Anyone running the Eibach Pro-Truck Lift (Stage 1)?
Discussion in 'Suspension' started by Talkdirttome, Jan 6, 2019.
  1. Jan 6, 2019 at 11:44 AM
    Talkdirttome
    Talkdirttome [OP] Dad
    Jon
    So Cal
    2018 Silver Tundra CM 4x4
    Toytec Lifts likes this.
  2. Jan 22, 2019 at 7:47 AM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
  3. Jan 22, 2019 at 10:11 AM
    Talkdirttome
    Jon
    So Cal
    That is a good price on the 5100's. Are you looking to do the shackle to keep some rake in the stance and not have it sit level?
    Sure would be nice to hear from someone who has the Eibach setup.
  4. Jan 22, 2019 at 11:27 AM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    I need a little rake since I tow frequently. I will probably still add airbags in the rear since I tow a wake boat, but don't want to make it a necessity for towing anything else.
    I would really love to hear from someone who has run both lol! I want whichever one rides smoother on the road since I don't get off the pavement much at all.
  5. Jan 22, 2019 at 2:31 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    This kit is honestly very awesome.... We have a good hand full of people on this forum that run this kit.
    The front coilovers can be adjusted or "pre set" on the bottom clip setting to yield 2'' of front end lift. Coilovers can be found Or if you are looking for a 3'' front lift, we adjust or "pre set" them on the 2nd clip setting to yield 3'' of front end lift, and with that you have a choice of rear lift options that fit your needs perfectly.
    Full kit can be found Let us know if you have any questions!
    -David
  6. Jan 22, 2019 at 3:23 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    Thanks David. When I go to the complete kit, it shows both front and rear options are backordered. What kind of timeframe do you think it will be before you get anymore?
    Toytec Lifts[QUOTED] likes this.
  7. Jan 22, 2019 at 3:52 PM
    Toytec Lifts
    Denver, CO.
    As of right now its the end of February but that may change as we get closer to that "expected date".
    Thanks!
  8. Jan 22, 2019 at 8:31 PM
    Talkdirttome
    Jon
    So Cal
    Thank you for the reply David!
  9. Feb 17, 2019 at 2:11 PM
    georger77
    georger77 New Member
    2016 Toyota Platinum Crewmax
    I had the eibach coil springs installed with the Bilstein 5100 up front and the 5160’s with a 1 inch shackle lift in the back. The coils along with the 5100 set at .87 got me close to 3inches in the front. My truck has a slight rake and rides really nice. This set up is definitely a nice upgrade over my stock set up. I have enough clearance to run a 35 in the near future as well.
    Talkdirttome[OP] likes this.
  10. Jun 7, 2021 at 7:46 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Bump for pictures!
  11. Jun 7, 2021 at 8:00 PM
    platslvrblt19
    platslvrblt19 New Member
    San Antonio, TX
    ‘19 Silver Platinum Tundra
    Front Eibach w/shims , rear 5160s and 1.5” shackles
  12. Jun 9, 2021 at 2:06 PM
    Tyrus001
    Tyrus001 New Member
    Ty
    2021 Crewmax
    Nice! By shims, do you mean you left the front at 2" setting and added 1/2" shims on both sides?
  13. Jun 9, 2021 at 2:26 PM
    tgrave1
    tgrave1 New Member
    Huntington Beach, CA
    2020 SR5 TRD 4X4 Sport
    Eibach Pro Kit. Camburg UCA's. Coachbuilder bumper shims. Cab mount chop. N-Fab side steps. 18 inch Method 308 Roost wheels. Falken Wildpeak AT/3 tires (295-70-18). Gator EFX bed cover.
    I have the Eibach stage 1 set at the top setting with a 1 inch shackle in the rear. Been happy with it so far though I have heard ride quality may increase if I adjust them down and add shims.
    Tyrus001 likes this.
  14. Jun 9, 2021 at 2:30 PM
    CCLJ03
    Craig
    PapaGrizz likes this.
  15. Jun 9, 2021 at 2:41 PM
    MightyTundraGA
    MightyTundraGA New Member
    Good lookin' truck. Newb question here, but why would you have Eibach 5160's AND shackles on the rear? Does that give you extra height above and beyond what the 5160's give you?
    CCLJ03 likes this.
  16. Jun 9, 2021 at 2:56 PM
    CCLJ03
    Craig
    The Eibach rear shocks don’t actually give you any lift. They are advertised as 1” lift rear shocks because that’s what they allow for - up to 1 inch of lift with shackles or a block.
  17. Jun 9, 2021 at 3:11 PM
    MightyTundraGA
    Got it. So, the Eiback shocks give you better off road capabilities than stock shocks, but they don't give you more height, so you put the shackles on to give you height + better off road suspension? If you're doing some mild off roading and want this exact stance, would you go with the Eibach's or would you just go with a leveling kit? Sorry....not trying to hijack the thread. Just trying to figure out how I make my truck look like that, but still maintain optimum onroad performance and comfort.
    AircareTundra and CCLJ03[QUOTED] like this.
  18. Jun 9, 2021 at 3:38 PM
    CCLJ03
    Craig
    A spacer leveling kit is going to be the cheap option, but will put stress on front end components and hurt the ride quality. An Eibach kit (or one like it) would give you front end lift, some even say better than stock ride quality (it’s subjective), and better geometry for your front end components.
    Your truck probably has about 2” of forward lean or “rake”. If you tow you’ll want to maintain some rake to keep the ass of your truck from sagging horribly when hitched/loaded. So of you raise the front you can add shackles to the rear to get the forward lean back.
    good questions! if you have more send me a PM. I’m happy to help.
  19. Jun 10, 2021 at 5:29 AM
    platslvrblt19
    San Antonio, TX
    Correct, coilovers are on the top setting (I got about 3”) and 1/2” Coachbuilder shims on top.
  20. Jun 10, 2021 at 5:36 AM
    platslvrblt19
    San Antonio, TX
    Shocks = ride quality, shackles = lift. The Bilstein 5160s are a stiffer shock than stock, so they don’t bounce/sag as much, but do not provide any lift (maybe .25” inch if any) - the shackles provide the 1.5” rear lift.
  21. Jan 1, 2022 at 1:22 PM
    ekertz
    ekertz New Member
    Do you need aftermarket UCAs with the complete lift from toytec? Their other 3in lifts strongly suggest them, understandably, but not this one. Why is that?
  22. Jan 2, 2022 at 9:25 AM
    tgrave1
    tgrave1 New Member
    I am running the Pro Kit on the highest setting. Have 1 inch rear shackles and still have a slight reverse rake. She is going in for UCA’s in two weeks to help with ride and alignment.
    ekertz likes this.
