    MGMTUNDEE
    MGMTUNDEE New Member
    Quacky
    Tampa
    Will all this wiring stuff work for my 18 crewmax?
  2. May 13, 2018 at 7:44 AM
    Assassin77
    Assassin77 New Member
    Toyota Tundra T Force Crewmax 2012
    It really would have helped if you would have showed which speaker wires you hooked to in the back of the stereo
    Sunnier likes this.
  3. Aug 2, 2018 at 9:45 AM
    Jdawg23
    Jdawg23 New Member
    2012 black tundra rock warrior 4x4 5.7
    Do you have a picture on how you did the Wires ? Running the wires to a stock stereo ?
    Sunnier and GNTundra like this.
  4. Nov 30, 2018 at 7:36 PM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    Here’s a box I built for 2 DD Audio Redline 8” 508 D2 subs. Rear seat sat right on top of it. Had it for a week and traded it for my current monster a Ampere Audio 3.0 15” in a T-line box I built. Fuck the rear passengers I took my long seat out and used the whole area for the box
    Idaho Tundra and csuviper[OP] like this.
  5. Jan 24, 2019 at 2:59 PM
    Idaho Tundra
    Idaho Tundra New Member
    Josh
    Boise ID
    2015 crew max 4x4 5.7L
    295, 70, 18 KM3’s, 18" Vision Rockers, K&N Intake, Bilstein 5100's, Decked System, Leer Camper, Van Tech Roof Rack,
    Perfect! Thanks for posting the dimensions.
    PSYCHO WHITE TUNDRA likes this.
  6. Jan 25, 2019 at 8:44 PM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    Not sure if anyone is interested in bigger boxes but Here’s another box i built with dimensions. This one is for a 15” sub capable of 1500 watts rms. The box is 3.5cu.ft and tuned to 33hz. Any questions, issues or if your needing specific box dimensions for a sub box tailored to match your subwoofer specs. Just ask me or send me the spec sheet for your sub and dimensions you got to work with and we’ll come up with something.
    csuviper[OP] likes this.
  7. Apr 16, 2019 at 8:30 AM
    Windsor
    Windsor New Member
    Oregon
    2008 Tundra Crewmax 5.7L
    Seat covers, SnugTop.
  8. Apr 22, 2019 at 12:27 PM
    Windsor
    Windsor New Member
    Oregon
    @csuviper, any additional pointers? Just ordered a LOC and amp wiring kit. Just wanting to give the radio a bit more bass while keeping stuff looking stock. Just a 8" behind the seats.
  9. Apr 22, 2019 at 3:51 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Really not to difficult. Just run cables as clean as possible. Spend the extra money on cable covers/sleeves and take the extra time to get wires trimmed to good lengths.
    Swamprat66 and Windsor like this.
  10. Apr 22, 2019 at 3:52 PM
    When can you help me with my dash speakers?:D
  11. Apr 22, 2019 at 3:56 PM
    csuviper
    Broomfield, CO
    After i complete the install of my LCA skids, rear diff skid, FRAC harness, pillar mount ditch lights, rear camp lights, reverse lights and tint my tail lights. Yea i just cant find much time with two boys in sports and a busy job right now. Sorry man.
  12. Apr 22, 2019 at 3:57 PM
    Soooo tomorrow?:p
    Migraine, csuviper[OP] and JoshuaA like this.
  13. May 3, 2019 at 10:35 PM
    Windsor
    Windsor New Member
    Oregon
    Thanks again @csuviper. Got mine hooked up and tuned (to ear). Used the Kicker LOC.
  14. May 23, 2019 at 10:04 AM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    It’s possible. See video below
    https://youtu.be/VaXHgErZoXE
  15. Jun 26, 2019 at 1:34 AM
    james33440
    james33440 New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    Still have this box for 2 8’s or interested in building a box? PM me
  16. Jun 27, 2019 at 3:52 PM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    I don’t have the box anymore. I can see if my buddy still has it. What part of the US you live in
  17. Jun 30, 2019 at 10:40 AM
    james33440
    James
    Magnaflow Exhaust
    I’m in FL. Please let me know. Thanks
  18. Aug 16, 2019 at 10:54 PM
    james33440
    James
    Magnaflow Exhaust
    Any luck with the box being available?
    Do you at least remember the dimensions or at least what the height was on the box? I can get one made or look for a prefab box.
  19. Aug 22, 2019 at 4:23 PM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    I just measured as I went along. Wasn’t hard to do though. Get a big section of cardboard from an appliance store. Build the box out of cardboard and tape with your dimensions and see how it fits under the seat and adjust your dimensions until it fits properly. It’s called a double wedge enclosure. Your bottom section will sit up 1” higher on the bottom of your front piece to make up the difference on the floorboard to the hump under the seat.
  20. Sep 2, 2019 at 2:50 PM
    #50
    Fire123
    Fire123 New Member
    2015 White 1794 Edition
    7" BDS w/ Fox, Fuel Wheels
    Excellent work and outstanding step by step.
    Thanks for the efforts...
  21. Nov 20, 2019 at 4:05 PM
    #51
    frontstmaui
    frontstmaui New Member
    Grayson
    2019 Tundra SR5 (Quicksand)
    I was told by 2 different shops that they cant put a sub box behind the seats due to the rear window motor/space.
  22. Dec 2, 2019 at 9:13 AM
    #52
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    Well I too got tired of hunting for a box for a single 12 without spending a fortune, so I used Brian’s concept to make my own box for a sub/amp that I already had. The dimensions were modified to fit my needs and I added an amp rack next to the sub and wrapped it in carpet. And ran the wires behind the box for cleaner install.
    For the line out converter I tapped on to the current sub’s wires in the back since the signal already went through the factory amp crossover.
    I kept the factory plastic panel covering the factory sub but cut it about 1/2 way to remove the factory sub cover to fit the new box allowing part of the plastic to be there above the new box for the factory look.
    I also ran a 2nd pair of RCAs from line out converter to the front to a volume control knob (I listen to range of music and wanted to have the ability to turn the sub up or down) and then back to the amp.
    I didn’t really take many photos of the build, but if anyone is interested, I can provide specs.
    It’s a night and day between factory sub and even wifey was impressed with sound quality and the build.
    For those with a table saw and a little carpentry skills, pull the trigger. It cost me less than $50 to build the box.
    Thanks Brian for inspiration.
  23. Jan 15, 2021 at 4:05 PM
    #53
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    I'm trying to build my own box for a single 10" sub. Can you share the specs of your build?
    Please and thank you!
    BLONGTX likes this.
  24. Jan 19, 2021 at 5:52 PM
    #54
    ZeRussian
    ‘11 CrewMax
    Your ‘21 Tundra will have different specs since I had black plastic paneling and a seat that flips the backrest down vs you shouldn’t have black paneling and a seat that has a seat rest flip up. I’d love to help, but I don’t think I will be very helpful.
    AT x AT likes this.
