Need help adjusting Coilover ride height
Discussion in 'Suspension' started by Markman, Jan 19, 2019.
  1. Jan 23, 2019 at 7:34 PM
    Markman
    Markman [OP] New Member
    Mark
    Utah
    2019 limited cement cm
    Tint airbags daystar cradles Elka suspension bushwacker flares
    I’ll admit I was stupid for not washing the shock better was dumb on my part, I got one turn and it was hell then I washed it oiled blew air with my compressor lubed it cleaned it really well got it to turn up fairly easy after it get out of the spring moved it up and down a few time lubed it lots but as soon as it drops into the spring it’s tight... I appreciate everyone’s help so nice to have a great forum with great ppl to help solve problems I know one way or the other Ill get it hey if it’s a case of bourbon that’s a price I’m willing to pay lol for use of your garage
  2. Jan 23, 2019 at 7:35 PM
    On an adjustable coilover? Never.
    Inquiringone likes this.
  3. Jan 23, 2019 at 7:44 PM
    For a case of Buffalo Trace...might as well buy a new shock...:D
    This is an expensive lesson for sure.
    Maybe one of our UT members has a N2 charge kit and could help a brother out in need.
  4. Jan 23, 2019 at 7:50 PM
    Markman
    Mark
    Utah
    Well the shock is not ruined yet. I need about a 1/4 inch more turn to get it about where I want it worst case it sits as is. Hopefully I have time to make a new tool tomorrow and give it a try. This is a pic with a screw driver edges in there don’t think threads are messed up it goes up easy just not down like the collar is to tight in the spring58CE5DAA-3A82-4830-A2BA-08918B3F4180.jpg
    ColoradoTJ likes this.
  5. Jan 23, 2019 at 8:01 PM
    Looks like the CAN has had just a "little" torque on it...LOL!!!
    Well hopefully you get it where needed and leave it until a rebuild is due. Educate yourself, buy some tools, N2 charge kit, and tackle it yourself.
  6. Jan 23, 2019 at 8:02 PM
    Vizsla
    Vizsla pretend2send
    No offense, but with a single ring adjuster, both Fox and King require a coil spring compressor to adjust(and supposed to remove from vehicle). My comment about nobody in the thread was exactly to the point. You cannot adjust them without compressing the coil. I seriously doubt anything is damaged. Here is the caveat of the split ring, if you pull right beside the split in the direction you turn it digs in, pull opposite or as far away from the split as possible. You won’t get it till you do one, I was surprised my first try. OP, I think if you compress the coil more it will adjust, again might take a few tries to get where you want.
  7. Jan 23, 2019 at 8:32 PM
    equin, 040Tundra and Markman[OP] like this.
  8. Jan 23, 2019 at 8:38 PM
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    I had a really hard time adjusting my icons too and I had the spanner wrench
  9. Jan 23, 2019 at 8:40 PM
    Vizsla
    Vizsla pretend2send
    It comes direct from Fox and King via phone conversations per adjusting Tundra(and Tacoma) coilovers. Remove coilover, compress, adjust. I suggest you call.
    Here is where a member called, and Fox switched to the spit ring in 2016, so same.
    https://www.tundras.com/threads/adjusting-king-front-coil-overs-for-tundra-lean.21143/
  10. Jan 23, 2019 at 8:43 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Damn, this must be a lot harder than a dirtbike shock. I usually turn mine by hand until it is half way. I will have to see about adjusting mine ahead of installation when I get my new suspension.
  11. Jan 23, 2019 at 8:46 PM
    cantle
    cantle New Member
    Durango, CO
    2018 Platinum CrewMax Barcelona Red
    TRD Pro Exhaust, TRD Skidplate, TRD Faux-Pro wheels, Ridge Grapplers
    I don't know much about these, but I talked to a shop with a great reputation from guys on here, and said shop indicated that Elka *had* to be removed from the vehicle to adjust height. Again, I can't verify with experience, but just putting that out there.
    Vizsla likes this.
  12. Jan 23, 2019 at 8:50 PM
    Markman
    Mark
    Utah
    Yeah I wish I would have done exactly that!! I just figured it was easy damn I was wrong. Installing way easier than adjusting never would have guessed lol
  13. Jan 23, 2019 at 9:03 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I haven’t adjusted my Radflos but I did my Toytec Boss Coilovers. Did in on the truck with provided spanner wrench. No issues. Did not pull off of truck and did not use spring compressors. All I did was lift the front end off the ground and wheels droop.
    equin and Markman[OP] like this.
  14. Jan 23, 2019 at 9:10 PM
    Vizsla
    Vizsla pretend2send
    It’s the single split ring used by Elka, Fox, King that makes it different. Crappy way to save a few bucks imo, but maybe there is some other reason.
  15. Jan 23, 2019 at 9:12 PM
    cantle
    cantle New Member
    Durango, CO
    I noticed that looking at the shocks closer now. The Elka has a single ring, but the fox 2.5 has two, I assume for this purpose?
  16. Jan 23, 2019 at 9:14 PM
    Vizsla
    Vizsla pretend2send
    Fox used to have two, now only one split ring.
  17. Jan 23, 2019 at 9:19 PM
  18. Jan 23, 2019 at 9:53 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    posibality go to an alignment shop for some help, if things go south, on you :popcorn::popcorn::popcorn:good luck
  19. Jan 23, 2019 at 9:59 PM
    Throwwire
    Throwwire New Member
    Gerry
    Humboldt county
    08 ext cab,16 platinum crew
    08 leveled 35s fab four bumpers light bars 16 leveled
    For all your hassle and time spent, most likely galled the threads, remove the coilover back up the ring,clean the threads,it shouldn't be that hard to spin and hope it adjusts back down to where you need it
    csuviper likes this.
  20. Jan 23, 2019 at 10:10 PM
    #50
    csuviper
    Broomfield, CO
    Think the boss is one ring, dont think its split though. Cant remember at this point.
  21. Jan 24, 2019 at 8:32 AM
    #51
    Elka Suspension
    Elka Suspension Shock Manufacturer
    Boucherville, QC, Canada
    Dear @Markman,
    I am Patrick, Marketing Director at Elka Suspension, and I would like to help you.
    Based on the photos you posted, it seems that maybe there's an issue that needs closer inspection.
    Could you please contact me directly?
    You can reach me via email at pat@elkasuspension.com or via phone at 1-800-557-0552 ext.227.
    I am looking forward to hear from you and get this situation resolved.
    For general reference, Elka recommends the following when adjusting the preload:
    1. Always work on clean shocks. Small debris such as sand or dirt can cause additional friction that would make the adjuster very hard to turn. Ensure everything is cleaned thoroughly. You can also use soap or a light lubricant to help the process. Just make sure to dissolve the lubricant after the procedure with water or brake cleaner.
    2. You need to loosen the locking screw just enough that it can turn freely, no more (about one turn). It is important not to remove the screw and not loosen it too much as this can cause the ring to split too wide and possibly jump over the thread, rendering any adjustment near impossible if the ring is cross-threaded.
    3. When looking to increase the preload, we highly recommend removing the shocks from the vehicle and using a spring compressor. Is much easier to remove the spring, move the preload adjustment ring into position then re-install the spring than it is to try to move the adjuster with the spring installed. Most trucks often use heavy springs that are very hard to compress. The use of a spring compressor (Branick) is often required to achieve proper compression to reach the desired setting.
    4. Applying 5 turns of adjustment will increase the preload by 5mm (3/16"). As a rule of thumb, we recommend a maximum of 1/2" of preload to be applied; otherwise we recommend switching to a higher spring rate.
  22. Jan 24, 2019 at 8:52 AM
    #52
    Looks like you are correct Dave. Elka recommends removing the shock.
    Damn that would suck ass.
  23. Jan 24, 2019 at 9:10 AM
    #53
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Having owned both Kings and Elkas, I can see exactly what’s wrong with this picture. If you open the hex screw too much, the preload adjuster will cross thread when you try to add preload.
    @Markman you should pull the whole coilover and put it in a proper spring compressor so you can reseat the preload adjuster. Tightening it more is why you broke the tool.
  24. Jan 24, 2019 at 9:33 AM
    #54
    jberry813
    Lake Tahoe
    All manufactures say the same thing. It’s a CYA clause.
    That said, I can tell you that the preload collar on the Elkas is nicer than King. It has more holes in it which allow you to adjust preload without the UCA or remote resi fitting getting in the way. The Elka adjuster punch sucks tho. Not enough leverage. I ended up using the King adjuster.
    48BADA8A-2D64-4E65-9DED-4CF5135AC734.jpg AF18315C-0FD6-48C0-AA16-2D257AD29438.jpg
    aperezsh and ColoradoTJ[QUOTED] like this.
  25. Jan 24, 2019 at 9:48 AM
    #55
    n2deep
    n2deep Pavement Princess
    I have never had to pull my Kings to adjust. Just use a punch and spanner wrench with the wheel in the air. If you are in Southern UT I can assist but its too damn cold in the Northern part of the state for me. My guess is the bolt on the the ring is too loose and allowed it to jump threads causing it to bind up.
    equin likes this.
  26. Jan 24, 2019 at 9:56 AM
    #56
    15whtrd
    15whtrd Mr. Blonde
    It seems like if they were to provide an anti-friction ring under the adjustment nut it would solve a lot of these issues.
  27. Jan 24, 2019 at 10:17 AM
    #57
    jberry813
    Lake Tahoe
    A what?
    It’s not a friction problem. We are talking about a 700 lb spring rate here. Meaning it takes 700 pounds of force to compress that spring 1 inch.
    15whtrd[QUOTED] likes this.
  28. Jan 24, 2019 at 10:24 AM
    #58
    15whtrd
    15whtrd Mr. Blonde
    I get it. And by friction ring I just mean a washer. Other than dirt being the problem I would think he would’ve had more luck when he was using the spring compressor and it still wasn’t moving.
    jberry813[QUOTED] likes this.
  29. Jan 24, 2019 at 10:27 AM
    #59
    jberry813
    Lake Tahoe
    Yeah at this point the whole preload collar is cross threaded. Seen it happen with Kings before with the set screw loosened up too much and high spring rates or lots of preload. Widow makers aren’t gonna help until you remove all the force off the preload collar so you can back the set screw all the way out and pop the collar back on the threads (assuming it didn’t chew up the shock bodies or collar too much). You literally only have to back the set screw off one turn.
  30. Jan 24, 2019 at 10:30 AM
    #60
    15whtrd
    15whtrd Mr. Blonde
    Now that makes sense.
